Question about Tappan TGF363 Gas Kitchen Range
Hello, Can't find model/serial number. Older Tappan custom gas stove. Burners work but oven does not. Told it has electric ignition that could be problem. Where to find it, how to remove, where to get replacement.
  • 1 more comment
  • nowaczm Jan 30, 2009
    Thanks so much.
    found it 30-2042-00/05332 8348 3405
    Thanks again.
  • 1,214 Answers
Serial number labels are usually located in any one of a number of places -
Under the cooktop in one of the corners
Inside the oven door frame (not on the door)
Behind the bottom drawer pullout on the oven, left hand side
Oven back.
If this unit is anything less than 20 years old, there will be a label somewhere.
Reply back you findings and I can give you more information as to how to repair, and we can identify part numbers. You might also try and see if you can drill down through parts when only knowing the manufacturer.
Posted on Jan 30, 2009
  • Mark Egan Jan 30, 2009
    You can also go to and see full exploded views and order parts.
    Enter TGF363 into the Model number blank.
    If you don't mind, bump me up a notch in the rating. While I didn't fix your unit, I found all the information you were looking for, and it's kinda hard to replace the parts without being there. :-)
    And thank you!
    Let me know if you need anything else. I'll be happy to answer.
Hello. I own a Tappan, Self Cleaning, gas range, electronic ignition. There is a Model number and serial number which has been partially obliterated. It looks like FF6578F83 and NF016100?? The top burners work fine. It is the oven which will not light. Can you help?
Posted on Feb 02, 2012
I have a 50 yr old Tappan Oven that I am trying to relight after gas was shut off.
I found the ID Plate under the broiler floor, by pulling forward the U shaped support for the broiler rack, disemgaging 2 flat hooks that were visible through the floor, then lifting it out. The plate was on the horizontal support running fore and aft on the broiler drawer.
My Model is G0-101. I still have not found the red button to push to let gas flow.
Good luck to us both.
Posted on Feb 01, 2009
2 Suggested Answers
  • 2694 Answers
SOURCE: model/serial number 12-0506-05/03135-18204133.
even though the ignitor glows it doesn't mean it's good,it works by amps. it takes 3.2 amps from the ignitor to open the gas valve,part number for ignitor is 5303935066 and it's around 65 can look it up on the sears site
Posted on Oct 12, 2011
Check oven temperature sensor, should be ~1100 ohms at room temperature. If too high or low, replace oven temperature sensor
Feb 07, 2010 | Tappan TGF364AS Gas Kitchen Range
No gas going to oven
Hi blocked oven pilot , ffd not working oven burner blocked injector blocked
Feb 02, 2010 | Tappan 24 in. Freestanding Gas Range...
Trying to bypass electrical ignition on oven to
Hi, the gas valves on modern ovens are electrical and cannot be turned on without electricity. Only the cook top burners can be lit manually.
Jan 29, 2010 | Tappan Kitchen Ranges
Tappan gas range electric pilots will not light
The gas line in your Tappan could be closed or
stucked up. Have it check.
Sep 23, 2009 | Tappan TGF320 Gas Kitchen Range
Magic Chef Range in camp trailer, pilot light in the oven works however, the burner will not light when turned on. No gas flows. Propane furnace works ok and the propane bottle is full. The surface burners...
The most common problem for gas surface burners is that they get gas but don't light. This is generally caused by dirt or grease splatters on the burner itself. Residential-grade range/stove burners are round and have small holes around their perimeter to allow gas to flow out and create a round flame. The gas coming from these holes is often ignited by a small vertical row of holes on the side of the burner. If these vertical holes are clogged or obstructed, the gas can't ignite.
The solution is to clean the burners thoroughly. Use a toothpick to clear the small vertical holes, then allow the burner to dry completely and try lighting it again. If it doesn't light immediately, repeat the procedure
May be the ignitor, replaced mine and it fixed it. A gas company guy told me that is common in Magic Chef ranges.
Thanks for contacting Fixya
Jun 14, 2009 | Tappan MGF500PBW Gas Kitchen Range
You have to light burners on stovetop with a match all the time.
The pilots for the range top are beneath the top of the range top. YOu will see them if they are there. YOu stove may use electronic ignition and you can hear the sparking when you turn the knob to the "light" position.
If it is electronic ignition, make sure the stove is plugged into an operating outlet
Apr 15, 2009 | Tappan MGF500PBW Gas Kitchen Range
Tappan oven not gas flow or ignition
Right rear burner will not ignite without assistance (a match or lighter). What is the problem?
Feb 13, 2009 | Tappan TGF303BW Gas Range
Oven will not lite
Older is BETTER !! Replace the igniter,even if it is glowing
note:there is a 2% chance the safety valve is the problem.And I'll bet you ,you are in the 98% side on this one.EVEN THOUGH YOU SEE IT GLOW -----IF ITS JUST GLOWING---------GLOWING--------GLOWING---------it's gone ! !
Please Rate This & Thank You ! !
Feb 01, 2008 | Tappan TGF363 Gas Kitchen Range
Tappan TGF363 Gas Kitchen Range Logo
3,981 people viewed this question
Top Tappan Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Sal De
Are you a Tappan Kitchen Range Expert? Answer questions, earn points and help others
