Cycle wont start. cummin up
Checked pipes for blockages, none pump fine 4 dirty kids. Please help. ta
  • 15,935 Answers
It appears your timer has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 13, 2010
What does the code f-05 for a hotpoint ultima WT640 1400 SPN
F05 measn some blockage, check and clean the filter at the front; remove the top cover of the machine,(power off) and disconnect the flexible hoses from the dispenser. Check if theyre blocked. The dispenser itself can be seperated - generally held together with plastic clips. Clean out any crud or hardened detergent.
Fabric conditioner is taken from the detergent tray by siphon action. Most likely flexible siphon pipe is blocked. Remove machine top, identify the pipe coming from the softener compartment, detach and clean.
Hope helps.
Apr 15, 2011 | Washing Machines
Bosch classixx 1200 express spin light flashing water wont drain pump is running water draining very slow i checked for blockage none found help... thanks
Sounds like the blockage is closer to the drum, Tilt the machine as far back as you can to access underneath. Make sure to have a basin and remove the pipe going from the drain pump to the tub and see if anything is obstructing the pipe or stuck in the tub, is usually a sock. Hope this helps.
Feb 28, 2011 | Bosch Classixx WFC 2465 Front Load Washer
IDL700 wont start Kept getting error message to say there was a blockage. Checked all the pipes and pump, all fine. Now the blockage lights are out, but the machine wont start at all, just beeps when I...
Sorry to read about your problem, I hope this helps you out.
the blockage, maybe inside the pump of the unit, or at the check valve.
I suggest you contact a service company..
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
2 Thumbs - Somewhat Helpful
1 Thumb - Not Helpful
Dec 28, 2010 | Indesit 24 in. IDL700 Built-In Dishwasher
Drum not turning despite belt ok and motor ok, lots of sediment from drainage pipe
check the pump/impeller for blockage.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
May 26, 2009 | Washing Machines
Water left after finishing wash
I have a Bosch Dishwasher and the E-Nr is SGS4362EU/03. The machine is approximately 4 years old, in good condition and has been working very well. Suddenly, there is water remaining after it completes a 50 degrees C wash cycle. This is also evident with the pre wash cycle and the 65 degrees wash cycle.
I have checked and cleaned the filters. I have loosened the internal pump white cover (Torx T 20 screw) and checked for any physical blockage - none. I have also checked for any drainage hose kinks - none.
I have tried a series of empty washes and the machine drains the water during the wash cycles. The dishes are also have a dull colour and show show signs of not being properly rinsed during the wash cycle.
Please assist.
Reagrds,
Brian
Dec 27, 2008 | Bosch 24 in. SHY56A05 Stainless Steel...
OE fault in Dishwasher model LD-14AT2
suggest you take the drain pump motor out and inspect. either a blockage or its defective.
Jun 15, 2008 | LG 24 in. LD-12BS6 Stainless Steel...
Hotpoint ultima 1200
Kirsty - There could be an item like a hair clip Jamming the pump impeller. Or then it can be only a blockage in the filter or in the waste pipe or if the waste is connected to your sink drain check that the blockage is not there - either in the end of the pipe or in the sink connection.
Try disconnecting at the sink, holding the waste pipe into a bucket see if it will pump out then. If it does then the problem lies in the sink plumbing - if not then it lies in the machine.
If the pump and filter and hoses are definitely clear you could have a Pump, PCB or wiring fault. Hope this helps.
Mar 12, 2008 | Washing Machines
Door locked light on but washing machine will not start
Try unplugging the machine and plugging it back in and see if that helps reset it.
Jun 07, 2017 | Hoover HF130E Front Load Washer
Washing Machines Logo
18 people viewed this question
Top Washing Machines Experts
