Question about Epson Stylus Multifunction Inkjet Printer/ Copier/ Scanner
I can't load the paper into my Epson sx100 - Epson Stylus Multifunction Inkjet Printer/ Copier/ Scanner
  • lauren_1519 Mar 29, 2009
    no matter how many times i put the new batch of paper in it wont recognize it and the error light continues to flash...
    HELP!!
Pinch grey thing where the paper goes with left index finger and thumb. it should then move sideways.
Posted on Jan 30, 2009
  • 35 Answers
Hi, i had this problem to i just solved it.
1. pull the grey leaver to the left by pinching the front peice
2. you then push it over to the left allowing space for the paper
3 load the paper by curving it in to a c shape (just slightly) allowing the paper to be able to be taken in
remember not to: push the paper in the space just hover it over incase in takes in more than one paper.
to ensure it is in make sure the paper is infront of the the black and white peices
Good luck
Posted on Apr 23, 2009
  • 24 Answers
Fiend your solution direct from EPSON. Here is your solution...
http://www.epson.com/printer/prob676ijt65/solution
asd-7
Posted on Sep 03, 2009
    Sergeant:
  • Epson Expert
  • 285 Answers
Put the paper in the top. If it is not grabbing it, try rubbing it with bar soap.
5 Suggested Answers
  • 99 Answers
SOURCE: Inserting A4 paper
You will be having a slider where you place the papers for printing, Use a A4 sheet and adjust that slider.
Regards....!
Posted on Mar 14, 2009
  • 31 Answers
maybe this Site helps.
http://safemanuals.com/user-guide-instructions-owner-manual/EPSON/STYLUS%20SX100-_E
Here you can find many documentations e.g. for your Epson Stylus SX100
Posted on Jun 02, 2009
anusuyaprem
  • 20 Answers
SOURCE: I can't print with my EPSON Stylus SX100!!
To solve the printing problem..
# Hold the cartridge upside down, with the bar-code label facing you and take a damp paper towel.
# Use the towel to wipe the printhead of the cartridge on the bottom (where the ink comes out). Wipe the printhead horizontally in one direction only (left to right).
# Continue doing this until it looks clean.
# Then dab the cartridge on the towel to make sure the ink is flowing.
# Next, look inside the printer and locate the carrier that holds ink cartridges. Caution: Make sure the cartridges are not installed at this point.
1. Look for a shiny piece of metal underneath the contacts at the back of the carrier.
2. Take a damp cotton swab (use water only!) and wipe along the bottom of the shiny metal piece. Note: You may need more than one swab.
# Reinstall the cartridges, making sure you snap them correctly into the printer.
Hope this help. Please Rate My Response! Thanks!
Posted on Aug 19, 2009
  • 1218 Answers
SOURCE: Epson Stylus SX100 General Error
The flashing lights are a "Maintenance request error" or a "Fatal error". Most of the time it is a "Maintenance request error" which means the waste ink pads need to be serviced. You can reset the waste ink counter but the ink pads will need to be serviced at some point. get more information and help from here . Hope this helps you.
Posted on Sep 01, 2010
Epsom sx100 keeps saying cartridges are not compatatble but are using epsom inks
If you have Genuine Epson cartridges and they do not work, call Epson Tech Support. You have to be patient [they're in India] and you may have to ask to speak to someone in the US if you're getting nowhere with TS.
Oct 06, 2012 | Epson 20 Ink For Stylus S20 Sx100 Sx200...
Paper not feeding for epson nx400
Check the following:
  • If paper doesn't feed, remove it from the sheet feeder. Reload it against the right side, behind the tab, then press in the tab on the edge guide and slide it against the paper. Make sure the paper is not above the arrow mark inside the edge guide.
  • If multiple pages feed at once, remove the paper from the sheet feeder, fan the edges to separate the sheets, then reload it.
  • If the paper doesn't eject fully, you may have set the wrong paper size. Press the c:\users\home\appdata\local\temp\msohtmlclip1\01\clip_image001.gif Stop button, then open the scanner and remove the paper. Select the correct paper size when you reprint.
  • If it's wrinkled when it ejects, the paper may be damp or too thin. Load new paper.
  • Make sure you use new, smooth, high-quality paper, that is not curled, creased, old, or too thin. Make sure to load it printable side up.
  • Do not load paper with holes punched in it for insertion in a binder.
  • Make sure you load only up to the recommended number of sheets. If you're printing on both sides of the paper, try loading fewer sheets.
Paper type
Load up to
this many sheets
Plain paper
Approximately 120
Epson Bright White Paper
Epson Presentation Paper Matte
80
Epson Photo Paper Glossy
Epson Premium Photo Paper Glossy
Epson Ultra Premium Photo Paper Glossy
Epson Premium Photo Paper Semi-gloss
20
Epson Premium Presentation Paper Matte
Epson Premium Presentation Paper Matte Double-Sided
Epson Photo Quality Self-Adhesive Sheets
Epson Iron-On Cool Peel Transfer Paper
If the paper jams, do the following:
1. Gently pull any jammed paper out from the output tray or sheet feeder.
2. To eject the jammed paper, try turning the Epson Stylus NX400 off and then back on.
If that doesn't work and paper is stuck inside, turn off the Epson Stylus NX400. Open the scanner, remove the jammed paper and torn pieces, close the scanner, and turn the Epson Stylus NX400 back on.
Aug 17, 2012 | Epson Stylus NX400 InkJet Printer
I am looking for epson stylus sx100 printer software for free download
You can download the installation driver and software for Epson Stylus SX100 from manufacturer's support website by clicking this link
On the page which opens, select the operating system of your computer (Windows Xp/ Vista..) from the drop-down menu. Then download the required drivers and software.
The list of available drivers will load only after selecting the operating system of the computer.
Hope this solves your problem. Thanks for using FixYa.
Sep 19, 2010 | Epson Stylus Multifunction Inkjet Printer/...
Aug 19, 2009 | Epson Stylus Multifunction Inkjet Printer/...
Inserting A4 paper
Jun 02, 2009 | Epson Stylus CX6400 All-In-One InkJet...
Inserting A4 paper
Regards....!
Mar 14, 2009 | Office Equipment & Supplies
How to scan with the SX100
its easy.
When you have the paper loaded all u have to do is press the button that says "**** my balls".
You will find it below the power button.
Good Luck!
Nov 30, 2008 | Epson Stylus Multifunction Inkjet Printer/...
Epson Stylus Multifunction Inkjet Printer/ Copier/ Scanner Logo
486 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
