Question about Dell Dimension 8200 PC Desktop
8200 Dell Dimension Password
I have never had a password on my system at the BIOS level. The computer is giving me a dos prompt and asking for a password or to select control enter to not use a password. I do not have a password. The computer has been idle for about 6 months. Do you have any suggestions?
  • Dell Master
  • 1,183 Answers
Follow the instructions , on the link below , to clear forgotten passwords
Posted on Jan 30, 2009
  • Mandeep  Singh
    Mandeep Singh Jan 31, 2009
    Kindly rate the solution , if it helped you with the problem
How can i have the password bios of laptop dell E6420
f you are running Dell servers, it is recommended to enable BIOS password. This is will prevent accidental changes done to Dell BIOS settings by others who get physical access to the server.
You can setup two different types of passwords in Dell BIOS:
System Password: This will be prompted before the system can boot up, and load the operating system.
Setup password: The system will prompt for this password only when you are trying to access the BIOS settings.
Depending on your situation, it might be a good idea to enable both the system and setup password at the BIOS level. I recommend that you at least enable BIOS password.
Press F2 for System Setup
When the Dell server is booting up, press F2 to start system setup, from where you can change Dell BIOS settings.
BIOS System Security
From the Dell BIOS main menu, scroll down to "System Security" and press enter.
Password Not Enabled
From here, you can see that both the System and Setup password is not enabled by default.
Enable System Password (and Setup Password)
Scroll to "System Password" and press enter, which will prompt you to enter the password that you like to set for the system. Please understand that if you set this password, you have to enter this password everytime you start the system. Do the same thing for Setup Password.
Don't forget this bios password. If you forget, then you have go through the painful process of resetting the Dell BIOS password.
Password is Enabled
Once you've enabled both the password, from the "System Security" menu, you'll see that that both system and setup password is enabled as shown below.
password is set
System Password Prompt (During Startup)
From now-onwards, anytime you start the system, it will not load the operating system, unless you specify the system password as shown below.
Setup Password Prompt (To Access BIOS)
If you press F2, to get to the BIOS, it will prompt for the setup password as shown below. If you don't enter a valid password here, you cannot access the Dell BIOS settings anymore.
Dec 16, 2014 | Dell Latitude E6420 Laptop Computer...
How do i chnage bios on dell dimension 4700
start computer with tapping f2 key, you will be directed to bios screen
and there you will get an option to default bios
Aug 11, 2011 | Dell Dimension 4700 PC Desktop
Keep getting checkpoint errors, and have changed Sys Battery , reset Bios and when i boot it ,it goes to Dell logo and keeps trying to reboot. Windows will not load.
Try going to the BIOS and see if it reboots from there. If it does, then it is most probably a hardware problem. You can try re-seating the memory modules and If you have multiple modules, try them one at a time.
If it does not reboot while you are in the BIOS, then the problem lies on Windows. Get your DELL Restore CD or your Operating System CD and insert it to the CD-ROM drive. Reboot the computer and press F12 while seeing the Dell logo, that should give you the options to boot to CD-ROM. It will give you a quick prompt of "press any key to boot to cd..". Make sure you press the space bar during this time to initiate the boot from CD-ROM.
Once the Windows Setup loads, Choose "Recovery Console" to repair your computer. Just choose the installation you would like to repair (normally it's number 1) then it will ask you for the administrator password. By default, the password is blank, but if you set a password for admin then use that password.
Once you get to the prompt, Type this command. "CHKDSK /R" (without the quotes). It will initiate the repair for your OS. This might take an hour or so. Just wait for it to finish and it will automatically reboot your computer. Let the computer computer reboot normally. You should be able to get to your normal windows screen back.
Good Luck.
Nov 10, 2010 | Dell Dimension 4600 PC Desktop
Start computer up asks me for password then it shuts down what is going on? It won't stay on.
computer loads basic system files threw the bios (Basic input output system) When the user set's a bios password it will not load the windows environment or win loader files until the bios password is entered. if you see a black window asking for password your seeing a bios password prompt.
Manny people buy computers aftermarket or used and cannot get past this. best tip is open the tower and pop the bios battery out and reboot with it out. go to the bios setup window and disable security now, put the battery back in and you will not see the password prompt again. if physical access to inside of tower imposable then we stop here.
If the password is a windows login prompt you will have to login safe mode to disable the faulty driver causing the issue.
once windows loads go to start then run and type msconfig then press enter. you will see microsoft configuration window and will go to the services tab at the bottom put a check in hide all microsoft services, now uncheck all the ones left and make sure the checkmark is on before doing so. this is goingto allow windows to load normally without third party drivers and you can fix the problem by enableing them till it fails to boot again.
Aug 12, 2010 | Dell Dimension 2350 PC Desktop
Need cmos jumper location on Dell Dimension 8200 to bypass bios password
From what I can gather, you just need to locate the jumper labeled PSWD and remove it. Turn computer back on, then back off. Replace jumper pin and turn computer back on. That should do it. Removing the jumper disables password. Turning on computer resets it. Replacing jumper re-enables password capability.
Jul 17, 2010 | Dell Dimension 8200 AUD System Board...
Dell Laptop BIOS password recover
Thank you for using
FixYa for your problem
A reliable method can be found here:
look for Password recovery.
Try the backdoor password Dell
: all bios passwords can be removed easily,
: 1-create a dos system disk,
: 2- copy "debug" (this is a dos command found in windows\command directory) onto the system disk you created,
: 3- boot the machine with this disk,
: 4- at dos prompt type: debug then enter, you will see a blinking dash
: 5- type: o 70 2e then enter, (also seen: o 70 18)
: 6- type: o 71 ff then enter,
: 7- type: q then enter,
: 8- remove the floppy and reboot! Power the system off and on by unplugging and re-plugging the system into the power outlet
Please rate our solutions and if you still have problems please call back for more ideas to help you
Richard Scott
Technical Support
New Zealand
Nov 19, 2009 | Dell Computers & Internet
You need to find a BISO/CMOS password reset tool, try googing them.
Apr 27, 2009 | Dell Latitude D600 Notebook
System password error
This password thats its asking for is upon first boot I assume before windows even trys to load. If thats the case theres a jumper on the motherboard that lets you reset the bios/cmos killing out the password and setting it back to factory stardards. You will have to goto and hit up there support section for a manual on were exactly its located but this will fix your password issue.
Mar 19, 2009 | Dell Dimension E310 PC Desktop
Dell Dimension 8200 PC Desktop Logo
132 people viewed this question
Alun Cox
