Question about Acer ScanPrisa 640P Flatbed Scanner
I need the output voltages of scanner acer flatbel 640.. is it 16 dc or 12 dc voltages ?
  • 2 more comments
  • Selio Feb 02, 2009
    I need to specify the output voltage for my scanner. Is it 12v or 16v ??!
  • matherqa May 11, 2010
    output voltage is 12V
  • Ananda Athukorala Feb 13, 2013
    I think 12V/0.9A. Becuase for AcerScan Prisa 320P power to the scanner is 16V/0.9A
    Sorry, typing mistake. it may be 16V/0.9A
Dear friend,
the voltage out put of your scanner is 16v DC, 0.09A
jyro101@yahoo.com
Posted on May 06, 2009
Display screen not ligthing up
Confirm voltage at the wall outlet and then move onto the voltage output from the power supply. The power from the wall outlet should be 110V AC. The voltage output from the power supply should be 12-14V DC. If these both check out as good readings, move up to the console to confirm 12-14V DC. If the console is getting power and still not coming on. then you need a new console.
SPORTSMITH LLC
Nov 26, 2013 | Stairmaster 4400PT FreeClimber
The power adapter is bad. What are the power requirements for this unit i.e visioneer 9220 USB scanner
Hello! You can actually get this directly from Visioneer for $19.99.
http://www.visioneer.com/products/parts.asp?PN=9220
Otherwise the power specs in the manual are here.
Power supply Input voltage/frequency 100 Vac, 50/60 Hz (Japan) 120 Vac, 60 Hz (North America) 230 Vac, 50 Hz (Europe) Output voltage/watt 12 V DC, 15 watt maximum
http://support.visioneer.com/downloads/Manuals/9220/9220_Install.OT3.EN.pdf
If this helps, please give a positive rating. Good luck to you!
Jul 01, 2011 | Visioneer OneTouch 9220 USB Color Scanner
Acer AspireOne Model ZG5 charger failure. How to test and is output voltage important on replacement.
Test the AC adapter's (Charger) plug with a multimeter set to DC voltage.
(You can buy an economical multimeter for around $10 to $12)
If the DC voltage has different scales to use, advise using the 0 to 50 volt scale.
The center of the plug is Positive.
The outer shell is Negative.
The Positive probe lead (Red) of the multimeter goes to the center of the plug.
The Negative probe lead (Black) goes to the outer shell.
YES, Voltage is absolutely imperative! You can go a little higher with Amperage. (Amp)
Nov 29, 2010 | Computers & Internet
What is the proper DC power supply voltage for an
Power supply details are as follows:
Mar 12, 2010 | Visioneer OneTouch 8100 Flatbed Scanner
Power coverter to scanner failure.which unit should i buy? present one 240v 50/60hz.0.4A. output 12v.dc.i.25A
I just found my Canon 5000F scanner to have a power supply outputting 3V DC instead of 12V DC. I replaced it with a 12V DC Power Supply from Tandy rated at 1.5 amps. I had the scans getting darker by the day and sometimes completely black. Now I have great scans again. Just test the voltage at the plug that supplies the scanner for a healthy 12V DC with a multimeter.
Jan 20, 2010 | Canon CanoScan 5000F Flatbed Scanner
I misplaced the power supply for my visioneer 4400usb scanner. Can anyone tell me the voltage output to the scanner?
Power supply
May 24, 2009 | Visioneer 4400 Flatbed Scanner
Voltage on Acer Aspire One -110 - 220?
It is 100 - 240 V.
All you needs is the Votage adapter, no converter needed.
Acer Aspire one rating 11.1V laptop battery. Charger Specs: Input Voltage: 100 ~ 240V AC 0.24~0.60A 50/60Hz Output Voltage: +12.6V DC Output...
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
May 14, 2009 | Dell Wireless Keyboard Optical Mouse w0147
MISSPLACED AC POWER SUPLY FOR "MY BOOK" 250 GB USB.
THE ANSWER TO MY QUESTION WAS FOUND OUT BY MYSELF BY VISITING A REPAIR / SERVICE DEPARTMENT AND MAKING ENQUIRIES CONCERNING THE DC OUTPUT OF THE AC ADAPTER ASSOCIATED WITH THE WESTERN DIGITAL, MY BOOK 250GB USB. tHE VOLTAGES ARE THESE. : - AC INPUT = 100 - 240 VOLTS 50/60 HZ
DC OUTPUT = 12 VOLTS ( REGULATED ) 2 - 0 A
CENTER PIN OF 12 VOLT DC INPUT PLUG IS " POSITIVE "
THANK YOU FOR THE SPACE TO ASK MY QUESTION.
Feb 18, 2009 | Western Digital My Book Essential Edition...
Lost the power plug what kind is it
1. You can buy a new power plug here.
2. You look at the power connector on your scanner and try to find a replacement with the following specifications:
Input voltage/frequency:
  • 100 Vac, 50/60 Hz (Japan)
  • 120 Vac, 60 Hz (North America)
  • 230 Vac, 50 Hz (Europe)
Output voltage/watt:
  • 12 V DC, 15 watt maximum
If you try to find an AC/DC converter yourself, make sure that the DC plug has the right +/- polarity and right size.
Jan 11, 2009 | Visioneer 4400 Flatbed Scanner
Can anyone tell me if the 12 volt powersupply is 12 volt AC or DC ?
Model HER-48-12010
P/N: 68300021-0013
AC Input
DC Output
Sep 20, 2008 | Compaq S 200 Flatbed Scanner
Acer ScanPrisa 640P Flatbed Scanner Logo
115 people viewed this question
Top Acer Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you an Acer Office Equipment and Supply Expert? Answer questions, earn points and help others
