Question about AKG C451B Professional Microphone
Akg D8000S I bought the Akg D8000S mic and I need to find a way to connect this to my laptop (maybe usb?) so I can hear myself sing. Is this possible? What do I need to buy?
Need to buy the proper sound card ,or a mixing board built for your comp.thier is a usb cord out there,i have one with 1/4 inch on end and usb other end,im sure someone makes one with xlr.
Posted on Apr 23, 2009
Surha AKG uhf ht 40 handheld mic
You need a pop filter while recording. There are different reasons why a "pop" would get recorded in the signal. Either because of the harsh P's and T's while singing or rapping like "Business", "Pain", "Property", etc. or it could be jitter problem due to an unstable clock. Mostly you would recognize these ones cause they don't sound like the pops coming out o a persons mouth. They're more like clicks. Your problem, from what I understand is due to the former reason. That's why you will need a pop filter.
Jul 06, 2014 | AKG Audio Players & Recorders
I recently bought the AKG Perception 120 and have a macbook pro. I also bought a XLR to usb cord to record it in Garageband... But there is no sign of any sound going through the microphone. Please he
Make sure your preferences settings in the MBP are set to use that input. USB recording is not the best way to do things. I'd look online and buy an inexpensive interface, like a Lexicon or Presonus etc, then the interface will connect via USB, but your mic will go into a genuine XLR input on the interface. You'll also benefit from much more gain and level control.
May 14, 2014 | AKG Perception 120 Microphone
C1000s hum/buzz on phantom power
possibly the microphone needs more power than your sound card can supply although I cannot imagine as the duet is a good piece of equipment.
Is the duet USB bus powered?
Have you tried another cable? Possibly one wire is defective which means that phantom power will superpose the audio signal. In this case you might hear a hum. By the way this results in 6dB of signal loss. This is why XLR plugs have 3 wires. If connected with a 1/4" jack it has to be a stereo plug (tip, ring, sleeve)
Mar 26, 2014 | AKG Audio Players & Recorders
Akg perception 220 professional microphone
Try building a little mike-preamp with an opamp to boost the signal.
Enough schematics on internet.
Or walk into an electronics shop for a ready to build package.
These are the things I can suggest; I don't know your audiobox.
Perhaps there is internally a pot-meter to adjust the gain of your mike; that would be the easiest solution.
Mar 06, 2014 | PreSonus AudioBox 22VSL 2x2 USB Interface
Sometimes my AKG Perception 420 won't record properly, when played back it sounds like white noise with the faintest sound of what i'm trying to record in the background
All microphones have a signal to noise ratio. Basically defined as the level of desired sound to background noise (unwanted sound). Microphone phones also have self noise which should be considered when choosing a mic. There will be noise in every mic, some more audible than others. Condenser microphones require phantom power (48V). This can be supplied by mic prea
mps, mixers, and similar equipment. *Note that phantom power (mic pre amps) must be on or engaged, this can be specific to different types of equipment.
Troubleshooting:Has your microphone been dropped or exposed to moisture? Internal damage to your microphone will be hard to assess but this could possibly be the issue. Inspect the microphone cable, check for damages. Try using a another microphone cable-- preferably a new one. Next to check would be your mic's power supply. Make sure all connections are made properly (mic to cable to power supply). If you are using a mixer or pre amp with multiple inputs, test the mic on each input. (You should test by making recordings and comparing with each change to isolate possible causes). Also test the mixer or pre amp by slowly sweeping the input gain feature while recording an audible source such as singing into the microphone. Typically next in the audio recording chain would be your DAW (digital audio workstation) or computer, but problems with noise most likely precede this.
I could possibly provide more useful information if I know your exact setup.
Provided that you have your equipment setup properly, the microphone or mixer/preamp could possibly be damaged/malfunctioning. I suggest taking your equipment to a trusted repair shop, or if still under warranty, returning to the manufacturer for repairs or replacement.
Hope this helps
Apr 05, 2011 | AKG Perception 420 Microphone
I get little sound out of the microphone spots onm my DA-X10Pro. I have a karaoke THE SINGING MACHINE. When I use my karaokee machine mic plug in the mic works fine...but any voice into the mic...
The mics on the singing machine are very low end mics and MAY not work on your other unit. The Voco has very sensitvie inputs to use with "professional" type microphones. The Singing machine mics are going to be fairly high output and likely to overload the voco inputs. Procure some professional mics like Shure, AKG, Sennheiser or others and don't forget to use a balanced to unbalanced adapter or cable on the mics.
Jan 06, 2011 | Vocopro DaX10pro
I hear a "pop" from the microphone when singing. What causes this?
very common problem caused by pressure waves, try singing off mic but on axis so maybe a 6inches away.
or buy a pop shield (transparent audio foam to cover the mic capsule)
should sort it out, if this does not work then the mic may be damaged.
hope this helps
thanks for using FixYa
Aug 29, 2010 | Magic Sing Along Consumer Microphone
Loss of bass frequencies in dynamic mics
That's one correct assumption, but it's actually the element that gets damages causing the coil to rub. Open the top up and see if there is any damage, sung a magnifying glass as the tiniest crack could go un-noticed by the naked eye.
In testing these 2 did you change the frequency at all? trying with a different receiver, having another mic on the "bad" mics frequency?
Loss of lows can also be a sign of a bad wire as this sometimes tend to act as a high pass filter.
Did you do the obvious, change batteries?
jeff
Dec 22, 2007 | AKG D8000S Professional Microphone
AKG C451B Professional Microphone Logo
97 people viewed this question
Top AKG Audio Players & Recorders Experts
Michial Gueffroy
Rob Beech
Vito Vacirca Jr.
Are you an AKG Audio Player and Recorder Expert? Answer questions, earn points and help others
