Question about Philips 190B6CB/27 19" LCD
How do I dismantle a Philips 190b Monitor casing?
I have removed all the visible screws and the bottom part of the casing will lift slightly but then will not move any further.
  • 18 Answers
SOURCE: Cannot remove the Brightness window that pops up
Press and hold the menu button for 30 seconds
If it doesnt work call your H/w vendor
Posted on Aug 28, 2009
  • 112 Answers
SOURCE: HP 1702 Case Removal
Keep prying. Plastic clips are strong. You won't break it, maybe a clip or 2. LCD is in a steel case inside. The outside plastic is only for looks.
Posted on Mar 17, 2009
imran_usa9
  • 13 Answers
SOURCE: Philips 190B - flickering screen
Its looks that Inverter board not work well for CCFL cus a CCFL inverter is a device (an inverter) for providing drive power to a Cold Cathode Fluorescent Lamp CCFL
Posted on Jun 17, 2009
  • 4 Answers
SOURCE: 190b Philips monitor and the volume bar keeps
change task bar properties...otherwise intall monitor software cd..
Posted on Mar 13, 2010
How do I remove the plastic shield over the grinder on saecco Vienna
a) Remove the water tank and the coffee bean container cover.
b) Remove the two fixing screws of the coffee bean container.
c) Remove the housing screw under the water tank (Torx/T10).
d) Remove the housing screw under the coffee bean container.
e) Remove the two bottom housing screws . Pull the housing left of the electronic system slightly forwards and lift.
f) Move the upper housing slightly to the left so that the notch of the steam dial is visible on the right side of the machine. Release the steam dial using a sharp object and remove.
g) Remove housing and pull water hose off.
May 02, 2014 | Saeco Vienna Espresso Machine
Tip
Miele W1613 Drain fault and code F51
My machine limped along for a few weeks with an intermittent drain fault and then threw in code F51 occasionally. The F51 code is a water inlet fault, suggesting that water isn't filling the drum to the correct level. Clearly the first thing you need to do with these faults is check the obvious.
Drain fault:
Is the drain hose and drain filter clear?
Does the pump sound like it's running?
Is water actually being emptied?
F51:
Is inlet water pressure ok?
Is the inlet water filter clear?
Is water actually filling the drum?
In my case there was no suggestion of an obvious fault. So what makes the machine think there's a problem with water entering AND leaving the drum? It's the water level pressure sensor. The sensor itself is at the top of the machine, but a pipe connects it (via a small plastic chamber) to the very bottom of the tub. Water entering the tub rises in the pipe, thereby altering the pressure of trapped air and telling the machine when to stop filling or draining.
After dismantling the machine and removing the big hose connecting the bottom of the tub to the pump the sensor pipe is visible through the hose hole, which is quite large. So this pipe is in a good spot for collecting gunge and if it gets blocked it's a problem. Clean it out with an old toothbrush or whatever, while trying not to push it further up the pipe.
You should get some compensation for this effort when you empty the coins out of the hose you removed!
So I said 'after dismantling the machine' like it was child's play. It is pretty easy actually.
Open the door. Disconnect power.
Start with the lid. Two screws at rear, one each side under screw covers. Grip lid at front and lift up. It can be a bit stuck so give it a tug.
Remove powder draw.
Lift control panel away from front panel and lay on top of machine. You don't need to disconnect anything. Now you'll see the top of the sensor pipe.
Remove drain filter to empty any water in the bottom hose.
Remove - two screws at the top of the front panel, two screws either side of the door lock, one screw just below the door.
Lift the front panel off of the retaining pegs and pull away as far as the door seal will allow. Pulling away the top of the sensor pipe gives a bit more movement.
Now you can either remove the door seal and take off the front panel, or do as I did, which is just move it slightly to the side, giving access to the screws of the left hand side panel. Remove all screws for the left panel and it's easy to get off.
Now you have good access to the pump and bottom hose. The bottom hose has two clips on the tub end, but only the top clip needs loosening to remove from the tub.
