Question about Panasonic TH-42PD50U 42 in. Plasma EDTV
TH-42PA50A - power supply problem
The unit is 18 months old and has worked perectly until now. The system powers itself down leaving the power light blinking slowly. After a re-cycle of the power switch it (usually) comes back on. It can remain on for anything between 5 minutes to 20 mins. before repeating the power down. Is this possibly due to power fluctuation? It only seems to happen at nighttime. Are Panasonic power supplies super-sensitive?? All other systems on the same power circuit continue to work flawlessly.
  • Anonymous Oct 02, 2008
    Yeah, same thing happening to me now. Screen goes dead with no warning and the power light blinks 4 times (and sometimes blinks only 2 times). Requires me to unplug it from the wall for at least 5 minutes before I can turn it back on and then might only last 20 mins.
  • 147 Answers
Ok,Sounds Like A Board Failure,Main Board,If you Have an Extended Warranty,Look for the Closest Warranty Station to you....Not an Easy Fix ttech
Posted on Jul 29, 2007
SOURCE:
I have a panasonic viera TH-42PA50A and the red light continuously blinks any ideas
There could be a power supply problem. Your TV tries to start, but can't.
Aug 15, 2014 | Televison & Video
Panasonic TH-42PX60B
have you already service the main unit, or you an initial check on the parts of the TV..
kindly post back the TV model/maker..
Thank you
May 18, 2008 | Panasonic TH37PX60 37 in. Plasma...
Hi I have a panasonic viera TH-42PA50A blinking red light and it just keeps blinking any ideas what it could be
it is not a good sign. If the tv screen is dark (no picture) and no sound but the standby red light is continuously blinking then it could mean the power supply board in tv is faulty.
Usually a few burnt out capacitors on the board but hard to replace yourself unless you are experienced in this sort of work. From the model it appears a reasonably recent unit and you may want to get it checked out by a repairer at least to get an estimate of the cost.
See this site to get some idea of the part costs.
PANASONIC TELEVISION TH42PA50A Parts
Sylvania LD320SSX turns off by itself.
your powersupply is dying in the set.. have it checked..
Apr 10, 2010 | Sylvania LD320SSX LCD TV
Tv wont turn on, red led flashes 10 times
If this is NOT projection, then the power supply is burnt out. If it is projection, then either high voltage transformer, flyback, or power supply is at fault
Nov 08, 2009 | Panasonic Viera TH-50PZ80U Plasma TV
My console is approximately 18 months old and will not power up, what can I do to start it?
HI, There is a fuse located inside the power supply unit. I would advise to check this fuse asap. The fuse may have burned out, due to a surge of some sort. If the fuse is ok, this will confirm that the power supply itself has failed. Have it replace asap.
Sep 30, 2009 | Nintendo Wii Console
Panasonic 42 Inch takes 15 seconds to come on
Okay, This is not i huge issue plasma do take some time 15 secounds would be kinda noraml there. I would say leave it alone until you find another mahor issue as 15 sec for a plasma on total cool down is not a issue as of yet.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Jun 26, 2009 | Panasonic TH-42PX75U 42 in. Plasma...
(panasonic TH-42PZ77U plasma) the tv will power on but before the picture comes up it powers back off. Red power light is flashing.
in protective mode the tv does not turn on and light is blinking, typically we must proceed by elimination as some faulty sections are preventing the tv to switch on. unplug the output power connectors from the power supply until the latter stop clicking. if it is still clicking after every of the output rail have been disconnected, then the power supply itself is faulty.
hope this helps!
Mar 21, 2009 | Panasonic TH-42PZ77U TV
Won't Turn On....Immediately Switches To Standby
Did you get your tv fixed? It may be the Sub power supply unit. If the main supply went out it would not light the display at all. Yes it is time for th repair shop. Good Luck.
Jan 25, 2007 | Sylvania 6842-PEM 42 in. EDTV-Ready Plasma...
Panasonic TH-42PD50U 42 in. Plasma EDTV Logo
287 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
