Question about HP Compaq Presario SR1830NX PC Desktop
Computer was shut down incorrectly and now i cannot get past this
The page comes up "sorry for any inconviences but your computer was shut down incompletely or more aless it didn't run its course to properly shut down. It gives me a few options of having the computer go back to known source before this happened..I pressed each one of them and nothing happens and it just goes round and round..please help!!!!!
  • 5 more comments
  • lexismommie Jan 30, 2009
    I am getting the Error Code SR1830nx..I have followed the directions on HP help and they have not helped. I cannot get to anything since when the computer starts up, I can't get into any files on my computer to scan the computer or anything. It goes back and forth from the black screen that shows the Error Message to the Compaq red screen. I am using Windows 98.
    Hi Camm171, thank you for your interest in helping me. The error code is HD521-2W. I cannot access Windows 98. When I initially turn my computer on, its the black screen with the error message. Then it goes to the Windows 98 screen and then to the Red Compaq screen and does this continuously.
  • lexismommie Feb 03, 2009
    Camm171,
    Thank you for your advice. I am very grateful there are great people out there, as such as yourself, that help those of us that are not computer wizards. I know I put that I have Windows 98 however I have Windows XP but sure this will not make a difference of the outcome. I do have the backup discs for my computer but scared to really do all that since I don't want to mess it up even more. Again, thank you for all your help.
  • lexismommie Feb 05, 2009
    Hi Chetangupta,
    Thank you for all the information. Unfortunately, I cannot type anything in the computer since it will not give me that option. It goes back and forth from the black screen to the Compaq red screen and continuously does that. Thanks for your help..:)
  • lexismommie Feb 06, 2009
    Camm171,
    Thank you for the information. So I am putting in the XP system disc? Is this a disc that would have come seperately then the disc that I have that was made for my computer? Sorry for all the questions but I want to make sure I am putting in the correct disc. I appreciate all your help.
  • Bryan Cammarata May 11, 2010
    what is the error code?? can you get into windows 98 at all? you must be a bit more specific.
    please be specific on what operating system , and messeges are being displayed..
    Problem Solver:
  • 16 Answers
Lexismommie,
I'm afraid the solution is a bit technical. You will have to make or get, a Windows98 startup disk. This will allow you to "boot" into the system and do a repair. If you don't have this, then your other recourse is to use the cd's supplied with the computer and do a restore. The last choice is to get a windows98(2nd edition) and rebuild the whole system. In any case the possibilty that you can recover fully is not good. The likely hood of your hard drive being currupt or bad sectors is very possible, and you may have to bring the pc to a qualified technician.
Posted on Jan 31, 2009
  • Bryan Cammarata Feb 06, 2009
    lexismommie,
    You have XP? thats better! If you have the XP system disc you can do a repair. Install the disc in CD (dvd) reader. Restart the computer. It will start off the cd -> hit any key to boot off CD (hit enter) , after a period of time it will ask if you want to repair, enter no, it will continue to load, again it will look for an installation of XP on your computer, this time enter REPAIR, XP will reload onto the old installation and repair the installation. Before you do all this make sure you have the XP key handy (located on a microsoft tag on your computer.). it will take 30 min to 1 hr to reload. Your computer should be ok then.
    lexismommie,
    Yes the disk should say Compaq system disk (sometimes there are two disks 1, to confirm it is a Compaq, the other to install/repair the system). Remember after you see the initial installing Windows XP screen, by pass the first repair option, continue on until you see Windows has found an installation of XP, do you want to repair or remove.. SELECT REPAIR.
    If you do not see that option.... Repair is not possible, your only recourse is to reinstall XP (you will loose all previous data). I suggest you "google" Repairing XP, and read an article to fully understand the process. Hope this helps you!
  • 139 Answers
Scan ur system with mcafee 8.5i antivirus and go to safe mode and login to admin account.
Start->run-> msconfig->startup (tab)->disable all->restart-> see the message is gone.
Posted on Jan 30, 2009
  • Chetan Gupta Feb 05, 2009
    From any other system go to the following link.....
    http://www.sophos.com/support/disinfecti...
    In the above link you need to download emeregency copy of SAV32CLI.exe file and the relevant ides to one folder. Extract both the file in that folder. Rename that folder to sav and burn to a disk.
    This is going to work 100% trust me. Boot your system with windows xp cd. One the first screen hit enter that is your recovery console now your in cmd prompt.
    C:\
    now type as I have written here where g drive being ur cd drive.