Remember to mop up any water from the bottom tray when finished or you'll get a flood fault.
on Oct 10, 2014 | Miele Washing Machines
LCD screen totally white when turn on
The HP is a flat screen monitor used with many desktop computers. When the LCD on your HP monitor goes white, it is an indication that your monitor's inverter board has gone bad. The inverter board is a small circuit board that transfers power from the monitor's main circuit board to the LCD screen. Replacing the inverter board means dismantling the HP monitor.
1. Power down your computer and unplug the HP monitor cable from the back of your desktop. Disconnect the power cable from the back of the monitor. Relocate the monitor to a flat work surface. Place the monitor with the screen facing downward.
2. Remove the Phillips-head screws from the monitor's base stand and from the back cover. Lift the base stand off of the monitor and remove the back cover. Peel away the foil from inside the monitor around the internal circuit board.
3. Locate the inverter board near the bottom of the monitor's casing. Unplug the power cables from either side of the inverter. Loosen the Phillips-head screws from the inverter board. Lift the old inverter out of the monitor's casing and set it aside.
4. Place the new inverter inside the monitor. Replace the Phillips-head screws and fasten it in place. Reconnect the power cables to the connectors on each side of the new inverter. Replace the foil around the outside of the main circuit board.
5. Replace the back panel and base stand, and their retaining Phillips-head screws
I hope you find it very helpful.
Thank you for choosing fixya.com
Aug 11, 2011 | HP Computers & Internet
I have tried to open the case of ViewSonic VA1930WM LCD monitor. I have removed all visible screws and released all clips around the side. However only the front "frame" releases and is loose...
These units are more of a challenge to get open than most monitors. Here are the steps:
remove all cords - power, VGA/DVI speaker
remove stand - pull off hinge cover and then remove 4 screws
2 screws at bottom corners of case.
Now comes the fun part.
On the bottom edge there are 2 slits on on each side of the monitor about 3-4 inches in from the side. Use a small flat bladed screwdriver inserted in this slot to pop the two halves apart. Once you get a small gap just work your way around the entire monitor until the case halves are released from each other, but don't pull them apart yet. When opening most monitors the front comes off first but on this one the back case comes off first. You will need to again use your flat blade screwdriver inserted between the two case pieces and under the LCD panel and gently apply pressure. At the same time you will need to pull one end of the back case away from the panel, there are two plastic catches on each end that hold the panel inn the back case. One end will release then the other sould come right out so you can remove the back plastic case from the electronics. Now to get to the electronics you will need to remove the two screws on each end of the panel that hold the metal RF shielding in place. Also there is a screw in the center at the bottom of the panel that will need to be removed. Next unplug the 4 backlight power plugs. Slightly lift the shield so you can get to the flat ribbon cable going from the driver board to the panel. It will unplug from the panel by pressing in on the two release tabs, one on each end of the plug. Now you can get to the electronics. I am guessing you are having power issues with the unit. Check here for power supply repair kits if you need to get parts for your unit.
http://www.ccl-la.com/catalog/product_info.php?cPath=21_34&products_id=168
I hope this helps you get the case off, if so please rate my solution.
BuddyMc
Aug 04, 2011 | ViewSonic VA1930WM LCD Monitor
How do I remove the case from my Samsung Syncmaster t190 monitor? I removed the screws from the stand, but I can't get more than the bottom loose.
my daughter's 3 year old SyncMaster T190 monitor developed a fault last week -it switches on ok, perfect display for about one minute, then the screen goes blank. It's the same with either DVI or VGA input.Switching off for a few minutes enables the display again, for about a minute.
Other Samsung monitors exhibit similar faults, mostly due to blown Capacitors.So, rather than junk the T190, I decided to open it up and check for damage capacitors.
But how to dismantle it? After spending over an hour searching the web, without success, I had another go.
