Question about Sony DSC-T7 Digital Camera
DSC-T7 Locked up "USB Mode Normal" Second user with exact same problem!
I have the same problem exactly as posted (included below)by jogairan on 5 March 2007. I was just double checking if anyone has a possible solution, since this problem is not unique and maybe someone has found a workaround. Thanks in advance, Kapinossa Hello, I hope someone here can help me. I am going crazy!! My DSC-T7 was working find and all of a sundden in the middle of taking a bunch of pictures it started to go back and forth between the normal picture taking screen and "USB Mode Normal" screen. I tried to turn it off and on a bunch of times and it is now worse! at the moment: when I turn it on, it showes the battery power on the left top corner, mid top it will say "USB Mode Normal" under that there are four white dots and at the bottom it says: "Switch on MENU". If I press the menu botton, everything stays the same except the lower left corner, inside a yello box will say: "USB Connect". pressing menue will toggle between these two screens. non of the other bottons do anything. I took the mem stick out and turned it on still the same. I took the battery out and put it back in with the same results. has anyone run into this? can anyone help? Please and thank you.
  • 4 more comments
  • brawn Nov 11, 2007
    YES I DO HAVE THE SAME PROBLEM. There is no reset button under battery.No buttons do anything All I can do is turn it on and off.Can anyone help me. Jim
  • Anonymous Feb 20, 2008
    Hi, exact same thing here, it's suddenly randomly stuck on usb mode... please help us! There is no reset button anywhere on this camera, i tried to push the menu button for 20 seconds but nothing happens. Any other tip?
  • darkglobe Mar 17, 2008
    have the same problem on DSC-T33,  it does have a reset button and the camera resets when pressed, but it doesnt help.
  • Robo1959 May 19, 2008
    Same problem for me stuck in USB mode and no reset button.
  • reidengw Jun 19, 2008
    Same locked up problem
  • michelbar Apr 13, 2009
    Same.
    Today I will go to the sony service to what can they do....
    Michel
I went to the technicall service.They fix it. They told me i had water inside (humidity) they have clean the chips, formated again (they said)
90 minutes of hand work= 72 euros.
You may try to open it and with a hair dryer?¿?¿?¿
Now is working properly, but I have 70 euros lessin my pocket..
Good luck
Posted on Apr 15, 2009
  • Anonymous Oct 08, 2013
    Thanks. That's not impossible on my end. It could be moisture. I will see if the battery reset method below works first, then I will try drying methods.
I you remove the battery and press the power button for 30seconds, after wait 30minutes and reinsert the battery again in the video position you will get access to the camera for a minutes, you have to go to the menu and reinicialice the camera. If this don´t work you have to go to the technical service. There is no hard reset button or firmware upgrade to solve the problem by yourself. (this is what the online technical support has told me)
Posted on Aug 02, 2009
    Giviing it a try. If anyone knows of a better method by now...it's 2013. please let me know.
  • 883 Answers
Can you find a reset switch? look for a tiny access hole to insert a pin...possibly under battery.
Posted on Jul 29, 2007
    Nope
SOURCE:
Need users guide /troubleshooting for DSC-T7
http://www.google.ca/url?sa=t&source=web&cd=1&sqi=2&ved=0CBcQFjAA&url=http%3A%2F%2Fdownloads.fotosource.com%2Fpublic%2Fcamera_manuals%2FSony%2FDigitalCameras%2FCyberShotDSC-T7.pdf&rct=j&q=DSC-T7%20manual&ei=ODtITo-SIMjkiAK16rzRAQ&usg=AFQjCNFifnLMdTE5Gmc30DSupAEdG6wgyg&cad=rja
Just copy the above link into your browser (Internet Explorer or Firefox).
Hit enter, then a download window should appear. accept the download.. it is a PDF of the DSC17
guide /troubleshooting manual.
Aug 14, 2011 | Cameras
My presario F700 was locked with a code and cant be remembered. i need assistance please
The instructiond were clearly givn in this link with images :
http://www.vistax64.com/tutorials/130095-user-profile-service-failed-logon-user-profile-cannot-loaded.html
STEP ONE:
Logon to the Computer
NOTE : Go down the list here until you find a option that will work for you.
1. Logon to another Administrator account.
NOTE: If you do not have another Administrator account, then proceed to step 2.
A) Go to OPTION ONE or OPTION TWO.
