RCA OPAL M4001 MP3 Player Logo
Anonymous Posted on Jul 29, 2007
Product Screwiness I recently purchased a Rca Lyra Opal, the device itself works awesome. But the equipment that came with it didnt work. The CD that has the software and extras on it would not download, i would click for it to download but it would come up with an error box saying "please reinsert disk into drive E:" yah........once i reinsert it, it will go to the main software for detecting the player when it is connected... Once again I click download and yet again Error Box.....Please help me Im stuck with 10 songs and it is starting to drive me crazy.
A
Anonymous
Go to the main site at www.rca.com and find and updat for your rca it'll have the driver and with a reformat you should be able to put more songs on it
Anonymous
Level 1:
  • Contributor 34 Answers
  • Posted on Jul 29, 2007
Anonymous
Contributor
Level 1:
Answers
34
Questions
0
Helped
13349
Points
60
One thing to try would be to copy all the files off your CD ROM onto your C: drive, then run whatever .exe file you're trying to run from the CD itself
2helpful
RCA Lyra RD1080 extra disk recognition
the card is to larg for the mp3 player use up to 1gb only and do not delete the files that came with the mp3 player or your player will not work use 64k not 32 works better use windows midea player to put music on it mp3 and wma only
RCA Lyra X3000 Burnt out
Your media player needs a professional repair service.
When is use a different power adapter with wrong voltage, the battery charge circuitry is damablowing up on or more internal integrated circuits.
Some times just replacing the damaged devices is necessary, but other times the printed circuit suffer a dmage beyond to be repaired (say that the excessive heat made a hole in the board)
Just a repair center that fixes this RCA model may help you.
Also, you can get your hands in a partially working media player (say a X3000 player with cracked LCD screen) in Ebay, and perfom the repair yourself if you have experience and skills to do it.
RCA repair centers charge $125.00 for such repairs.
Best regards,
2answers
RCA OPAL 4008 CAN'T SYNC SELECTED
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
RCA M4018 8GB MP3 Player
Mine didn't recognize either, so what I did is go into the device manager, find the opal in the listings, double-click, disabled the device, re-enabled it, at which time it shows that there's a firmware error. I then re-installed the driver from the cd, unplugged the opal, plugged it back in, and for whatever reason, the computer then recognized the opal as a mass storage device, instead of a portable music player. The computer now sees it everytime, and all I have to do is drag and drop any files I want into the opal. Works like a charm. Hopefully RCA will provide an updated firmware program in the near future, but this might work for you for now. Good luck!
2answers
Lyra rca mc4002a
Hi, you can try to upgrade the player's firmware, you can download it from the RCA Website (moz-screenshot.jpgmoz-screenshot-1.jpghttp://support.rcaaudiovideo.com/downloads.aspx?product=187), the firmware it's the second app listed.
If your computer doesn't recognize the player, you'll have to turn it off and keep "PLAY" pressed for 10 seconds while connecting it to the USB port, then update the firmware.
H125PA 5 gig mp3 player problems
This is most likely caused by the Lyra being nearly full.
First try deleting content to free up 15MB of disk space. Then profile the device contents.
If that's not successful, connect the USB cable to the device while pressing the enter button (Play/Pause). Continue to hold the button in until your PC recognizes the device. This will connect the player as a mass storage device with a drive letter in Windows Explorer.
In Windows Explorer, navigate to the drive letter assigned to the Lyra and locate the Lyra_Sys folder. Within that folder you should find the local.lrd file. This contains the information from profiling.
Delete the local.lrd file, then safely disconnect the player from the PC.
The embedded profiler should then work correctly.
RCA lyra
The songs are not in the right format - they do not have transfer rights
3helpful
3answers
"Boot Error, Sutting Down"
when i turn my mp3 on from memorex model MMP8561 it says boot error shooting down.
how do i fix this?
MP# player isn't working
mine did the same thing ... so i took it apart carfully and found that the battery conection had come off ... so i re attached it with some sauder(<--- sorry fer the spelling) and it worked fine after that
3helpful
4answers
My rca lyra MC5102A
If you go on to rca.com and type in MC5102 you will get the support page and the mp3 player does not suppord windows vista
Top RCA Audio Players & Recorders Experts
 Grubhead
Grubhead
Grand Canyon Tech
Grand Canyon Tech
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
