The machine fills with water (dare not do it again, very full. but does not empty or spin.
Turn the machine off and check under the lid.
the pressure switch hose may have fallen off. its a clear tube that fits onto a nozzle on the underside of a plastic circular unit about 40mm diameter on the left hand side. this should shut the water off when filled to correct level.
to get the water out in any case put the drain hose end lower than the water level into a basin to syphon it out. lifting the hose above water level will stop it till you empty basin.
