Question about Goodman CKL49AR49 Air Conditioner
Bryan A/H FA4ANF048
Is this a heat pump? Need to replace the thermostat
  • 56 Answers
Yes it is a heat pump
Posted on Feb 13, 2009
Step by step on how to replace a dodge stratus 2005 water pump and Thermostat.
i hope this helps for the water pump. The thermostat is located at top of engine simply follow upper hose to engine and remove housing and replace thermostat.
Jul 03, 2016 | Dodge Cars & Trucks
I have a Carrier heating unit in my attic ,
zone controller might be stuck seek help from service co.
Mar 25, 2015 | Carrier Heating & Cooling
My gas furnace and heat pump runs at the same time???
its likely the outside control unit board its supposed to only kick on gas only when the temp is at freezing..
or
the inside thermostat is not selected for heat pump, open it an look at the jumper / switch.
or just replace the thermostat , then return it saying you couldnt figure it out. :P
there are a lot more variables here after that you cant know how to check.
Nov 05, 2014 | Honeywell VisionPRO 8000 Programmable...
Armstrong Concept 12 heat pump blows warm air when the thermostat is set on cool
likely in the configuration need to change when the reversing valve is energized. sometimes energized when in cooling ,sometimes when in heating. whatever yours is on its likely the opposite.
Nov 12, 2017 | Heating & Cooling
Installed a RTH2310B to replace an older model honeywell. All wires do not match. only 3 do r, w1, and g do and o and e do not. what should i do?
The Honeywell RTH2310B is a standard thermostat and is not compatible with a heat pump system. The terminals O and E are for a heat pump system. I am assuming that the terminals you described that do not match are from the old thermostat. What you will need to do is get a heat pump thermostat. Sometimes it can be hidden within a lot of other descriptions on the front of the box, but it will say heat pump and either 2 heat/1 cool or 2 heat/2cool. You should just need the 2 heat/1 cool heat pump thermostat. Hope this helps.
Aug 17, 2010 | Heating & Cooling
I have a Trane heat pump, model #TWP060C300A and a Trane air handler, model #TWE065E130A. Heat pump is 5.0 ton, split system. Air handler has a variable speed motor and a 20Kw 3-phase auxiliary heat strip....
Honeywell Chronotherm thermostats have always had a great reputation for longevity and reliability. They are also much more user-friendly than the other types of programmable thermostats out there. Make sure you get one that states 2-stage heat, heat pump. T8611G will offer that for you. There are many out there that claim to be suitable for heat pumps; however, they do not have the ability to utilize your auxiliary heat strips (2nd stage of heat).
Before you attempt to replace, be sure to write the wire colors and their corresponding terminal marking on a sheet of paper........of your old thermostat. This is very important to make it easier to hook up the new thermostat. Also, before you disconnect the wires, be sure to shut off the circuit breaker to your air handling unit. You can ensure you have the right one by putting the fan switch in "ON". When you turn off the right breaker, the fan will stop running. :-)
I hope you find this information to be very helpful to you. Please don't forget to leave a rating.
May 09, 2010 | Honeywell Programmable Thermostat Heater
Just moved in. Trying to figure how to set thermostat so actual heat comes out. I have tried everything. Only cool air comes out and the House temp stays the same...Cold. Carrier Model No. FA4ANF048.
You have a problem both on the inside unit as well as the outside unit.
The outside unit is not coming on due to a failed contactor relay,bad capacitor or low refrigerant. The inside E-heat is not coming on because of a failed heat sequencer or limit switch.
If you have tools and a volt/ohm meter I could walk you through it.You would be dealing with live high voltage as well as low voltage.
If not.
The problem will require a local HVAC technician.
Dec 22, 2009 | Heating & Cooling
Want to replace manual thermostat with programmable.
you can use a 5 wire heat pump thermostat.
Must be heatpump thermostat
red is 24 volt power
white is aux/emergency heat these usually will need to be jumped together
Green is fan
yellow is compressor contactor
blue is reversing valve
you just don't have a common so some thermostats will not work.
get one with batteries
Dec 13, 2008 | Honeywell Programmable Thermostat Heater
Goodman CKL49AR49 Air Conditioner Logo
431 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
Paul Carew
Tim Whalen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
