Question about Mitsubishi HD-6000 DTV Receiver / Video Recorder
How to hook up hd on mits 1080 8 years old
What cable to hook up hd to my tv
  • 3 Answers
HDMI is the best
Posted on Feb 06, 2009
My PS3 connects to my 3yr old Mitsubishi HD tv fine via HDMI or the analog connection. However, using the same cable(s) it won't do anything but flash a squiggly green line a couple of times on a 6 year...
yup one or the other is capped at or below 1080 P - I so when you go to power it up at a new tv push and hold power till it makes the second beep 5 secs later and your good to go ok :)
Dec 21, 2010 | Sony Playstation 3 (PS3) Console
Does my hd 1080 series tv have the capability of running my computer through it?
Yes,u can used ur LCD tv as a computer monitor.Used a HDMI cable to hook it up or a computer VGA signal cable to hook it up.Process is pretty simple,read ur LCD tv instruntional owner manual how.
Nov 22, 2010 | Mitsubishi Televison & Video
High Definition--WS-55807
IF the MITS has 3 component inputs blue red yellow RCA jacks on the back then yes at 480 or 720p, you'll need to attach 2 audio cables for sound. If it has a HDMI input then absolutely.
please rate!
Mar 11, 2009 | Mitsubishi WS-55807 TV
BLUE RAY 1080 (p) PLAYERS INHANCE VISUAL HD ON 1080 (i) tV
try to see if u have hdmi slots and check the highest resolution it can go.there is a higher resolution called hdcp,with not div x but dvi-d where resolution can go up to 20000
Feb 06, 2009 | Mitsubishi WS-65513 65" Rear Projection...
HDTV CABLE NOT HOOKED UP/WORKING
COMP 1 and 2 are for 480i/p sources. Hook it to the 1080i capable on the back. Also make sure the HD DVR is outputting 1080i not 720p. The Mits can not disply 720p and will show a scrambled screen if you try to.
Jan 31, 2009 | Mitsubishi WS-65809 65" Rear Projection...
Phillips hdtv
if the cable box is sending in 1080 signal the tv will not be able to format to a 480 (you can switch to either/or)
the problem you have is if your not sending 1080 to the tv your not really watching HD but you cant strech the 4:3 (non HD channels) to the 16:9
the only thing you can do is run analog signal and a digital signal then switch between the two sorces for your HD and non HD programs
Mar 11, 2008 | Philips 42PFL5332D 42 in. LCD Television
HD setup, 480 to 1080 not working.
I had this same problem, got my HD installed yesterday w/ Direct TV, have had this TV since '02. The fact that is wasn't working, and Google, led me to your post in search of answers. I even went to a local retailer that sells the Mitsubishi TV's and they were as helpful as if I had gone to a drug store seeking the answer. So, between browsing other posts, and then going to the manual (who'd of thunk) I got my, and your, answer. You need to do the following, nothing magic: 1)Connect the component video output of the Direct TV HD Receiver to the DTV inputs on your TV. The COMP 1/2 inputs are NOT 1080 compatible, only the DTV input. As another poster said, you must use component video cables, not the old red/yellow/white cables. you can lose too much signal quality w/ the old R/Y/W cables and your TV still won't recognize the 1080. 2)Set your receiver to a HD Channel, which are in the 70's. 3)Use the format selection on your remote and select until you get the 1080i Standard (or whatever your preference is) format. 4)Enjoy Bottom line is the COMP inputs are not HD. Page 64 of the manual (at least the one i downloaded from mitsubishi-tv.com) is what gave me the final piece of the picture. Good Luck!
Sep 20, 2007 | Mitsubishi WS-65869 65" Rear Projection...
Mitsubishi HD-6000 DTV Receiver / Video Recorder Logo
176 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