2. Boot into Safe Mode.
NOTE: You may not need to enable the built-in Administrator account. If this was the only normal administrator account you had, then Safe Mode should automatically boot into the built-in Administrator account. See: How to Start Vista in Safe Mode
A) If Safe Mode did not boot into the built-in Administrator account, then enable the Built-in Administrator account. If it did , then go to step 2C.
NOTE: See: How to Enable or Disable the Real Built-in Administrator Account in Vista
B) Logoff of Safe Mode, and then logon to the built-in Administrator account to logon with it in Safe Mode.
C) Go to OPTION ONE or OPTION TWO.
OPTION ONE:
Fix the User Account Profile
1. Open the Start menu.
2. In the white line (Start Search) area, type regedit and press Enter.
3. If prompted, either click on Continue or enter the password for the Administrator account.
4. In regedit, go to: (See screenshot below step 5)
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\ProfileList
5. In the left pane, look for the S-1-5..... folder (SID key) with the long number that has .bak at the end of the numbers.
(See screenshots below steps 6A and 7B)
NOTE:
A) In the right pane, look at the ProfileImagePath to verify that this is the user account profile that has the error.
B) You may have another S-1-5..... folder (SID key) above it with the exact same number without the .bak at the end of it.
6. For Two S-1-5..... folders (SID key) with the same Number -
NOTE: This is if you have two S-1-5..... folders (SID key) with the exact same numbers, but the second (below) one has the .bak at the end of the numbers.
A) In the left pane, right click on the first (top) S-1-5..... folder (SID key) that does not have .bak at the end of the numbers and click Rename. (See screenshot below)
B) Add .bk to the end of the numbers. (See screenshot below)
C) In the left pane, right click on the second S-1-5..... folder (SID key) with .bak at the end of the numbers and click Rename. (See screenshot above)
D) Remove only .bak from the end of the numbers and press Enter. (See screenshot below)
E) Now go back and Rename the first one with .bk to .bak now at the end of the numbers and press Enter.
F) Go to step 8.
7. For Only One S-1-5..... Folder (SID key) with .bak -
NOTE: This is if you only have one S-1-5..... folder (SID key) for your user account with .bak at the end of the numbers.
A) In the left pane, right click on the S-1-5..... folder (SID key) with .bak at the end of the numbers and click Rename. (See screenshot below)
B) Remove only .bak at the end of the numbers and press Enter. (See screenshot below and below step 10)
8. In the right pane of the one without .bak now, right click on RefCount and click Modify. (See screenshot below step 10)
NOTE: If you do not have RefCount, then right click on a empty space in the right pane and click New and DWORD (32 bit) Value, then type RefCount and press Enter.
A) Type 0 (number) and click OK. (See screenshot below)
9. In the right pane of the one without .bak now, right click on State and click Modify. (See screenshot below step 10)
10. The registry will now look like this for the one without .bak now. (See screenshot below)
11. Close regedit.
12. Restart the computer.
13. See if you can logon now.
OPTION TWO:
Delete the User Account Profle
NOTE You can do this option if you do not care about losing the user account and the contents in the user folders.
1. Delete the User account profile that this error is for.
NOTE: See: How to Delete a User Account in Vista
2. Open the Start menu.
3. In the white line (Start Search) area, type regedit and press Enter.
4. If prompted, click on Continue.
5. In regedit, go to: (See screenshot below step 7)
6. In the left pane, click on one of the S-1-5..... folders (SID key) with the long number in it.
NOTE: It may have .bak at the end of it.
A) In the right pane, look at the ProfileImagePath to see if this is the same user account that you deleted in step 1 above.
B) Repeat step 6 until you find the one that you deleted in step 1 above.
NOTE: If the user account is not here, then it has already been removed when deleted in step 1. Go to step 9.
7. To Backup the Registry SID Key -
WARNING: You should backup this SID key to be safe in case you delete the wrong one in step 8 below.
A) Right click on the SID key, and click Export.
B) Type in a name and save the REG file to a safe location.
NOTE: This is your backup. To Restore the Backup, right click on the REG backup file and click Merge.
C) Continue on to step 8.
8. To Delete the Registry SID Key -
A) Right click on the SID key, and click Delete. (See screenshot above)
B) Click Yes to confirm deletion. (See screenshot below)
9. Close regedit.
10. Now, just create a new normal Administrator account.
NOTE: See: How to Create a New User Account in Vista
11. Restart the computer, and logon to your new account.
Good Luck.
