Question about Sony ICF-2010 AM/FM/SW Radio
Sony ICF 2010 Shortwave scan does not scan, it beeps.
My Sony ICF 2010 shortwave radio scan does not scan,
it make a beeping noise until i cancel the scan attempt,
Please advise,
Thank You.
  • 1 more comment
  • chanel500 Jan 30, 2009
    Its around 10 years old,
    Has new AA batteries.
    Thanks for your reply.
  • Shahid Electronics
    Shahid Electronics May 11, 2010
    It is 1985 model and radio needs replacement of all capacitors.
    Local repair shop can fix it.
    How old is this radio?
  • 494 Answers
It will not scan blank memories and it will not scan on search function till you specify a frequency range.
Rod
Posted on Feb 09, 2010
Sony icf sw7600gr won't power up on battery power and showing exhausted battery symbol,only on ac adapter will work
check the connection inside the radio, switch of AC-DC connector maybe loose contact.( leak diode more probability replace it)
Nov 09, 2015 | Sony ICF-SW7600 AM/FM/SW Radio
How do I set the. Time
With the radio off, press and hold the ENTER (time set) Key DOWN. On the right side, there are 4 buttons with arrows on them. The inside ones set the timezone that you are in, the outside two will set the time. I just checked this on my ICF-SW100 and it works for me.
Mar 04, 2015 | Sony Icf-sw100 World Shortwave Receiver...
Sony radio manuals
You may download from Sony web
Apr 05, 2014 | Sony Shortwave Radio Icf-6700w
Hi,Ive been trying to set my icf-cd2000 clock radio,I downloaded info,It is so small I cant read it.(ive tried to make it larger on photo copier) but it only blurs ,can I buy a manual please,Or do you have...
Setting the Local Time
  1. Press WORLD/LOCAL to display "LOCAL".
  2. Hold downl CLOCK until you hear a beep.
  3. Press TUNE/SCAN TIME SET + or - to set the hour.
  4. Press CLOCK to enter the hour.
  5. Press TUNE/SCAN TIME SET + or - to set the minute, and then press CLOCK. Two beeps sound to confirm the setting.
Setting the WORLD Time
  1. Press WORLD/LOCAL to display "WORLD".
  3. Press TUNE/SCAN TIME SET + or - to set the desired hour and press CLOCK. Two beeps sound to confirm the setting.
If you need any more help, feel free to ask.
Mar 08, 2011 | Sony ICF-CD2000 Clock Radio
My SonyICF-2010 works just fine when using the power adapter. However when I use battery power nothing happens. Please help. I love my old shortwave radio. Thanks.
This problem can be caused by a loose external power connector. This will require disassembly of the case and some soldering. it is possible that the battery terminals are corroded if any batteries have leaked.
Apr 12, 2010 | Sony ICF-2010 AM/FM/SW Radio
No am on am band
Usually the "front end" of the radio has a bad FET transistor. This is caused by a static zap at the antenna. Early models suffered from this and the cure is to replace the FET and add protection diodes. If you need help with this email me at.... poikaa@yahoo.com
Rod
Nov 08, 2009 | Sony ICF-2010 AM/FM/SW Radio
Sony ICF2010 Scan does not work.
The SONY does not scan non programmed memory channels, you must have some programmed in.
Jan 30, 2009 | Sony ICF-2010 AM/FM/SW Radio
Shortwave programmes
Before you call a doctor or an exorcist, verify that you're using your shortwave receiver under normal condition. There are several factors which affects reception of whortwave programs and signals.
1. Check for the time and frequencies. Depending on your country and location, all Shortwave time zones are based on World Time in UTC or GMT ("Universal Time Coordinates" or Greenwich Mean Time") In my country (Philippines, Asia) for example, we are 8 hours advanced from World Time. You can check your time zones and regions using a world map.