Here is how:1. remove the foot dish (undo butterfly screw at bottom)2. swivel the remaining stand post RIGHT back, as far as it goes (it may be quite stiff, I had to use WD40)3. stand the monitor on its top edge, you can now see 2 small cut-backs on the post, where it enters the monitor case4. use a small Philips screwdriver and remove the two screws hidden there5. remove the screw holding the two cover halves of the post together6. remove the covers7. the metal core of the stand, with its hinge part, is now exposed8. pull this out (NOT easy!); the part inside the monitor is shaped like a spade and is a very tight fit! I tapped it with a small hammer while pulling hard.9. when it is removed, you can access 2 screws that hold the bezel and housing together.10. gently insert a small flat screwdriver all along the four edges of the bezel and snap it apart11. the remaining parts can now be dismantled; some cables need unplugging (make a note of polarity!)
If anybody needs more information, please email me, I have taken some photos
PS - all capacitors were ok, I've no idea what's causing the fault.
Nov 22, 2010 | Samsung T190 19" Widescreen LCD Monitor
How to take apart the samsung gravity sgh-t459
Remove battery cover and battery. Using a #00 philips head screwdriver, remove the 6 screws around the perimeter. Slide phone open and carefully pry up on the edge of the green (or blue) trim near the space bar. The colored back should unsnap. There will be two philips head screws visible on the now exposed circuit board. Remove these and carefully pull up on the rectangular ribbon cable to disconnect the main circuit board from the keypad circuit. Carefully peel the two button contacts from either side of the phone. On the spacebar edge, there will be a clip holding the circuit board in place. Gently pry it away from the board and the board should come free (there will be clips on the other side but you should be able to lift the free side of the board up and slide it out from under the clips). Remove the QWERTY keypad. Unglue the remaining ribbon cable from the keypad frame. Undo the 8 silver screws securing the keypad frame to the hinge and lift frame off. There will be 4 screws visible on the back of the LCD case. Remove these and insert a thin plastic spudger at the top of the frame and carefully work your way around. The two halves will separate (should hear two snaps on each side). You will now be into the keypad/LCD section of the phone. Removing everything else is pretty straight forward. Follow these directions backwards to reassemble.
Oct 10, 2009 | Samsung Gravity SGH-T459 Cell Phone
Cannot remove the Brightness window that pops up on my Philips 190B monitor.
Aug 27, 2009 | Philips Computers & Internet
Osd locked
Hold the menu/ok button for ten seconds, to unlock the OSD.
If this doesn't solve the problem, then it's probably the button that got stuck.
There are two things you can do to repair it, but both require that you dismantle the casing, which voids any warranty.. so, if the monitor's still covered by the warranty, or if money is not an issue, have it repaired by professionals on an accredited brand shop (check your warranty details for more information on this subject).
If not, remove the casing, locate the menu button's contact switch on the circuit board, and try to release it using something thin like a screwdriver, x-acto knife, or set of plyers.
If this doesn't work, chances are the menu button is stuck on a loop, sending a continuous signal to the board (which keeps locking/unlocking the OSD).
If so, your only solution (other than take it to a repair shop) is to remove it, by prying it off with a screwdriver or set of plyers.
Of course, you'll lose access to the OSD features, but I guess this is better than to have a message stuck on front of your screen all the time..
This is a tried and working solution, since I had this problem myself (with a Philips 190B monitor), and solved it successfully, with this method.
Mar 16, 2008 | Philips 190B6CB/27 19" LCD
Dismantling notebook.
Hi Beem, i will try and advise you if you want to send images of your laptop, from different angles so i can give ya ideas of how to get into it.. John auctionscotland@tiscali.co.uk
Jan 21, 2007 | Samsung X15 Notebook
Philips 190B6CB/27 19" LCD Logo
914 people viewed this question
Top Philips Computers & Internet Experts
Computer Repairing
Computer Repairing
micky dee
Are you a Philips Computer and Internet Expert? Answer questions, earn points and help others