Dec 08, 2010 | Computers & Internet
I have a Sony Cyber-shot DSC-T7 Digital Camera how can I reset it
To reset camera follow below procedure:
Press MENU, select SETUP, select SETUP1 and select INITIALIZE and press OK to reset DSC-T7 camera.
Hope this info will help you.
Thanks.
May 22, 2010 | Sony DSC-T7 Digital Camera
Problem .
If you open the part that gives you access to the battery and the memory stick you'll see a small button that says 'reset'. I'm actually not sure what it resets, but you could give that a try.
Jun 27, 2007 | Sony Cyber-Shot DSC-P100 Digital Camera
Sony Cyber-shot DSC-W50 Record Mode
I had the same problem and you go to menu then REC mode and make sure it is on normal, mine was on multi burst and thats why it was recording on every setting. Hope this helps :)
Apr 29, 2007 | Sony Cyber-shot DSC-W50 Digital Camera
I am a user with the exact same problem as you desribed for my DSC-T7. My problem started when I splashed two drops of water need the battery door and then the camera would not power up. I removed battery and card for a day and camera worked fine for another day. The following day, I left my camera in my sun visor of my car for the day (>90 deg F outside) which I forgot that I put it there. The next day my camera did power up in the locked mode exactly as yours. I do not know if it was the water drops or the heat but it is doing exactly as you desribe. However, here is something that I have discovered while trying to get the camera to work: 1. I plugged the adapter into the side of the camera since I am concerned that the USB port is the issue. 2. I plugged the USB cable into my portable printer and powerer the printer up and then turned on the camera in all three modes to see if anything changed and it did not. 3. I have found if you turn off the printer with the USB cable still in the printer and the adapter, the camera then enters a mode that shows thw word "ACCESS" and then the camera works perfectly. All modes of the camera work fine. But as soon as you power up the printer or remove any of the cables or remove the adapter the camera reenters the locked mode. This is not a solution but an indicator that the USB port is possibly causing the problem but not sure why the printer being off causes the camera to work fine. In addition, have all of the cables hooked up and to the printer does not allow the camera to be used with any mobility but wanted to let you know what I have discovered and hopefully maybe this may lead to a potential solution. Steve
Mar 05, 2007 | Sony DSC-T7 Digital Camera
What are the system requirements of the DiMAGE 5?
System RequirementsIBM PC/AT compatible computer with preinstalled Windows Me, Windows 2000, Windows 98*, or Windows 98 Second Edition* and with a built-in USB port as a standard interface.Power Mac G4 (includes dual processor G4 and G4 Cube) series, G3 (Blue and White) series, iMac series, iBook, or PowerBook G3 with preinstalled Mac OS 8.6** – 9.1 and with a built-in USB port as a standard interface. • Problems may be encountered depending on what other USB devices are being used in parallel with this product. • Only a built-in USB port is supported. Problems may be encountered when the camera is connected to a USB hub. • Normal operation may not be possible even when all the system requirements are met. * Users of the Windows 98 and Windows 98 Second Edition must install dedicated driver software included in the DiMAGE 5 and DiMAGE 5 package. ** Users of the Mac OS 8.6 must download free dedicated driver software from the Apple Computer web site and install it.System requirements are based on the latest information available at the time of printing and are subject to change without notice.
Sep 15, 2005 | Konica Minolta DiMAGE 5 Digital Camera
DSC-T7 Magnify Mode
Hello, Don't mix magnifier mode and expanded focus mode. Magnifier mode is simply a short AF range operating mode, like a kinda super-macro. Whether you selected mag/macro/normal, the camera operates always same except that the focussing range limits are changed accordingly by the S/W. The lens itself is capable of focussing from 1cm to infinity anyway. Expanded focus is used on some still and video cameras to assit manual focus because the LCD's resolution is lower than the CCD's. It can be seen as a workaround for the lack of optical reflex viewfinder (Sony cams ar not dSLRs, including HDR-FX1!). So the center area of the pic is "digitally zoomed" to make sure you can adjust a sharp focus of the point of interest in your frame. However it has nothing to do with macro shooting, and works at any distance within the lenses focussing range. Hope having helped
Sep 12, 2005 | Sony DSC-T7 Digital Camera
Sony DSC-T7 Digital Camera Logo
232 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
 Russ Hill
Russ Hill
Are you a Sony Camera Expert? Answer questions, earn points and help others
