Question about Hitachi 57SWX20B 57" Rear Projection Television
Convergence of Picture
I am being offered a 53" Hitachi TV but the picture is not aligned in that it has several (3 I think) overlapping pictures. I believe the problem is something called a "convergence circuit". What am I looking at as far as repair cost/level of effort...I could do the repair myself if the parts were available possibly.
  • Mark Egan May 11, 2010
    Most TV's like this have a built in convergence capability that you access from a menu of some sort.
    Do you know how to access a menu that displays dots on the screen?
    Problem Solver:
  • 11 Answers
Your TV most likely has one or more possible problems.
Problem #1: Convergence Chip Failure ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.Convergence of Picture - 2c07611.png/>2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Problem #2 CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set thaConvergence of Picture - 578ba6c.jpg fluid changed.
TV set after fluid change
2c07611.pngSolution #2
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc.
Posted on May 07, 2009
    Scholar:
  • 87 Answers
Convergence problems are very common with projection type televisions.As a shop owner/operator I fix convergence problems on a daily baisis and depending on your electronics skill it is a pretty involved desoldering and soldering job.You could end up with a nice set that can last you a few years problem free for any where between $185.00 and $275.00.(If it is done right)You can try it yourself and spend about $75.00 in parts.Call around ant let the shop know that you need Stk392-120 and resistors installed into your set.Find out what it would cost to do just that and go from there.If you were to ask me that question the answer would be $225.00 parts and labor in shop, and $275.00 in home.Hope this information helps and please rate my information.
Posted on Jan 30, 2009
  • Albert Vasquez
    Albert Vasquez Jan 30, 2009
    If you cannot adjust in customer menu the service menu is not going to work either.No need to go there
Magic Focus button will not line up picture. Red and green colors shadow images.
The tv have a problems known as a convergence picture problems it is dead.The tv have any colors lines like R,G,B mis alignments,tv have any colors shadows pictures or 3D pictures look alike?Yes,than the tv convergence board it is dead and the causes of these problems.The tv convergence board must have to repair like replacing like 2 STk covergence ICS and some or all of it resistors too.To fixed the tv convegence board to solved the tv convergence picture problems.The tvs shops will cost u like $300-350 for parts and labors.
Sep 02, 2011 | Hitachi 53SDX01B 53" Rear Projection...
My tv on the right of the screen is blurry,with green around the images.
Ur tv have a problems known as a convergence picture problems,it is dead.The tv have R,G,B colors lines mis alignments,tv have colors shadows pictures or 3D pictures look alike?Yes,than the tv have a dead tv convergence board.The tv convergence board must require changes 2 STK convergence ICS and some or all of it resistors too.After the tv convergence board is fixed,the tv convergence picture problems will be solved.The tv shop,will cost u like $300-350 for parts and labors.
Apr 26, 2011 | Hitachi 53UDX10B 53" Rear Projection...
The tv looks as though Im watching 3D. Tried unplugging for 5mins. Tried resetting picture settings nothing worked. Help please...
Very commom problems on the DLP tvs.The tv have a problems known as a convergence problems,it dead.Tv have colors lines R,G,B mis alignments,have colors shadows pictures or 3D pictures look alike?The tv convergence board have dead 2 STK convergence ICS and some or all of it resistors too.These parts must be replaaced on the tv convergence board to solved the tv convergence picture problems.The shop,will cost u like $300- 350 for parts and labors.
Jan 11, 2011 | Hitachi 53UWX10B 53" Rear Projection...
Hi I currently own a Hitachi rear projection . And I was trying to tune he color and I think I burned the tube I have a line onbrhe screen. Is there a way to clean the picture tube or replace it
Tv colors lines R,G.B mis alignment,colors shadows pictures or 3D pictures?Yes,this tv have a problems known as a convergence problems,it dead.The tv convergence board require changes 2 STK convergence ICS and some or all it resistors to solved the convergence board problems.Will solved the picture convergence problems.The shop,will cost u $300-350 for parts and labors.
Sep 15, 2010 | Hitachi 53SBX59B 53" Rear Projection...
Hitachi 53FDX01B 53 in has green line in the middle and in the corner
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony2_bing.gif, Samsung,JVC2_bing.gif,Philip Magnavox,Panasonic,Akai,Pioneer2_bing.gif, Hitachi,Mitsubishi,Zenith2_bing.gif and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
You can see some more examples and find a fix herebb0cf99.png http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull bb0cf99.png
Apr 20, 2010 | Hitachi 53FDX01B 53" Rear Projection...
The picture is in 3d and i cant turn it off?
The most likely cause is shorted convergence chips and possibly a few pico fuses.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony,Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer Hitachi,Mitsubishi,Zenith and others.
You can get a convergenece repair kit with instructions from the links below.
*Screen Looks 3-D
*Colors wont align
Problem #2
You can see some more examples and find a fix herebb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Apr 17, 2010 | Hitachi 53FDX01B 53" Rear Projection...
HITACHI ULTRAVISON REAR PROJECTION TV HAS 3 OF EVERYTHING. IS IT WORTH FIXING?
Convergence problems are very common on all Projection TV sets including Sony2_bing.gif,Samsung, JVC, Philip Magnavox, Panasonic, Akai, Pioneer2_bing.gif, Hitachi, Zenith, and others. You can get a convergenece repair kit wiith instructions from the links below.
  • Screen Looks 3-D
  • Colors wont align
  • Screen may look distorted or warped
  • No Audio/Video - makes a chirping sound.
Problem #2
  • Dull looking picture
  • White looking picture
  • Halos around objects
  • Red/Orange looking picture
Apr 11, 2010 | Hitachi 53UWX10B 53" Rear Projection...
Where can I get a convergence panel for Hitachi udx10B 53in tv?
These sets have several common problems which are listed below.
  • Screen Looks 3-D
  • Colors wont align
Problem #2
Your TV may have one or more of the following symptoms....
You can see some more examples and find the fix here...
Apr 02, 2010 | Hitachi 53UDX10B 53" Rear Projection...
Seeing double
  • Screen Looks 3-D
  • Colors wont align
Problem #2
Mar 31, 2010 | Hitachi 53UWX10B 53" Rear Projection...
Image of picture has blue color overlaping the other colors
These sets have several common problems listed below.
Symptoms:
  • Screen Looks Distorted/3D
  • Colors wont align
Problem #2 CRT Fluid has clouded over. Symtoms
  • Dull looking screen
  • White looking sceen
You can see some examples and find a fix here...
Mar 07, 2010 | Hitachi 53UDX10B 53" Rear Projection...
Hitachi 57SWX20B 57" Rear Projection Television Logo
186 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
