Question about Ricoh Aficio 2015 Copier
Pcq on full colour mode
I have aproblem on a 1224c where it is puting feint lines on the back of a calibration copy about 1 cm from the edge of the paper .the line is about 1cm thick and 6.5 cm long,also repeat the calibration image on the same page
  • Ricoh Master
  • 2,794 Answers
Make sure your rollers are clean. It could be something dirty in the fuser section as well.
Posted on Feb 10, 2009
Printer colour alignment out. How do it align this?
CALIBRATE THE PRINTER
Use the menus
1. Press OK to open the menus.
2. Press the Left arrow ( ) or Right arrow ( ) button to navigate through the listings.
3. Press OK to select the appropriate option. An asterisk (*) appears next to the active selection.
4. Press the Back arrow ( ) button to scroll back through the submenus.
5. Press X to exit the menu without saving any changes.
Color Calibration
? Power On Calibration. Specify whether the product should calibrate when you turn it on.
? Calibration Timing. Specify how frequently the product should calibrate.
? Calibration Mode. Specify the type of calibration the product should use.
? Normal
? Full (slower)
Full calibration improves the color accuracy of photos printed on 100 x 150 mm (4 x 6 in)
HP Color Laser Photo Paper.
? Calibrate Now. Set the product to calibrate immediately.
NOTE: You must click Apply before your changes take effect.
Jul 18, 2011 | HP LaserJet CP1515n Printer
The printer works OK but it prints two lines clearly but every third is feint almost half the writing is ommitted
Set the print quality to normal or best.
Clean the printhead
Run a calibration.
The Kodak EasyShare AiO performs a calibration every time you install or replace a printhead. However, you can run a calibration if you are seeing changes in the image quality. Calibration aligns the printheads and performs a nozzle health check to enable high-quality prints.
1 Load the main tray or photo tray with photo paper.
IMPORTANT: If you don't have any photo paper, you can use plain paper, but photo paper is highly recommended for calibrations.
2 Press and hold Photo and Cancel together to make a calibration print.
3 Follow the instructions on the calibration print to calibrate the printer.
Feb 11, 2011 | Kodak EASYSHARE 5100 All-In-One Printer
Hi, I have a Ricoh 1224c, color copies come out with a blurred or waterfall effect on about the first half inch of the leading edge of the copy, but the black copies are ok. The next 1 1/2 inches roughly...
The Colour toner more small and he does not disappear the blade a peelings, you it is necessary to check the magnetic hand on colour cartridge. If hand unevenly covers the magnetic gross to adjust the дозирующее blade. Clean the gross, insert the sheet of paper between dose and gross and release the bolts an dose blades, press the blade to paper aside gross magnetic, afterwards bolt the bolt. Extract the sheet. Clean all from the remainder of the toner. Check the blade a peelings drum if evaporation during stop main by breaker exists on drum, change rakel. The Period of rakel's work is measured by period of the work photo drum, beside 10 thousand sheets. Such effect more often exists from wear-out of rakel. Remind, black toner has grain more so he leaves the rakel. The Colour toner small and its clear requires new rakel.Udachi. fault has not an electronic reason. This mechanics.
Oct 06, 2009 | Ricoh Office Equipment & Supplies
Black line down the right hand side of prints
it may have had a dirt inside that may have been causing the lines. try cleaning with a soft dry cloth then try to print. reseat first the toner before you clean or wipe with a soft cloth
Sep 23, 2009 | Office Equipment & Supplies
Service Manual for disassembly
HP Photosmart C7280 printer gets into a paper blockage mode that appears to be from its own mechanical parts - leaving 1.2cm wide indentations on the leading edge of the paper on its top left side starting at about 2 cm and sometimes also 7 cm from the corner. Happens in copy and print modes. Is there a fix for this problem?
Apr 22, 2009 | Office Equipment & Supplies
Full colour page print has faded lines printed through the work
I have ordered a new photocunductor unit as i am assuming that the other one was faulty.
Jul 07, 2008 | Epson AcuLaser CX11N All-In-One Printer
Trying to use a Zebra ZTC ZM400 with an AS400
I was having same issue printing from our AS400's as well.
Issues was resolved by installing latest Zebra ZM400 firmware.
We were on ver V53.16.3Z but upgrading to V53.16.4Z seems to have resolved it.
Good luck.
Jul 03, 2008 | Office Equipment & Supplies
Clicking nosie from scanner bed on epson cx5800f
I had a similar problem, the scanner bar was stuck to the far left side. Here's how I fixed it:
1)Unplug the printer, disconnect any cables/phone lines to it.
2)Lift up the entire scanner bed housing(you will see the printer ink cartridges).
3)Locate the access patch (approx 1 cm x 1 cm square) along the left edge of the scanner bed housing(this is the side that closes in, next to the keypad buttons).
4)Using a small knife blade, peel off the patch from the corners and edges(it's sticky. Save it, you can stick it back over the hole when you're done).
5)Stick a pen through the access hole, and push the scanner bar to the right, approximately 2-3 inches.
6)Now, close the scanner housing, plug in the printer, and power it on.
It should reset and re-calibrate the scanner bar. If it doesn't, repeat steps 5) and 6) a couple times, until the printer correctly performs calibration. Then, you can put the sticky patch back over the hole, and you're ready to go. Hope this helps!
Jun 28, 2008 | Epson Stylus CX5800F All-In-One InkJet...
Epson Photo R265 Lines every 2.5 cm
Check status monitor see if cartridges are low or nearly empty , if new or full take out all cartridges and soak nozzles upright in cleaning solution overnight , or untill ink starts to bleed out:
Dab dry and re - fit , make up a A4 paper page with 6 colour bands about 1" high x 8" wide and print about 4 to 6 pages ,
check which colours are poor , if improvement is observed run
again a few times:
If one colour is poor take out that cartridge and soak again for a few hours , try again:
If no improvement replace with new cartridge or use a cleaning cartridge ( available on-line ) :
Using the head-cleaning utility shortens the life of the printer as the printer is set to lock-out after a pre-set use of the cleaning facility: and will have to be re-set instore:
cx3200@tiscali.co.uk
Dec 17, 2007 | Epson Stylus R265 InkJet Photo Printer
Ricoh Aficio 2015 Copier Logo
69 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
