Question about Tappan TGF363 Gas Kitchen Range
Tappan Custom Stove
Burners work but not oven. Told could be the ignition as stove has automatic pilotless ignition. Where located? How to safely remove? Where to get replacement part quickly?
  • chuckwagon70 Mar 02, 2009
    my ignitor to the stove turns on and is bright, but the oven does not turn on. is there something i can light to turn the oven on?
4 Suggested Answers
  • 1214 Answers
SOURCE: Hello, Can't find model/serial number.
Serial number labels are usually located in any one of a number of places -
Under the cooktop in one of the corners
Inside the oven door frame (not on the door)
Behind the bottom drawer pullout on the oven, left hand side
Oven back.
If this unit is anything less than 20 years old, there will be a label somewhere.
Reply back you findings and I can give you more information as to how to repair, and we can identify part numbers. You might also try www.repairclinic.com and see if you can drill down through parts when only knowing the manufacturer.
Posted on Jan 30, 2009
SOURCE: oven not coming on
I have a tappan gas stove the top comes on but the oven wont come on.
Posted on Mar 18, 2010
  • 2694 Answers
SOURCE: model/serial number 12-0506-05/03135-18204133.
even though the ignitor glows it doesn't mean it's good,it works by amps. it takes 3.2 amps from the ignitor to open the gas valve,part number for ignitor is 5303935066 and it's around 65 dollars.you can look it up on the sears site http://www.searspartsdirect.com/partsdirect/part-model/Tappan-Parts/Range-Parts/Model-TGF320DWB/1269/0124002/R0510098/00002?blt=06&prst=&shdMod=
Posted on Oct 12, 2011
I have a Hot Point Gas Stove my burners all turn on but when I turn on oven nothing seems to happen
If you have a pilotless model it is very likely that your oven igniter is bad. This is fairly easy to replace. A contunuity check will show if the igniter is bad.
Nov 25, 2013 | Stoves Ovens
I just cleaned my Tappan NF40700643 Automatic Pilotless Ignition gas oven and now the light bulb (bulb is good) the and oven does not get hot .... it does nothing. Help ... I have dinner ready to put in...
if not even the light bulb is working it sounds like the plug is out or the fuse blew,pull the stove out,plug in a hair dryer or something to see if there's any power at the outlet or just go check the fuse or breaker box
Aug 16, 2011 | Tappan TGF363 Gas Kitchen Range
Hi, I own a Tappan oven..model #TGF364ASF..the
Hi an welcome to FixYa. I am Kelly.
If nothing lights... i.e burner or oven there are only 2 things that can cause this problem. A failed ignition module or a wiring problem. The wiring problem can be a simple short or a broken power lead. All of the stove top ignitors are in a series parallel connection and if one of the burmer control shorts you loose the stove top. With nothing is lighting oven and burners it sure points toward the ignition module or power to the module.
Thanks for using FixYa.
Kelly
Note... The ignition module itself is not cheap.
Apr 09, 2010 | Tappan TGF364AS Gas Kitchen Range
Oven not coming on
Sep 07, 2009 | Tappan TGF363 Gas Kitchen Range
You have to light burners on stovetop with a match all the time.
The pilots for the range top are beneath the top of the range top. YOu will see them if they are there. YOu stove may use electronic ignition and you can hear the sparking when you turn the knob to the "light" position.
If it is electronic ignition, make sure the stove is plugged into an operating outlet
Apr 15, 2009 | Tappan MGF500PBW Gas Kitchen Range
Tappan oven not gas flow or ignition
Right rear burner will not ignite without assistance (a match or lighter). What is the problem?
Feb 13, 2009 | Tappan TGF303BW Gas Range
Hello, Can't find model/serial number. Older Tappan custom gas stove. Burners work but oven does not. Told it has electric ignition that could be problem. Where to find it, how to remove, where to get...
Oven back.
Jan 30, 2009 | Tappan TGF363 Gas Kitchen Range
Tappan TGF363 Gas Kitchen Range Logo
537 people viewed this question
Top Tappan Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Sal De
Are you a Tappan Kitchen Range Expert? Answer questions, earn points and help others
