Question about McCulloch 13HP 338 Cc Portable Generator # FG6000MK
10 kw deisel generator in sailboat suddenly stopped generating,
Kohler gen set suddenly stopped generating after no problems for several months. Where would I start trouble shooting? We are a family of four in a sailboat in the southwestern Caribbean with poor access to help...
  • Jim London
    Jim London May 11, 2010
    Hi, You say it stopped generating, does that mean it starts and runs but puts out no power? We will also need a model number if you can find one. Do you run all from one circuit or do you have multiple circuit breakers? Is this a portable you carry on board or is this a marine genset?
    New Friend:
  • 32 Answers
Dear, hope you are lucky. Maybe you can get help from this article. Why Diesel Generator Fail to Start
Posted on Oct 11, 2017
    New Friend:
Yes I've not used it for a while and can't remember how to start the thing
Posted on Jun 18, 2013
    President:
  • 1,714 Answers
Are you still looking for help with your Gen. ?
Posted on Jul 04, 2009
Gen runs when switch in auto even though power avail. Tried resetting ATS - waited 30 min. No luck. Only way to turn off is to move switch to stop/reset. Any ideas on what is broken?
have an electrician check the relay that is activated when the utility power fails
that is what starts the genset when it is in auto
it should also stop the get set when utility power comes back on
Nov 03, 2015 | Kohler 17RES 17 kW Generator
I have a Kohler 12.5 KW marine generator on my houseboat that has a problem I was hoping you could help me with. Specs: Kohler 12.5 KW 79 CID 23HP Mfg date 9-10-96 Gen Engine Serial # 06919 L-29-R
there are some magnets behind the flywheel to cause the battery charging system to recharge the batt. sometimes they come unbonded/loose from the flywheel and cause the engine to become hard to turn. I would start there first.
Apr 03, 2013 | Cars & Trucks
I have a Kohler 12 RES home standby generator. Once in a while when the power goes out the generator will start and then immediately shut down with no fault codes. When I flip the control in the unit
Check the inlet fuel pressure, on exervise there is no load, when power is out it is loaded and demands more fuel. Also check for bugs blocking gas regulators vents etc
Nov 12, 2012 | Kohler Generator. 12 kW and 14 kW Home...
I have and old model #10RY6Z 10 KW Kohler Generator used for back up on a solr system that over speeds when we try to run it without to solar panels hooked up. What is
Your problem is mag pick up, or possibly the solar panels are reverse powering the generator, if the home consumes less than solar output
Oct 29, 2012 | Kohler Electrical Supplies
My gen starts and runs for 1 min or so then dies restarts then dies again and again. if i start it under load ( turn on air con) it will run for 10 min then die allen
Is there a fault?? All UL listed generators including Kohler are required to lockout on a fault on shut down. This really sounds like a problem with your 2-wire auto start connection between your automatic transfer switch and genset. RDT model automatic transfer switch it is the 2 middle wires on the green connector and terminals 3&4 in the generator. close to run and open to shut down. Any open at any time will cause the unit to shut down. The 12 will shut down instantly upon an open because your 5 minute cool down is built into the transfer switch.
Jun 27, 2011 | Kohler 12 kW Emergency Power System -...
The monitoring system of our Kohler propane generator has sent a "UU" message. What does this mean as it causes the generator to shut down 10 seconds after starting? Also how can this be...
The monitoring system of our Kohler propane generator has sent a "UU" message. What does this mean as it causes the generator to shut down 10 seconds after starting? Also how can this be corrected?
May 28, 2011 | Kohler 12 kW Emergency Power System -...
I have an 18kw kohler generator. the unit is aprox 10 years old...has about 150 hrs on it. over the weekend, when the power was out, it was running just fine when all of a sudden the ford engine...
change the temp sensor and re test the gen set these have a bord that senses if theirs a issue with the engine and will cut the bower to the get head so theirs no load on some mod's then when the temp reaches a higher point they shut down. re-post is this does not fix the issue i will review the books on the unit.
hope this helps
Aug 09, 2010 | Kohler 18RESL 18 kW Emergency Power...
UU undervoltage kohler 20kva
call koler but ui think is meant high heat as in the thermal circut is shuting you down or low oil
could be a couple of things best bet call kohler
Aug 06, 2009 | Kohler 12 kW Emergency Power System -...
McCulloch 13HP 338 Cc Portable Generator # FG6000MK Logo
347 people viewed this question
Top McCulloch Electrical Supplies Experts
John Trevino
Roland W VanLue
Roland W VanLue
Are you a McCulloch Electrical Supply Expert? Answer questions, earn points and help others