2. Check for propagation and band conditions/ openings. During daytime higher frequencies such as 9 -21 Mhz are active, while nightime frequencies are the lower bands such as 3 - 9 Mhz. Daytime and nigthime divider frequency is about 10 Mhz, that means you might receive signals under most conditions during daytime and night time. Check some technical books on amateur radio operations or magazines for radio reception. It might be worthwile to study books or materials on receiving international broadcasts stations before you can receive good or adequate shortwave signals. This might become your hobby too, "DXing" or receiving distant stations from across the world. Try it, but it might be an addicting hobby once you're drawn to it!
3. Check if any shortwave station broadcast in any specific time of day at any frequency. Shortwave broadcasts are scheduled based on band openings mentioned above. If for example I'm a Shortwave broadcaster from Asia, and would like to broadcast my signal through the Americas, I would use band openings with respect with time zones. If it is night time in the Philippines, and daytime in the Canada, I would use the higher frequencies to propagate my signal. So I would specify the time for example "8:00 pm Philippine local time, 12 hours UTC, and 7 am in Canada"--- Asia: 8 hours advanced to UTC, Canada--- 5 hours behind to UTC). So shortwave broadcast schedules varies. Broadcast schedules are available on the net, just search for the Shortwave station you want to hear such as Radio, Japan, Radio Australia, BBC, DW (Deutche Welle) Radio in Germany, China Radio International... There's too many shortwave stations waiting to be discovered out there! Check some books and magazines too such as Popular Communications, Monitoring Times, Passport to World Band Radios, World Radio and TV Handbook, etc. You may want to check if any station would be broadcasting in your dialects as most of these mainstream and regular broadcasters are multilingual.
2. Check your location. If you are using your radio indoors, shortwave signals might not entering your homes or offices due concrete walls and metal railings or fence. There are many factors which blocks radio waves especially in the HF or lowetr bands. Try receiving AM (Mediumwave) first. If it cannot receive any AM station, then you would not receive any Shortwave signal at all, even if you extend fully the telescopic whip. If you cannot receive AM or Shortwave signal indoors, try using your receiver outdoors.
2. Check for local interference. Your receiver might be receiving interference from noise generating gadgets such as PC monitors, TV sets, faulty wall adapters or switching power supplies, motor operated appliances such as washing machines or vacuum cleaners, flourescent lamps, etc. Try turning off or unplugging each of these mentioned gadgets to see if they are the cause. Faulty house wiring or powerline noise might also cause some interference noise which could drown shortwave signals, verify this with your local electrical technicians.
3. Check your radio's settings. Depending on the radio that you use, there might be settings such as attenuator or RF gain, be sure that attenuator are set to zero or turned to off, and RF gain to high. Attenuator must be turned to minimum or OFF position, unless you are receiving too much signas from nearby radio stations. Setting attenuator to mid or high position will attenuate most weak signal, and only those strong local stations will pass through. Setting too much attenuation will prevent you from receiving any station at all. Same with RF Gain, always set it to highest gain setting unless you are receiving too much signals which might overloads your shortwave radio.
4. If these troubleshooting efforts above doesn't works and you still cannot receive any station, then your radio's front end parts might had burn out due to signal overloads. Burn parts might include one or several transistors or diodes. Let your local service technicians check your radio and solve the problem for you. If your radio is still under warranty, send it back to the store or dealer, and let a qualified technician do the repair.
MANNY DE GUZMAN JR.
SoundMagik Home Studio
Site Creator, Teen Models 2007
Visit my website at http://mannydeguzmanartist.wetpaint.com/
My YouTube Channel, http://www.youtube.com/user/mannydeguzmanjartist
My imeem social media channel, http://mannydeguzmanartist.imeem.com/
My Talents and Modeling site at http://teenmodels2007.wetpaint.com/
I've also signed up an account at Total Popstar, uploading some promotional videos. You can watch and rate my videos (you can find my videos on the right side of the screen), just click the link here: http://www.totalpopstar.com/?profile/index/&1740
Thank you very much. I hope I'll really be of help here at FIXYA.COM!!!
Jan 26, 2008 | Sony ICF-SW30 Radio
Sony ICF-2010 AM/FM/SW Radio Logo
364 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
