I have 36-812 Delta RH unisaw with a unifence, and the fence doesn't make a positive connection to the rail. I wanted the adjustment technique via a manual or something.
Richard
Go to Dewaltservicenet.com and in the middle of the page at the bottom type in your model number and on the second page you will get a list of the various models with type numbers you can either download a breakdown or an owmers manual for this tool. This is all I can find.
Prob needs the plastic pads that hold the position when locked. should be readily available at any Biesemeyer outlet as they are replaceable.
..or make your own.
The capacitor is probably failing. Take the motor to an electrical service center (most mid-to-large cities have them ... usually something like "Industrial Electric and Motor Service" ... and ask to have it checked. Caps are cheap!
I would use a straight edge, to see if the blade is parallel to the table. Bring the blade up, put the straightedge on it and measure to one of the dado cuts in the table, front and back should be the same. If not, You can loosen up the mounting bolts underneath and tap the whole thing around to square it up. Hope this helps.
Go on line and download the manual for the fence. You can take it to the hardware store (not Home Depot) and pick up the hardware you need. Everything is listed in the instructions with a nice photo. The bagged sets are available from Beisemeyer but they may cost you more and you will have to wait. I purchased a fence from big box and the set was missing. I called Biesemeyer and they sent one to me for free.
Go online to OWWM.com and download the manual. Don't forget to make a contribution. This will give you the step by step instructions for setting up fence. The jetlock is pretty easy.
Yes you can adjust the angle of the fence. There are two adjusters at the front of the fence where it meets the fence rail. Adjusting these will pivot the fence either slightly left or slightly right.
There is a basc video on youtube my daughter made to show you how to align yourfence to the saw blade.
