Question about Canon ZR100 Mini DV Digital Camcorder
Camera went swiming in salt water, But I need the tape!
Hi Folks My ZR100 went for a swim in salt water. I'm sure it's a paper weight, well almost, but may try to send it in for an estimate. The Problem is the tape is stuck inside the camera and I need the tape. How do I remove the tape without power? I need more detail then turning the motor. How do I get to the motor that releases the tape? Are there schematics online for this camera? Thanks m
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 133 Answers
1-800-ok-canon is the number unfortunatley there isnt a mauual way to open it without breaking something, in any manual posted. Best advice is to call and ask plus you can get a quote for repairs while your on...Sorry
Posted on Jul 29, 2007
SOURCE:
Is a saltwater swimming pool bad for you?
only if you live in it full time without showering in fresh water after .then you will get crusty.
Feb 13, 2016 | CircuPool Salt Water Pool System
Hi, last month we bought an intex round pool (18' x 54") with sand pump and salt sanitizer. Within the last 2 days the water started turning green. It turns out my husband accidently set the pump...
You don't want to swim in water that has algae... 1st ...Make sure you have the correct amount of salt. See you manual for amount needed. Must set you pump timer first and sync your chlorinator between that time, if pump turns off before chlorinator cycle ends, you will get an "Low flow" alarm. Set you pump timer to run 12 hours and the chlorinator for 10 to 11 of those hours and should see results within 3 days or so. After that, If you live in an area that is hot, 10 hours pump and 8 to 9 chlorinator... Hope this helps...
Jul 13, 2011 | Intex Automatic Salt Water System for ...
No image on TV or in viewfinder when I playback the tape in 4yr old Canon ZR100 video camera
This is usually caused by an oxidized or defective Audio/Video drum. Try running a cleaning tape through the camera. If this does not solve the problem the camera will need to be repaired qualified service technician.
Aug 11, 2010 | Canon ZR100 Mini DV Digital Camcorder
Canon zr100 died: no power
If you have had the camera for a long time, it may have simply died. This may not help, but you could leave the camera on untill the battery loses all power, then try to turn it back on, and see if it works.
Feb 09, 2008 | Canon ZR100 Mini DV Digital Camcorder
USB Port
To transfer video to your computer from the ZR100, you will need to connect the camera to the computer via the firewire interface. The ZR100 does not have a USB interface.
Jan 19, 2008 | Canon ZR100 Mini DV Digital Camcorder
NOT TAKING TAPE
I have one doing the same thing. I called Cannon and the told me I would have to send it in for service. Now after reading that about 10 other folks having the same issue, I think Cannon has some issue with the ZR100. Of course mine is out of warranty. Everyone should call Cannon and complain.
Apr 09, 2007 | Canon ZR100 Mini DV Digital Camcorder
Camcorder keeps spitting the tape out when I put one in
Mar 01, 2007 | Canon ZR100 Mini DV Digital Camcorder
Dropped camera in pool
Open camera and place in a bag of rice for a couple of days to absorb moisture.It's worked before on cell phones.
Jun 30, 2006 | Canon PowerShot A70 Digital Camera
Canon ZR100 Mini DV Digital Camcorder Logo
131 people viewed this question
Top Canon Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Marvin
Marvin
Steve Mason
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
