Question about HP Officejet 6310 All-In-One InkJet Printer
Insertion of Paper
Where is the best place to insert my scanable document.
  • 916 Answers
Place the document (face down) on the right front corner of
the glass. Make sure the long edge of the document is at
the front of the glass. Close the lid.
Press the Start Copy Color button.
Posted on Jan 30, 2009
Jumping paper in regaster rooler
Open the right side door and check for proper insertion of Paper dust remover beside transfer roller. Not proper inserted Paper dust remover cause paper to jumping register roller.
Oct 22, 2015 | Konica Minolta bizhub 250 All-In-One Laser...
CLX-3185FW I would like to know how to send a fax overseas. Where do I put the paper to be send? Thanks
You are talking about a Samsung all in one printer model CLX3185 and not a PDA right? You can put the document that you want to fax into the automatic feeder on the top of the printer or directly on top of the glass - your choice. If you use the auto feeder on top of the printer, look for a picture of paper near the insertion point that shows you whether the text side goes down or up when you put the paper in. If using the glass on the flat bed, the text goes down.
Once the document is loaded in either place, push the button that says "fax" and enter the number with the Country Code first and then press start. The line you are using to fax should have international calling enabled in order for this to go overseas.
Sep 14, 2011 | RIM Computers & Internet
How do you create animation in word 2007
You normally can't "create" animation in MS Word, however, you INSERT an animated picture file into your document. Here are the steps below to insert an animated clip art image into your document:
  • Place the insertion point in your document where you'd like to have the animated graphic appear.
  • Click on the INSERT Group Tab located at the top of the screen.
  • Choose ClipArt (Note: if you have an animation file present on your computer, then you would select INSERT PICTURE)
  • In the Clip Art Gallery, make sure that in the SEARCH IN: box that you have ALL COLLECTIONS chosen.
  • Then in the RESULTS SHOULD BE: box select only MOVIES.
After you insert the graphic into Word, you may not see the animation until you save it as a Web Page and then Open it in your Internet Browser.
I hope this answered you question. Please do not hesitate to write again for further clarification.
--Sandy
Apr 12, 2011 | Microsoft Office Home and Student 2007...
I keep experiencing paper jam,and some problem about aligning paper
the sensor for the sensing the insertion of paper must not be in proper place and with dust on it. try to clean it and reposition the sensor on it proper place.
Feb 24, 2011 | Lexmark X5470 All-In-One InkJet Printer
I need to cheat my car ignition interlock systems or home system, how might i go about this?
Take an empty toilet paper tube. Wrap it around the mouthpiece tightly. By bending end of insertion. Wrap good tape I.e.. duck tape, packing tape. Around whole tube. Pull tube off and cover insertion end with tape. Cut small **** on tape so you can get an airtight fit on mouthpiece. Fill with 2-3 pieces of good tissue paper. Place on mouthpiece and blow. This has worked for me many times. Won't work if you have a really high b.a.c. though. Let me know
Jul 11, 2010 | 2004 Honda Civic
What is the meaning of insertion point?
Insertion 1Definition: The act of inserting; as, the insertion of scions in stocks; the insertion of words or passages in writings.
Insertion 2Definition: The condition or mode of being inserted or attached; as, the insertion of stamens in a calyx.
Insertion 3Definition: That which is set in or inserted, especially a narrow strip of embroidered lace, muslin, or cambric.
Insertion 4Definition: The point or part by which a muscle or tendon is attached to the part to be moved; in contradistinction to its origin.
insertion 5Definition: the act of putting one thing into another
insertion 6Definition: a message (spoken or written) that is introduced or inserted; "with the help of his friend''s interpolations his story was eventually told"; "with many insertions in the margins"
google_protectAndRun("ads_core.google_render_ad", google_handleError, google_render_ad);
Jun 26, 2010 | Microsoft Office Professional 2007 Full...
Paper tray
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00786157&cc=ca&lc=en&dlc=en&product=1128296
Jun 06, 2008 | HP DeskJet F380 All-In-One Printer
Broken Black Arm on Scanner Attachment (Detects insertion of documents)
Unfortunately, you can't buy the sensor finger by itself. You need the DADF Assy.
Duplex Automatic Document Feeder Assembly
Part Number: 004K07270
Jun 04, 2008 | Xerox WorkCentre C2424DN All-In-One Laser...
Paper will not feed into machine
Most likely the sensor in the insertion area is not recognizing a paper when you try to insert it to be shredded.
Try to clean out the gears, and oil the grinders.
Clean around the insertion area to remove any debris from around the sensor. (Be sure to turn it off/unplug it first!).
If you can remove the shredder head/grinders from the body of the shredder box, turn it upside down and clean it that way as well.
Sometimes the little pieces of paper get clogged up inside the gears.
I got some of the dust spray with the straw...inserted the straw deep into the shredder grinder/gears and sprayed.  I got tons of stuff out.
My motor/grinder worked perfect after I did all this.
Oct 28, 2007 | Royal VF1000MX Shredder
No paper error
There's a little plastice lever type thing that hangs down above where the paper tray is inserted. When the paper tray pops up after being inserted, the paper moves this lever up. This is how the printer knows if there is paper or not. With the tray out, push the little white lever up and see if the "No Paper" message goes away. If it does go away, the lever/sensor is working OK, if not the lever sensor is bad. If that was not the problem, check that the paper tray is popping up after being inserted (look from the back of the device while you insert the tray). If it does not pop up, there is a little white plastic button type thingy on the side of the tray that releases the paper tray to pop up after you insert it into the printer. Make sure that is working correctly. If you flip the pritner upside down, you can see this little white plastic button type thing that should release the paper tray to pop up during the insertion process.
Oct 09, 2007 | Dell 1600n All-In-One Laser Printer
HP Officejet 6310 All-In-One InkJet Printer Logo
18 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
