Question about Thermador Cooktops
VENT-A HOOD WILL NOT LOWER
THE HOOD WILL NOT GO DOWN..THE BOTTOM BUTTON ON THE RIGHT HAND SIDE IS ON ALL THE TIME (RED)...MOTOR RUNS WELL, ...THERE ARE MANY NUMBERS I HAVE FOUND TO DESCRIBE THE UNIT: CEP/304 28 / 01
FD# 850100025
SERIAL # 825010080535000252
50600000000082
    President:
  • 2,559 Answers
By the info you provided,Your model is 1 of the 2 below
UCVM30FS / UCVM36FS (both are identical in features)
To cover all the bases,we will start with the basics
To Lower the vent
Press the control push-button once.
Note: The blower will turn off when the
intake is lowered if operating when the
control push-button is pressed
If vent Stops during raise or lower
Locate and remove obstruction.
Press control button to raise intake.
Press control button again to lower
intake.
How to Obtain Service
For authorized service or parts information, call 1-800-735-4328.
We want you to be a satisfied customer. If a situation arises that has not been resolved to
your satisfaction, please let us know.
Write: Customer Support, BSH Home Appliances, Corp. 5551 McFadden Ave.,
Huntington Beach, CA 92649, or call: 1-800-735-4328.
Please include the model number, serial number, and date of original purchase/installation.
Posted on Jan 30, 2009
  • Randy Hough
    Randy Hough Jan 30, 2009
    Also,If you need the manual,You can view it here
  • Thermador Master
  • 19,396 Answers
There is a fault, probably some part is jammed, or a control is malfunctioning.
Try tripping the circuit breaker and cutting power for ten minutes.
If you still get the fault the best thing is contacting the manufacturer.
Rega rding the model, the numbers you gave do not help, I need the model number, so that I can look for schematics for this model.
See: finding the model number on your appliance.
See here how to validate warranty, or buy an extension.
    President:
  • 1,214 Answers
While I am trying to find the manual for this unit -
Does the hood retract by itself, or are you supposed to push it down?
  • Mark Egan Jan 30, 2009
    I am unable to find a manual under the numbers given at the Thermador site. But, it looks like there may be a drive motor that raises and lowers the unit when you push the red button (and as I recall there is from when we were looking at these several years ago.).
    The Model number should be something like UCVM36SS (the SS probably stands for stainless steel.).
    If you can give me a better model number, I will try to provide additional information and instruction.
  • 679 Answers
There is a spring on that button (spring is inside the button),
there might have been an autocut due to power overload.
check tham.
  • rockfixya
    rockfixya Feb 01, 2009
    please let me know if problem solved.
    Thanks
We have a viking cook top and the vent goes up and down but the fan does not always turn on ? Can you help
Some units have a dead man switch, which means that if the filters are not in place correctly the blowers will not operate. Its a safety thing to prevent little ones from dropping toys into a running blower. Double check the filters placement, if the filters are in the proper location than I would look at the power to the blower unit. The vent has two jobs, (1) to raise and lower, (2) to turn on the blower unit once in the full up position. If this is not the case, the upper switch in the vent system has failed. If you already confused, you will need to call a Viking expert to correct this problem. Its not difficult but can be time consuming.
I hope this helps
I have seen this problem twice and found the filters were the problem, rarely replace blower motors..
Jul 26, 2011 | Viking Cooktops
My new home already has a hood vent for the range. I have a gas Jenn air downdraft range. I prefer to use the hood vent as the downdraft is not very efficient. Do I have to connect the blower on my range...
The poupose of either is to eliminate any smoke created by the range or grille and move as much of the cooking odors to the outside. I wouldn't use both at the same time, but if the hood is vented to the outside, it would be just fine to use only the hood. Aregular cleaning will be necesssary. The downdraft has limits as to the distance it will efficiently exhaust air. Flex hose should not be used. And excessive bends or vent length, cuts into the efficiency.
Oct 29, 2009 | Jenn-Air JED8230 Electric Cooktop
What is a bottom vented cooktop
There is a fan that sucks DOWN like a Jenn-Air cook top. There is no hood usually over such a stove. Usually the suction for the vent is between the burners. I think the air can be exhausted through a filter back into the room or to the out of doors.
The salesman didnt explain this to you???
I hpe this answers your question
Oct 05, 2009 | Jenn-Air Cooktops
Downdraft vent unit is stuck halfway.
You'll have to remove it and manually reverse the drive gear. Hopefully, it didn't get stripped.
May 07, 2009 | Thermador SGS36GS Gas Cooktop
Pinnacle Raised Vent System #RV36 or RV 46
Ours started doing the same thing. I got it to start working again by gently holding down the up/down button until it started to move. After doing this a few times it started working normally again. Also the keypad can be locked and unlocked by pressing the low and high buttons together for 1 second.
Dec 08, 2008 | Dacor Preference SGM365SS Gas Cooktop
Vent Cleaning Problem
Hello.
Down drafts are one of the biggest pains in the neck to work on, because one has to get underneath the cook top, and remove the duct, then the blower motor, and then the cover that is over the part that goes up and down. That is if the contractor who put it in didn't build shelves around it or put a bunch of drawers in front of it. So there you have it. It is not easy to clean it. You have to be prepared to disassemble it and try and put it back together properly. One time a customer paid me to have me completely dissassemble the inside of her refrigerator because some bad fish had leaked into everything and she wanted to clean it. You could always do that.
Nov 30, 2008 | Jenn-Air JED8230 Electric Cooktop
Thermador Cook 'n' Vent Stove with stuck vent (model # SGCS304RS)
I just had a similar problem. The switch knob, and backer for the blower got jambed in the housing. After pulling it all apart I called the parts center at Thermador and ordered a new switch. If you can hear the motor the raises the unit run, then that could be your problem.
Oct 11, 2008 | Cooktops
Downdraft vent on jenn air cooktop
How do you get the inside area of the vent clean from the grease and oils where the filter is?? I have a rectangular box style downdraft that the vent goes into the floor, I pulled the filter, but the box is to slender to get an arm into to scrub the grease....... does the bottom come off, or is it a sealed unit? How do you get all the brease from the bottom if you cannot reach it?
Jul 09, 2008 | Jenn-Air JED8230 Electric Cooktop
Raised vent system won't stay in down position
sounds like yo u have a faulty home switch. when dropped to lowest setting it should switch off electric. however if switch is bad never senses its down adn thenwants to open back up. there should be an acces panel in lower right corner of unit along witha wire diargam
Mar 08, 2008 | Cooktops
Cooktops Logo
71 people viewed this question
Top Thermador Cooktops Experts
Dan Webster
Dan Webster
meztang
meztang
Are you a Thermador Cooktop Expert? Answer questions, earn points and help others
