Question about Lexmark Wheelwriter 5 Series II Typewriter
Some letters do not work on IBM Personal Wheelwriter 2
Some letters work, tried changing the wheel but this does not help.
The letter n was the first to stop working.
  • Lexmark Master
  • 3,594 Answers
The keybuard probably needs replaced.
Posted on Feb 16, 2009
How do I change the size/font of the letters? Bold and underline too?
To change font and pitch, you need to buy a different printwheel. machines came with a prestige elite 12 printwheel. Prestige elite has small letters and 12 puts 12 charactors per inch. Letter gothic is larger size letters. Google search for ibm wheelwriter printwheel, also called a daisy wheel.
Mar 03, 2016 | IBM Wheelwriter 30 Series II Typewriter
IBM Wheelwriter 2, the bottom half of the letters are not printing. It is not the ribbon because I have changed it out.
Two things come to mind for this problem. First try pushing down firmly on both ends of the black rubber platen roller. Sometimes the black plastic latch on either side may break causing one side of the roller to lift up causing partial print. The other possibility is the ribbon is not lifting correctly. A technician can adjust the ribbon lift. After typing a few letters, take the ribbon out and look at the letters on the ribbon.Are they in the middle of the ribbon or are they at the top or bottom of the ribbon? middle of ribbon is correct.
Mar 01, 2016 | IBM Lexmark Personal Wheelwriter 2...
My print wheel is typing any letter but the one I hit
Is the Daisy Wheel installed correctly? If so, Maybe it's time to buy a computer.
Oct 27, 2015 | IBM Personal Wheelwriter 2
The letters A,S,D, F, and K,K,L,: will not type
You more than likely have a bad keyboard. You can try to unplub the two keyboard connectors that plug in to the function board and then replug back in. If that doesn't work, then you will need to have your keyboard replaced.
Apr 06, 2014 | IBM Lexmark Personal Wheelwriter 2...
Ibm wheelwriter won't strike. Ribbon is good. Wheel is working. Carriage is moving. Just not striking. I dusted & cleaned as well as I can but to no good.
May 10, 2010 | Office Equipment & Supplies
Wheelwriter 3 Selector Assembly
The selection motor bearings just right of the print solenoid get dry a little WD40 on the front and rear bearings usually takes care or this.
Dec 14, 2009 | Lexmark Wheelwriter 3 Typewriter
IBM personal wheel writer 2, wrong letter is typed
Try code "L" it will get you out or the language mode
May 11, 2009 | IBM Office Equipment & Supplies
Look at the ribbon and see if the letters are on the very top of th ribbon. If so on the front of the carrier there is an eccentric screw for adj. ribbon height. Loosen the lock nut W/ a small 9/32 wrench and adj screw to raise ribbon. Be sure to check L/O with the underscore as you can get it to high.
Jul 02, 2008 | IBM Wheelwriter 30 Typewriter
Lexmark Wheelwriter 5 Series II Typewriter Logo
118 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
