SOURCE: Panasonic DVD-RV32 DVD Player
Awwwww The old HO7 code!! This code means that the spindle motor did not come up to speed and the only way to fix it is to first find out if its the driver servo circuit thats bad or the spindle motor itself is defective. If you know how to trouble shoot a motor speed control servo sure you can fix it, But theres no easy wand waving fix for this unit. Sorry. If its an older unit you want to consider buying a new one as it may not pay to estimate the unit and have it fixed . The balls in your court now my friend. Good Luck
SOURCE: ON A DVD-CV37 PANASONIC DVD/CD PLAYER KEEPS GIVING
This normally means the spindle motor is faulty.
SOURCE: does not play DVD and displays HO7. We have tried
This normally means the spindle motor is faulty,there is a little coupler and this splits,this will cause the machine not to load.
Testimonial: "Thank you for your help. Does that meen that the DVD player can not be repaired by me?"
SOURCE: HO7 displayed on machine and won't play dvd
email me your email address and i will show pic's how to my email address is [email protected] plzzz email me i will help but for now i will help step for step.
1)open your driver and pull out the plug.
2)nou the driver is open pull of the cover infront of the dvd player.
3)nou screw open your dvd player and take of the cover.
4)screw of the driver take it out.
5)nou clip of the lazzer and take it out gently.
The top resen of the HO7 is problem is it movement is dry use selicone spray to spray it there will be a thing that makes it spin but for screen shots plzzzz email me.PLZZZ RATE ME FOR NOU BECOUSE THIS PROBLEM IS NO MORE IT IS SOLVE FOR SHORE..
SOURCE: Panasonic DVD player RV62 H07 message - disc
You can try to clean the laser by opening the unit and wiping gently with a cue tip or cotton swab, but if you are getting a H07 errorit may be somethng more serious and require a replacementof the dvd drive.I hope this helps. Good luck.
