Question about ASUS GeForce FX 5200, (128 MB) Graphic Card
Geforce 6200 i am still getting the same problem i was having with the line that were moving fast all around the screen. the card is less then 3 hours old please help with a way to fix my problem
  • 1 more comment
  • chris cainan Jul 29, 2007
    they are set to the lowest setting i can go whitc is 6o any other ideas would be great
    yes i have uninstalled the old drivers and installed the ones that came on the cd. i have unistakked them and down loaded the ones off the web page
  • chris cainan Aug 02, 2007
    thank u for your help. i went and bought a different brand it has fix the problem. thnks again
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 133 Answers
You need to adjust your monitor settings. go to your desktop, rightclick and go to properties, settings, advanced, under monitor adjust your settings to the lowest refresh rate. hope it helps
Posted on Jul 29, 2007
  • scott gregg
    scott gregg Jul 29, 2007
    Did you uninstall your old driver?
  • scott gregg
    scott gregg Aug 01, 2007
    no the original driver that is on your computer not the geoforce one...
    if its trying to run both it can cause errors
Hi, I have an EVGA GeForce 6200 AGP, 256MB DDR2
This is a common problem, you need to clear the CMOS which will also reset the BIOS settings. Here's a few ways you can do that:
http://pcsupport.about.com/od/fixtheproblem/tp/clearcmos.htm
Feb 22, 2010 | Evga e-GeForce 6200 GeForce 6200, (256 MB)...
Geforce 6200 / dell dimension 4600 resolution problem
if this is a relacement for an old card 1st make sure the old drivers are ubisnatlled and the goto www.nvidia.co.uk and install the latest wqhl drivers and that should remidy it you may also need to reset you monitor settings
Feb 02, 2010 | XFX GeForce 6200 Graphic Card
Will an Nvidia GeForce 6200 graphics card support dual monitors?
I would say yes one on your old computer montior connect and one on the card unless that card has two tv outs
Jan 28, 2010 | Evga nVIDIA GeFORCE 6200 TurboCache 256MB...
No sound toshiba tecra m3
The Toshiba M3 laptop has an Intel Pentium M 2. 13 GHz processer and 512 MB (DDR2 SDRAM) of memory (although it can support up to 2048 MB). The 36cm XGA TFT LCD screen supports a maximum resolution of 1024 x 768. The internal hard drive can store 80 GB of data. The weight of the laptop is around 2300g and the Lithium ion battery lasts for around 3. 2 hours from a full charge. This laptop has a NVIDIA GeForce Go 6200 PCI Express graphics and has Headphones, Sound card and Speaker(s) audio outputs.
Dec 03, 2009 | Toshiba Tecra M3 Notebook
Scrolling delays, choppy scrolling as if multiple pages
Did you install the original drivers from the vendor of the e-Geforce card if not try doing it it should fix the problem.
If you dont have it download it from here
Also try to update the directx
Nov 29, 2009 | Evga e-GeForce 6200 GeForce 6200, (256 MB)...
Bad 3 grapics Geforce 6200 AGP
Download your graphics driver from nvidia the Geforce 6 series, select for the kind of operating system you use. http://www.nvidia.com/Download/index.aspx?lang=en-us
Apr 27, 2009 | Nvidia GeForce 6200 AGP Graphic Card
GeForce 6200 PCI when drivers are loaded, screen goes blank
the problem is with display resolution setting which ur monitor doesnt support
press f8 on startup and choose enable vga mode
then widows will boot up in 640x480 mode
then change the resolution to 800x600 or whatever u want
thanks
Apr 11, 2009 | XFX NVIDIA GeForce 8500 Graphic Card
Vedio controller GeForce 6200
XFX GeForce 6200, Graphic Card
driver dowunload
Aug 16, 2008 | XFX GeForce 6200 Graphic Card
Getting black screen after booting screen after install of new card. . :(
hi im wesley iv had the same problem before with my compute. the problem might be i broken ide cable or a loose connection make sure the all cables in your pc is connected properly and if so change a few of the cables if it doesnt work you might have to get a new hard drive and also check if your cpu is in properly and not moving around at all then go into your bios and check the temprature pf the cpu and try running a health test from the bios it might be you fan isnt making proper connection with the cpu causing it to over heat and automaticall switching off for safety.
Jul 08, 2008 | Evga e-GeForce 6200 GeForce 6200, (256 MB)...
Black Screen
hi im wesley it might be that your video card is lose and noy making proper connection with the mother board or it might have blown something small on the board make sure nothing has broken off or is bent
Jun 16, 2008 | Evga e-GeForce 6200 GeForce 6200, (256 MB)...
ASUS GeForce FX 5200, (128 MB) Graphic Card Logo
122 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Marvin
Marvin
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
