Question about Delta Victorian T2755-NNLHP Bathroom Roman Tub Faucets Pearl Nickel
Delta faucet is loose ;moves right-left/wobbles. Tightening?
How do I tighten the fitting to get a more secure mount? It is a I believe Victorian style tub fixture with single handles alongside faucet which are fine, but the water faucet fixture is wobbly and needs to be tightened and adjusted. I need information on mechanics to get this resolved.
  • 33 Answers
Try tightening the allen set screw behind the spout "you need a special (allen keys) to do this, and one should have came with your faucet". You can also buy or borrow an set of them.
http://www.efaucetscomplete.com/SpecSheets/T2755CBLHP_Install.pdf
Copy and paste this to your address bar for directions.
Posted on Jan 31, 2009
Delta 2555-216 Victorian Double-Handle Centerset Lavatory Faucet with Metal I have a slow drip in bathroom sink and do not know how to remove the stem to get at the washer in the Victorian listed above.
If you notice right below the handle,there should be a small opening where ,by using an allen wrench you should be able to remove handle giving access to the stem retaining nut ......CAUTION... be sure cutoff valve is turned off(both hot and cold cutoffs.... under lavatory sink before removing..........unscrew retaining nut and remove stem.....hope that helps......
Sep 01, 2011 | Delta 2555-216 Victorian Double-Handle...
We have a kitchen faucet that is similar to this one, in that it has two different handles for hot and cold and there is no plate that the faucet and the two handles rest on. The problem is that when we...
I personally would not call this plumber back if that was his prognosis. Sounds like it might have a stripped thread you could possibly try some loctite on the portion of thread before tightening or just replace the unit especially if it has age on it's side. Good Luck..
Nov 26, 2010 | Delta Victorian T2755-NNLHP Bathroom Roman...
I have a Moen Monticello bathroom faucet. I am
Moving left to right: I am not an expert, but I have installed a fair number of faucets. Seems like a basic issue of just getting under the sink and tightening up. Make sure someone is topside to assure the faucet stays straight and does not move as you tighten up below. It is never easy to get a wrench and your hands in the proper position to tighten up the nut, but don't give up try a smaller Channel lock wrench if necessary.
Sink Stopper: http://www.lowes.com/lowes/lkn?action=howTo&p=Improve/PopUpStop.html
Jan 02, 2010 | Moen Bathroom Sink Faucet - 4-inch...
Delta 473 loose connection to sick
There should be a nut holding the plate on. What is holding the u-shaped plate up?? You can't tighten the faucet from above. Seems strange the nut disappeared.
Aug 08, 2009 | Delta Model 473: Saxony Kitchen...
Delta 473 faucet very loose where it meets the granite
This is a view from the underside of our sink. Is this what you were talking about? The steel plate is W-shaped (upside down in this case) and has a single nut larger than 3/4". It's almost impossible to fit a wrench up there to tighten it.
Jul 30, 2009 | Delta Model 473: Saxony Kitchen...
Swing arm too loose
What I have doen in the past is to take the compression nut off. Wrap teflon plumbing thread tape around and between the two o rings and tinghened the compression nut back down,tightening the worn swing arm joint.
Mar 11, 2009 | Delta 16955-SSSD Stainless Steel Victorian...
Delta Victorian T2755-NNLHP Bathroom Roman Tub Faucets Pearl Nickel Logo
2,333 people viewed this question
Top Delta Plumbing Experts
Donni Steen
Ed Mac
bwbconstruct
Level 1 Expert
Are you a Delta Plumbing Expert? Answer questions, earn points and help others
