Question about Canon PIXMA MP530 All-In-One InkJet Printer
Canon Pro9000 - cayan color - not working
I have tried three different ink tanks and I have cleaned 3 times then deep cleaned 3 times. Both the test print (for nozzle clog and alignment) sheets show no cayan color.
  • roncastillep Jan 30, 2009
    Bud: I turned the unit off then unplugged it then unplugged the usb cable. I then plugged in the unit turned it on and tried to print something it told me that the printer was not hooked up so I them plugged in the usb cable. The results wes the same. Ron
    President:
  • 8,637 Answers
Normal 0 Could have a corrupt driver.
Disconnect the printer or at least be sure it is turned off. I'd do both and when the CD software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Posted on Jan 30, 2009
Blurry colorwashed photos from canon pixma pro9000. What can I do to fix this?
Hi there, I located this video about removing the print head and cleaning it. I've had to clean my print head from time to time, so take a look at this video and see if it can give some help. Your printer might not look exactly the same, but you should be able to remove the print head. If cleaning the print head doesn't clean up the color issue, try contacting Cannon support: Canon Contact Us. I wish you best of luck!
-Mr. W
Feb 25, 2015 | Canon PIXMA Pro9000 Printer
Canon Pixma 9000 pro flash 14 times
Hello, this is what your error means: Ink tank not recognized [1684]
A non-supported ink tank is installed (the ink tank LED is turned off). Install the supported ink tanks, check that the chips on the cartridges are clean.
Oct 07, 2012 | Canon Uv Ink Refillable Cartridges For...
Canon pixma pro9000 -2 i have done all the print head cleaning and deep cleanig and the test shows no cloggs -- when i print specifying low quality ( fast ) and plain paper, the photo looks marginal...
Hello Charles! Welcome to FixYa!
Actually as you told that you have replaced ink cartridge sometimes ago so with the new ink the effect of primary colors is more and when you print on the high quality the effect of primary color is more.
If you are printing the photos with software the try to print it on medium quality, even on low quality, The result will be fine. You can change the setting of printing in any software. After a time while when the ink will be used the result will automatically fine even on High quality.
I hope you have a clear picture in your mind.
Sir, If you find my service helpful for you then please don't forget to Rate the Service as "Five Stars" and give Words of appreciation as Feedback
Thank You for taking my service and using FixYa
Dec 17, 2011 | Canon Office Equipment & Supplies
My Canon Pizma Pro9000 prints photos that contain TOO MUCH black in it. All the colors appear to be much darker than on the screen. And when I lighten the pics, it doesn't help since all the shadows are...
Hi
I suggest you clean it manually by removing the ink cartridge and rub the print head into a paper with alochol and then run the print nozzle for 2 times to clear some ink residue that cause darken color
Mar 08, 2011 | Canon PIXMA Pro9000 Printer
Canon mp530 - colors print dull and faded
The ink tanks may be full but sometimes the pins that connect the cartridges to the printer may have dried up ink on them preventing the ink from flowing. You can try to swab these with a bit of rubbing alcohol on a Qtip and letting it dry for moment or two. I would strongly suggest doing a couple of deep cleanings first and try test printing of the individual colours separately in a program such as paint to see which colour is affected.
Jan 24, 2010 | Canon PIXMA MP530 All-In-One InkJet...
Pixma Pro 9000 Canon Printer is printing terribly colored photos.
HOW LONG HAS YOUR INK SAT IN THE PRINTER WITH OUT USE AND IS IT A CHEAP INK THAT YOUR USEING ? IF SO THAT COULD BE THE PROBLEM
Apr 05, 2009 | Canon PIXMA Pro9000 InkJet Photo Printer
I960 canon printer
Lift lid ,let carriage stop in middle, un-plug the printer > Remove all ink tanks > Remove print head > Soak print head in > 3 parts very warm water an 1 part ammonia over night. Rinse under faucet with water directly over ink ports, shake out excess water,(if when you shake it out and if color still comes out repeat soaking for another hour or two and rinsing again ,HAD TO DO MINE TWICE) let air dry. (hair drier helps) Cured my problem for a while ,but if not used almost every day, this will happen again, I also use compatible ink tanks. Don'T believe the inks are as good as Canon Ink. But who the hell can afford them. So fill your owe with Canon ink from Canon. Still seems that the cyan always dries up first. Good luck Lestero1
Oct 18, 2007 | Cannon Canon i960 Photo Printer
Canon PIXMA  MP530 All-In-One InkJet Printer Logo
177 people viewed this question
old marine
old marine