    =one space bar
    =press enter
    c:\ cd\
    c:\ cd g:\
    g:\cdSAV
    G:\SAV\SAV32CLI -REMOVE -P=C:\LOGFILE.TXT
    AND WHERE IT SAYS VIRUS FOUND HIT A KEY AND ITS GOING TO SCAN YOUR SYSTEM WITH ALL VIRUSES AND SPYWARE AND MALWARES, YOUR SYSTEM WILL SURELY WORK AND YOU DONT NEED TO RESTORE ANYTHING.
    ANY PROBLEM TELL ELSE HAVE A CHAT I WILL HELP YOU FIX THIS ..........
    HAVE A GREAT DAY.
Computer shuts down when loading garmin software
you said the computer just shuts off and restarts? it sounds like the software is making the operating system (windows) unstable and crashing it all you can do for your computers sake is not use that software on that pc sorry to have say it, but hope this helps and good luck
Feb 03, 2012 | HP Computers & Internet
Im trying to put in my power button on my hp 60 230 us notebook pc
Power button board 496830-001
1. Shut down the computer. If you are unsure whether the computer is off or in Hibernation, turn the computer on,
and then shut it down through the operating system.
2. Disconnect all external devices connected to the computer.
3. Disconnect the power from the computer by first unplugging the power cord from the AC outlet and then
unplugging the AC adapter from the computer.
4. Remove the battery (see "Battery" on page 4-7).
5. Disconnect the wireless antenna cables from the WLAN module (see "WLAN module" on page 4-15).
6. Remove the keyboard (see "Keyboard" on page 4-17).
7. Remove the keyboard cover (see "Keyboard cover" on page 4-20).
Remove the power button board:
1. Remove the two Phillips PM2.0x4.0 screws 1 that secure the power button board to the keyboard cover.
2. Remove the power button board 2.
Here is the service manual: See page 4-22
http://h10032.www1.hp.com/ctg/Manual/c01602064.pdf
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
Feb 01, 2011 | HP Computers & Internet
Vostro 200 PC freezes on Dell Start up page & won't turn on
If you have windows 7 installed, then see if you can boot to the DVD and run a repair on the OS. You also may want to run a diagnostics on the system if you can get to the F12 menu
Feb 27, 2010 | Dell Vostro 200 PC Desktop
My Gateway computer shuts down ramdomly. This
Listen for fans coming on, as this sounds like overheating issue. If fans kick in and then stay constant or dont work at all.
The link is for Notebook hardware control, this will monitor the temp among other things (only reference as a guide any software can give you an indication but not exact temp) Generally if a laptop hits 90c it will auto cutout to stop major hardware failure normal running temp (40-55c upwards depending on use) http://www.pbus-167.com/
If the machine is overheating it could be due to blocked vents, faulty heatsink, fans not working or incorrect fitting and thermal paste.
In all honesty if this is due to overheat problems, as the machine has been cutting out my strong advice would be to do all the above ESPECIALLY re-apply thermal paste (arctic silver5) to cpu, it takes about 100-200 hours of use to start to work 100%.
hope this helps, let me know if i can be of further help
Nov 06, 2009 | Gateway T1623BU 14.1" Notebook PC PC...
Keeps turning off
Sounds like a hardware failure. Possilbly the motherboard, more than likely, the power supply.
But then - maybe neither.
Shut it off completely, once you restart, start hitting the F8 key ( once a second ) until you see the " Safe Mode" choices screen. Drop down and select the " Last known Good Configuration" option and hit enter.
If this doesnt work, try the same proceedures ( restart - F8 ) but this time select safe mode - at the top of the list.
If you sucessfully boot in safe mode, you have a system file problem that could be virus related, file table corruptions or registry problems or all combined.
We're here if you need us.
www.wvpcrepair.com
Oct 10, 2008 | MSI PT880 Neo FSR Motherboard
Blackhawk down problem
http://www.trap17.com/index.php/internet-explorer-http-error-500-glitch_t31112.html go to this web site u would get some infor mation (OR)
  1. The multiplayer is team vs team, or is it co-op mode where people team up to ... Started to update to 1.08, it checks files until wheeled.pbo and then comes " ...
    being that its a multiplayer demo, does that mean dedicated servers can be ... it but i remember seeing a page where a player with a GeForce 4 could not open ...
Sep 14, 2008 | NovaLogic Delta Force: Black Hawk Down...
HP Compaq Presario SR1830NX PC Desktop Logo
414 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
