Question about HP OfficeJet 4215 All-In-One InkJet Printer
Hello, I work in a studio that has an HP officejet 4215 all-in-one, and although I did a partial reset, and restarted the computer as well, the printer will not print. Its' status on the computer says "Paper Out" when actually there is paper in the printer. Please help!
  • emikryan8 Jan 30, 2009
    I am not sure if it's because we are using Windows Vista, but after right clicking on the printer and then going to Properties, there is no "Maintenance" or "Tools" or "Cleaning" or "Deep Cleaning" option/tab/button anywhere. Help!
  • 258 Answers
Try going into Control Panel
--> Printers and Faxes
--> Right Click on the Printer ICON and select Properties
--> Look for a "Maintenance" or "Tools" Tab across the top click one
--> Look for an option for "Cleaning" or "Deep Cleaning"
and click on one of these options to run
If you cannot find that then Try going into Control Panel
--> Right Clicking on your printer
Posted on Jan 30, 2009
  • Peter Conway Jan 30, 2009
    ok, i'll just re-boot my pc in vista and have a look and post an option
    I've find a manual, try settings to factory settings this may resolve your problem but it won't change the date and time etc.
    Press Setup
    5 Tools Menu
    3 Restore Factory defaults
    there is also a clean print cartridge under
    5 tools menu,
    1 clean print cartridge
When I try to print from either of two computers with the HP 4215 driver and/or copy the printing is extremely slow - takes about 20 minutes to print or copy one page
You need to do two separate things: 1. You must erase the driver that you currently have for that printer and disconnect/restart the printer physically. To erase the driver in Windows 7 do the following: Start Menu -> Devices and Printers -> Right Click HP OfficeJet 4215 -> Remove Device (if this doesn't work you can also try fiddling with the properties too in the same context menu).
2. Then you need to download and install the new driver from here: http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?lc=en&dlc=en&cc=us&product=351106&lang=en& (Contains Drivers for all Operating Systems)
Feb 28, 2011 | HP OfficeJet 4215 All-In-One InkJet...
Hp officejet 4215 all-in-one "remove and check left cartridge"
^_^
uninstall all existing printer driver on your computer..maybe you have two or three driver installed..
an then..
install compatible driver to it..
May 12, 2009 | HP OfficeJet 4215 All-In-One InkJet...
HP Officejet 4215 will not print
  • Unplug the printer cable from the computer.
  • Unistall the printer drivers from Device manager and also unistall the all the printer appications
  • restart the computer
  • try to download drivers from the website
  • after installing drivers and software it will ask you to connect the printer.
  • then you can connect the printer and and try to Print the test page.
Mar 29, 2009 | HP OfficeJet 4215 All-In-One InkJet...
Printer wont print
open up the printer folder in your computer and then cancel the pending documents after that open SERVICES.MSC that u can easily find searching in your computer and after that look for print spooler restert that service 3-4 times and then restart your computer after that try and print if this oes not help leave a message i have a solution for that as well
Dec 31, 2008 | HP OfficeJet 4215 All-In-One InkJet...
I lost the Cd to instal my hp printer to my computer
Here is a link for the 4215. Links are on this page for software downloads, manuals, etc.
4215 Support Page
Nov 17, 2008 | HP OfficeJet 4215 All-In-One InkJet...
Hp officejet 4215 all in one
  1. Ensure that you have a two contact phone cable connected to line 1 socket of the printer and that the other end of the cable is connected to the phone jack in the wall.
  2. Perform a partial reset on the printer. To do this first remove the power supply from the back of the printer. With the power off press and hold the # and 3 keys.
  3. Plug the power back into the printer, keep holding the # and 3 keys till you see “ Partial Reset ” displayed on the printer screen.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Nov 08, 2008 | HP OfficeJet 4215 All-In-One InkJet...
HP 4215
try connecting a normal phoneline to that line and try.
It might be a prob with long dist calls.
If u are ok with the phone test, check its in tone or pulse. Try switching. Then also if that is not working just reset the printer and try.
Mar 04, 2008 | HP Officejet 4215 All-in-One Color Photo...
Hp officejet 4215
Hello sonyamac,
You can download the software directly from the manufacturer and install it without the CD. Go to www.hp.com/, find and click Software & Driver Downloads, select Download drivers and software, type officejet 4215 in the box and press enter. Select which officejet matches yours: 4215, 4215v or 4215xi (you can find that info on a label attached around your printer. Sometimes the model is only described as CXXXXA format. If that is all you got, go back to the prior page and type that model instead of officejet 4215. You should reach a page where you select which operating system you are using, click on it and on the next page you can select which software you want to download. After saving your download, just open the program, follow the installation instructions and you should be ready to print in no time. Hope this helps.
cancerags
Dec 26, 2007 | HP Officejet 4215 All-in-One Color Photo...
HP OfficeJet 4215 All-In-One InkJet Printer Logo
90 people viewed this question
Ben Johnson
