Question about Philips 47PFL7422D/37 Television
I have a philips 42in LCD TV and am trying to connect to it through VGA connection. All i get is blue screen and video not supported
    Sergeant:
    Champion:
  • 267 Answers
IT IS TELLING YOU YOUR VGA INPUT SET UP IS INCOMPATIBLE. IS THIS A COMPUTER YOUR HOOKING UP?
IF NOT USE YOUR HDMI INPUT OR COMPONENT INPUTS.
Posted on Feb 06, 2009
Still wont connect iomega screenplay 1tb media player with philips universal need different programming code.???
Mine is the same problem too cant connect Iomega Screenplay-director with my Philips 32pfl LCD with hdmi though composite connection works.....with hdmi its just blue screen which says video mode not supported....
Sep 10, 2011 | Iomega ScreenPlay
I have a tosihba a205 s5000 laptop and a philips 42in lcd tv. i bought a hdmi to dvi with a dvi to vga adapter, hook it up and the laptop senses the philips but the tv says no signal
on your laptop locate the FN button and then on your key someplace there is a picture with a light screen and dark screen on it hold FN and hit that button it alternates the video feed from your monitor to the tv, then to shut it off hold FN and hit it again to switch to the monitor
Aug 02, 2010 | Computers & Internet
Trying to connect laptop to Samsung HD LCD TV using VGA cable.
I had the same problem with my Samsung series 6 32" Lcd. After many hours of trying different settings and banging my head on the wall I found the solution. What the problem is your VGA cable not supporting the high resilotion of your Samsung TV. The simple solution is to buy a new VGA cable that supports HD. Take a look at this site you need something like this one! Hope this helps.....C
http://www.clearly-av.co.uk/PGM1110.html
Sep 19, 2009 | Philips 32PF7421D 32 in. LCD HDTV
VGA Connection Not Working
Before connecting your HDTV to the laptop you must go to your display drivers options in Windows and add "the external device" i.e. HDTV. If the onboard video is capable of providing this function it may require you download drivers to support the extra device. I believe you may have to make an adjustment in your laptop BIOS to enable external viewing also the amount of memory to dedicate for this function. I hope this helps.
Mar 14, 2009 | Compaq Presario M2000 Notebook
Trying to hook compaq presario laptop to philips lcd digital tv
hey fox,
sounds to me like a connection problem. If the compaqs output is vga, you need to convert the input (tv side ) to hdmi, component, s-vidio... what ever you can find. Typically when you hook up your computer to a flat screen or such, its best to try to use the hdmi ports or the rpg. But if thats not available you need to take the outout from your laptop ( whatever type that might be and input it into your flat screen tv. If you input laptop into tv under ( eg..HDMI) then when you VIEW it you need to select the correct source on your flat screen. Such as hdmi or pcmi or rpg.I know that the do sell alot of cables that adapt from one type of connection to another. Typically only one cable is required from the laptop to the flat screen. If you think about it you are only using the flat screen as a monitor.
Feb 14, 2009 | Samsung LE32R74BDX 32 in. HD-Ready LCD...
Philips 42" HDMI connection to VGA on laptop connection problems
why dont u just use the vga input and select vga from your input selection. it should work just fine. if not, email me back.
Feb 10, 2009 | Philips 52 In. LCD HDTV
How to connect acer aspire mini laptop to digital lcd tv?
You get the audio from PC: you must use a separate audio cable to your TV audio input.
Configure your PC Display properties to a lower resolution until you reach a format your tv can display.
If you use a flat digital screen check the manual to know the resolution to be used with VGA input.
Use Dual screen option or swittch main screen/external/both using FN key + blue key showing screen on your keyboard. (F4 or F7? check manual.)
Jan 07, 2009 | Acer Aspire 5100 Notebook
Hot to connect acer aspire mini laptop to digital lcd tv?
Press the Blue function key and toggle the screens. You can view, the Laptop, the Laptop and Screen, or just the screen.
Also you will need to flick through the channel button on the TV to get to the PC interface. Since you indicated you were using a VGA cable, this is likely the missing element.
Note: The VGA cable does not carry audio, you either had a separate audio interface to the TV or you were using RBG/Composite/S-Video/HDMI. So check to make sure you are using the correct cables.
Connecting my MAC to my LCD TV!
Do you have a DVI port on the LCD screen? Please tell me what connections you have on your macbook and your TV. There may be a converter.
Normally HDTVs can only be hooked up through S video or DVI Depending on your video card.
Oct 24, 2008 | Philips 32PF5321 32 in. HD-Ready LCD...
Philips 47PFL7422D/37 Television Logo
127 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
