Question about Intertherm P3RA-048K Air Conditioner
Intertherm furnance chimmly icing up
The top of the stack is putting out mosture fhat runs down the outside of the stack ,that causes a huge ice build up on stack and roof this is a 1995 mobile home with a shingled roof it belongs to a elderdy lady who keeps her inside temp at 80 degrees she is very cercerned about this problem , She lives in Milan Illonios.
    Problem Solver:
  • 6 Answers
It sounds like there is a restriction on top of you're flue pipe top, not allowing the air to escape in a normal way, ike bird nest, leaves or the position down on the pipe.
Posted on Feb 16, 2009
Heat pump problems
Some heat pumps have high and low pressure swiches installed to keep compressor from running when unsafe conditions occur that can damage the compressor. If the outside fan is not turing on, the unit is cycling on high pressure, if you see ice forming on the big refrigerant line coming from the air handler, then the compressor is shutting down on low pressure. Low pressure can be cause by lack of air flow through air handler or from a low refrigerant charge.
Feb 13, 2014 | Intertherm Heating & Cooling
Whirlpool 2211590 Ice Auger Conquest 2-door side-by-side Part #: 2211590 ice cannot come out through the dispenser & will not crush ice....freezer still makes the ice....motor runs slowly &...
If the ice will not go down the delivery outlet. the the augar will have to work harder than .normal .. try drying the out the delivery area // then use a food grade silcone and spray this . this may correct problem .. . also ck the seal on the door if bad it will let mosture in and cause poor delivery .. hope this helps mm. feed back pls ..
Jul 10, 2011 | Whirlpool 25.6 cu. ft. Side-by-Side...
My Electolux freezer freezes things at the top but not lower down, why? Also the top has a huge and rapid build up of ice crystals.
Sounds like you have lost some of the refrigerant charge. when this happens the cooling coils only freeze partway and the unit runs most of the time due to lost capacity.
Jun 22, 2011 | Electrolux Freezers
Outside unit iced up how do de-ice
As with the simplest way to thaw ice is with heat.
If you are running this unit in cooling and have ice outside, then you most likely have a freeze up inside as well. If this is a heat pump unit, then frost is normal during operation, however, ice build-up is an indication of a problem.
There are 2 effective ways to remove the ice build-up. The first is the simplest. Get your water hose and hose it down. Be sure to turn off the breakers to the unit and avoid spraying the electrical compartment. If you have the ability to hook the hose into a hot water line, then this process with be extremely fast. Let the unit sit for about 20 minutes to dry out and turn it back on.
The second can be a little more complicated if your not tech savoy. You can turn the system on in the cooling mode. This will make the outdoor coil the condenser section. Then, either block the airflow through the coils with an object, put an object over the fan to increase pressure, or if you can, disconnect the fan so it does not run. This method is essentially the same as a defrost cycle.
As with any failure, you can fix the problem at hand, but it will return. After you get past this, your real challenge will be determining what caused the freeze-up.
If you were running your system in cooling already, then you will need to ensure the system has de-iced on the inside as well.
Jan 12, 2010 | Heating & Cooling
Ice builds up inside packages in freezer.
This is the moisture coming out of the food. It is what causes freezer burn.
The problem is made worse in frost free models by the defrost cylce. Best way to slow it down is to use vacuum bags or freezer bags. Also above 0 F food deterioates faster and below it gets freezer burn and the moisture problem faster.
Mar 22, 2009 | Frigidaire 9 cu. ft. / 255 liter Chest...
Ice build up out side hitting fan
pop out drain plug heat up pan with heat gun to melt ice
Nov 24, 2008 | GE Zoneline AZ38H12DAD Split System Air...
Amana refrigerator top freezer going out; water under crispers
you are right about the cause of water in the fridge - blockage in the drain. i'v never met this caused by ice but it is possible.
with the freezer, the cause of the fault is the fan not working - probably jammed with ice. take back panel off inside freezer and check for ice build up. if loads of ice thgen defrost system has failed. you can do a temporary repair by melting the ice off with a hairdryer
Sep 24, 2008 | Refrigerators
Ice maker dispenser and frost
outside moister cause making frost, probably you can not do it youself,if you know , do it.
Jun 17, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Intertherm P3RA-048K Air Conditioner Logo
78 people viewed this question
Top Intertherm Heating & Cooling Experts
Dennis Boxerman
Dan Webster
Dan Webster
Bill Long
Are you an Intertherm Heating and Cooling Expert? Answer questions, earn points and help others
