Question about LG VX4400
LG VX4400 Can't get the ringer to turn on.
I have pushed the keys on the side and still will only vibrate. Wondering if there is a setting on main menu to turn it on yet.
  • pjb717 Feb 13, 2009
    Same problem....the phone is stuck on "Silence All" and nothing gets it changed. It won't vibrate or anything. I've tried everything.
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 66 Answers
HI Just try these steps it should be ok
1 . P ress Soft Key 1 Menu.
2 . P ress key 8, key 1,key 1.
3 . Select Caller ID key 1, No Caller ID key 2 ,orRestrict key 3.
4 . To select a ringtone , press Soft Key 2 select Downloaded or Default.
5. Choose a tone if you have more than one. Then press Soft Key 2, select Downloaded and press ok button .
6 . Press up/down arrow key until find the sound
7 . Then press ok to save the sound.
Posted on Feb 11, 2009
My phone will not vibrate at all anymore
Hi
Make sure your ringer is not in vibrate mode. Try These this thing first
Press Menu > Settings/Tools > Settings > Sounds > Ringer Type > Voice Calls.
Select Caller IDor No Caller ID. (A list of ring type categories will be displayed.)
Select a category, and then use your navigation key to scroll through the available ringers. A sample ringer will sound as you highlight each option.
Press OK to assign a ringer. Make sure your speaker works. Turn On your speaker phone while talking to someone and see whether you can hear or not. Make sure the increase the volume using keys on side of your phone.
If none of these works the ******** motor needs to be cheked for loose connections inside the phone.
Thanks for using Fixya
Mar 24, 2011 | LG Ally Cell Phone
Phone will only vibrate and not ring
a. Make sure your ringer is not in vibrate mode.
1. Press Menu > Settings/Tools > Settings > Sounds > Ringer Type > Voice Calls. 2. Select Caller IDor No Caller ID. (A list of ring type categories will be displayed.) 3. Select a category, and then use your navigation key to scroll through the available ringers. A sample ringer will sound as you highlight each option. 4. Press OK to assign a ringer.
b. Make sure your speaker works. Turn On your speaker phone while talking to someone and see whether you can hear or not.
c.Make sure the increase the volume using keys on side of your phone.
Mar 14, 2011 | LG RUMOR Cellular Phone
I own LG VX8360 and can't figure out hoe to turn ringer on. Can you help me?
To restore the ringer it will depend on what mode your phone is in:
Vibrate Mode:
Sets the phone to vibrate instead of ring.
To set Vibrate Mode, with the flip open, press and hold the # key .
To return to Normal Mode, press and hold the # key again.
Sounds Off Mode:
Quickly deactivate your phone's sounds when you're in a place where phone sounds would be disruptive.
From standby mode with the flip open, press and hold the lower side volume key for 3 seconds. To return
to normal sounds mode, press and hold the upper side key.
Airplane Mode:
Turning on Airplane Mode will disable all wireless communications.
1) With the flip open, press the Menu key.
2) Use the Directional Key (top center of phone) to scroll to 'Settings and Tools'.
3) Press the 6 key for Phone Settings.
4) Press the 1 key for Airplane Mode.
5) Use the Directional Key to highlight a setting, then press OK.
On/Off
Mar 30, 2010 | LG VX8360 Cell Phone
My LG VX-8700 does not vibrate. Ring works, but vibrate mode is the same as silent mode. Can this be fixed?
Yes,
What happened is you probably set it on silent and from the soft keys, you increased the ringer volume. What you want to do is go to main menu => settings => profiles, and from there make sure your ringing volume is set on lowest possible.
Oct 28, 2009 | LG VX-8700 Cellular Phone
How do I turn on the "vibrate" function for text messages?
Hmm try this;
Go to Settings>Sound>Vibrate Type and set one to texting.
OR
Go to sounds > volume > messages > text message > and click on use ringer volume and click the button on the left side of the phone and change it to vibrate.
Hope this helps and if so, Kindly Do Rate!
Regards.
Jul 18, 2009 | LG Lotus Cell Phone
Need to set razr phone to mute. How??
On the side you have a up and down keys open the phone, and keep pushing the down key on the side of the phone. this is where you adjust the ringer but alos puts it in vibrate, or silent mode
Jan 26, 2009 | Verizon Communications Motorola MOTORAZR2...
Txt help
You can not turn that off as that is their signature they have put on their text messages, unless you are chris and then you can go to settings and take the custom signature for your texts off. You can place your phone on silent by tapping the down arrow key on the left side of the phone above the camera shortcut key (as you are looking at the main screen). As soon as you start pushing the down arrow you will see the volume control and turn the ringer completely off. If you note the vibrate checkbox marked, you can push the little button above the speakerphone button to uncheck the box, or recheck it to have vibrate on. Let me know if that is enough information for you!
Jan 13, 2009 | LG RUMOR Cellular Phone
Ring vs vibrate
This phone allows you to independently set ring and vibrate modes. When you access "Call Vibrate" to set the mode, also visit the "Call Ringtone" menu to turn off the ringer.
You may want to leave the vibrate mode OFF and your ring tone ON and use the quick keys to switch between ring and vibrate. Two ways to do this, push and hold the # key to switch between normal mode (the settings you chose in "Call Ringtone" and "Call Vibrate") or use the side volume button to access the "Master Volume" and select "All Off", "Vibrate" or a ring tone volume.
If this helps you, please leave me a good rating.
Aug 17, 2008 | Samsung SCH-u340 Cellular Phone
Manner mode
the microphone button works with the phone closed.
with the phone open, press and hold the * key (about 2 seconds)
it will cycle from manner mode to silent mode to normal mode
Dec 12, 2007 | LG VX4400
LG VX4400 Logo
185 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Raphael Josiah
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
