Question about Kodak EasyShare Z710 Digital Camera
Lens stuck camera turing on and off
Our camera turns on, but the lens is stuck in its open zoom position and it sounds like the motor is running trying to extend the lens. Then it turns off
  • Anonymous Mar 27, 2014
    camera on stuck with lens extended snd wont close
    Genius:
  • 2,985 Answers
Lens mechanism is shot. A repairs is not likely to be an economic proposition Contact Kodak customer support for a try
Posted on Jul 29, 2007
Les Error, cannot get in focus when in auto focus. I when itry and use the zoom I get a lens error and retry power on
the lens unit was not extend properly and cause of turning off once you turing on and zoom out.If you can open the camera and get the lens unit. Try to open the lens unit and clean it and try to rotate to the maximun position but dont put too much force. if you cannot do that bring it to service center
thank you
Jun 17, 2010 | Casio Exilim EX-S500 Digital Camera
Camera dropped. lens is stuck in open position, won't turn on
Hello
Thank you for using FixYa for your problem
Zoom lens is jammed, It should be taken to an authorized repair centre for a repair estimate. Very few digital cameras have any user-serviceable parts.
Please rate our solutions and if you still have problems please call back for more ideas to help you
Thanks
Richard Scott
Technical Support
New Zealand
Jan 20, 2010 | Cameras
Lens is stuck in the open position and when i try and turn on the camera, it makes a clicking sound and displays a LENS ERROR message
lens is stuck inthe open position and displays a lens error message and when I try turn on camera ,it makes a clicking sound
Jul 06, 2009 | Casio Exilim EX-S600 Digital Camera
Cannon PowerShot S2 IS lens is stuck
I have the exact same problem, took it completely apart removed the zoom motor, physically turned the zoom gear and retracted the lens, reinstalled the motor, put it all back together, and found that I had the same problem and the lens wouldn't move out, so im pretty certain that the motor is bad, as the lens moves smoothly once the motor is not attached to it... looking for a replacement motor as i type...
May 29, 2009 | Canon PowerShot S2 IS Digital Camera
Canon powershot s2 15 shutter won't open
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open).
To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see the following for further info and a simple fix that may help:
http://camerarepair.blogspot.com/2009/05/simple-fix-for-stuck-shutter.html
May 10, 2009 | Canon PowerShot S2 IS Digital Camera
My digital Sony camera fell down Lens got stuck
    As in short answer you have to replace the optical lens assymbly.Because due to heavy jurk its motor called sledge motor stsrt malfunctioning and it can not be changed component level. For this please contact any SONY SERVICE CENTRE nearby to you.
Hope you will understand.
Thanks for using FIXYA!
Apr 28, 2009 | Sony Cyber-shot DSC-H7 Digital Camera
Konica Minolta Zoom 160c won't turn on--lens stuck out and open
There is some kind of grit or something in the lens gearing mechanism, preventing its movement. Take it to a repair facility, or replace it.
Jul 26, 2017 | Konica Minolta Zoom 160C Date 35mm Point...
The camera zoom got jammed
This can be caused by several different situations. Most commonly the camera has experienced some kind of impact which knocks an element out of alignment, preventing the lens from rotating normally. Symptoms of this include: *you may hear no mechanical sound at all when the camera is turned on *you may see visibly mis-aligned components of the lens *you may hear a loud "snap snap" sound as the camera tries to move the lens when the camera is powered on The second most common cause is a particle of sand getting stuck in the focus motor drive gears. This prevents the focus element from moving normally and causes the camera to shut off to prevent damage to the lens assembly. Symptoms of this include: *A loud "buzzing" sound when the camera is turned on, followed by the beeping and shutdown. Finally the third most common cause of this problem is a broken tooth on the zoom motor drive gears. Symptoms of this include: *the sound of the running motor with a regular "click click click" sound for several seconds. This will not be a "snap snap" sound, that is a different problem. *the lens will move in and out easily by hand as if free from any resistance. All of these problems require disassembly to repair. The charge is around $125 at my shop. Broken drive gears are generally This can be caused by several different situations. Most commonly the camera has experienced some kind of impact which knocks an element out of alignment, preventing the lens from rotating normally. Symptoms of this include: *you may hear no mechanical sound at all when the camera is turned on *you may see visibly mis-aligned components of the lens *you may hear a loud "snap snap" sound as the camera tries to move the lens when the camera is powered on The second most common cause is a particle of sand getting stuck in the focus motor drive gears. This prevents the focus element from moving normally and causes the camera to shut off to prevent damage to the lens assembly. Symptoms of this include: *A loud "buzzing" sound when the camera is turned on, followed by the beeping and shutdown. Finally the third most common cause of this problem is a broken tooth on the zoom motor drive gears. Symptoms of this include: *the sound of the running motor with a regular "click click click" sound for several seconds. This will not be a "snap snap" sound, that is a different problem. *the lens will move in and out easily by hand as if free from any resistance. All of these problems require disassembly to repair. The charge is around $125 labor at my shop.
Jun 14, 2007 | Canon PowerShot SD300 / IXUS 40 Digital...
Kodak EasyShare Z710 Digital Camera Logo
339 people viewed this question
Top Kodak Cameras Experts
Jerry Greenberg
Jerry Greenberg
Parshiv Luthra
Marvin
Marvin
Are you a Kodak Camera Expert? Answer questions, earn points and help others
