Question about Maytag PYE2300AY Electric Dryer
Dryer seems to heat up but clothes not drying
Dryer seems to heat up but closthes are not drying, when I open the dryer door there is water (condensation) and it fogs up my glasses.
Thanks
Bill Linduff
Check for clogged passages from where the door opens to the exhaust hose. start ate the exhaust and work backwards.
Posted on Jan 30, 2009
  • 29 Answers
Check to ensure that its rotating. Then check the outlet hose for restrictions. If there are not any restrictions in the hose, and if the dryer connects to a wall pipe check the wall pipe for an accumulation of lint. Heavy lint will saturate and allow reverse drafting of condensation once the core air temperature drops. There have been instances where the blower is not attached to the operator shaft of the motor. Your air is circulated by the blower pulling air from the barrel into and over normally two heating elements. If there are restriction in the air flow here a fire hazard could exist. Hope that helps. After checking provide more details.
Dryer won't dry clothes
Heating element faulty not giving as much heat as it should
Nov 14, 2015 | Dryers
It just doesn't seem like my frigidaire gas affinity dryer is drying as fast as it should
Hey Car Guy,.. there are two factors that determine how fast the clothes will dry:
1- air temperature, Is the gas burner is lighting and heating the air? Just stop the dryer mid-cycle and feel the clothes - if they are hot, then the burner/heating part of the dryer is working ok.
2 - adequate air going through the dryer. This is usually where the problem lies. There is a lint filter at the dryer somewhere, accessed either where the door opens, or on the top of the dryer....there may be an additional lint filter somewhere on the exhaust duct. Check for that, and check your air flow where it exhausts outslde. See that the flappers of the backdraft damper aren't stuck closed etc.
If you have good heat and good air flow, then it's doing all it can.
Mar 22, 2013 | Dryers
My dryer is running hot but doesn't dry the
The cycling or operating thermostatis often the problem when a dryer runstoo hot, but there are also other things that can make it run hot also.
Here is a tip that I wrote that gives more details about why a clothes dryer will get too hot.
Clothes Dryergetting too hot
heatman101
Aug 05, 2011 | Whirlpool Electric Dryer Heating Element...
Wed9200sq0 heats, tumbles but does not dry at any heat setting
You are correct. Pull the dryer out and disconnect your venting from the back of the dryer. Turn your dryer on and check to make sure your dryer is blowing air out of the dryer duct. If it is then leave your dryer out at least 2 ft from the wall and run a load of clothes through the dryer. If it dries your clothes normally then you have a venting restriction. Check to make sure your venting is clean, not kinked or smashed, make sure your outside vent is opening an doesn.t have something blocking it. Check your lint screen filter by running water through it. If water is not flowing through it, you have a build up of fabric softener on your screen, blocking air flow. Scrub your screen off and test again. Good Luck, Appliance Specialists
Dec 30, 2009 | Whirlpool WED9200SQ Electric Dryer
Maytag Neptune MDG 5500 AWQ heats sporatically
your dryer has a safety feature that it will not run or heat when the door is opened. It is so no gas fumes are exhauseted into your home. Once the safety is engaged, It will not allow the dryer to restart for a short while. It should clear itself after only a few minutes. Hope this helps, good luck.
Apr 18, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Dryer takes forever to dry clothes
firstoff, youll need to check for a clean not kinked vent, mosttproblemswith "too long to dry are genrelly tracedback to innadequate/poor venting"
Jan 26, 2009 | Whirlpool Dryers
Dryer not drying
Check your lint filter. Put it under running water to see if the water goes through it. Chances are it is clogged up. Wash it and put it back. Should do the trick.
SGt 48
Jun 18, 2008 | Roper Dryers
My clothes are not completly dry when I dry them for about 56 minutes.. at times I have to dry my clothes as much as 3 times to get them dry I have tried putting less amounts in with no luck. It seems to...
Reset your two circuit breakers. Check all vents and vent lines. Check your lint filter and its receptacle. Is all the water being spun out by your washer first?
Dec 16, 2007 | Whirlpool GEW9250 Electric Dryer
Maytag PYE2300AY Electric Dryer Logo
162 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
