Question about Sony PS2 Dual Shock 2 Controller (PrePlayed) (PS2PRSODUSH2)
Directional buttons not working on both PS2 (controllers
the up, down and left buttons on the left side of both my PS2 (Dual Shock 2) controllers have stopped working. I haven't use the console for a while but they were working when I last used it. One of the controllers has never been used. Please help, as i can't access a lot of the menu's.
  • 74 Answers
The wire must have been.. twisted.. due to the way you keep it.. dont twist the wires around the controller to avoid this problem.. n.n
Posted on Jun 05, 2009
2 Suggested Answers
  • 29 Answers
SOURCE: directional buttons not working on both PS2 controllers
Try them on another playstation 2. If the same problem occurs, then the controllers probably or broken. Did it get banged around a lot? Is the cord ruptured or something?
Hopes this helps!
Posted on Jan 31, 2009
My mad catz dual force ps2 controller wont work
you will need a dual shock 2 ps2 controller. The mad catz controller is probably a dual shock 1 controller. Some games require the dual shock 2. It should say on the back of the game if the dual shock 2 is required. If it says something along the lines of "pressure sensitivity" or "pressure sensitive" on the back of the game case (where it says "1 player" or "2 player") ... then you will need a dual shock 2 controller. If this is not the case and it only says "analog controller" and "vibration" then you won't need the dual shock 2 controller. If the controller doesn't work for any games or even on the console main screen, then it must be the controller that is broken. Try turning the system on without a game in it and see if the controller works. Hope this helped :-)
Oct 16, 2012 | Mad Catz PS2 Dual Force Controller
Hi, I just put a 5mm LED inside my dualshock 3, behind the ps button, but now when I connect it to my ps3 the left analog stick is always pointing left. so on menus it will always scroll left. I dont know...
You just have to keep pushing down on the top of the stick and releasing it,like the PS2 had L3 and rolling it around.I get that with PS2 controller.I basically just go spastic on it for about 10 seconds and it stops.Do you know what I mean?Push down on the knob,not literally in the down direction.If you have questions,just reply.
Jul 18, 2010 | Sony Dual Shock 3 Controller for...
I'm looking for the L3 on the controller. I have
Hi a lot pf people get confused over this button but you know the two thumb controls that you can turn in all directions the round controls well you can press these down the left ball is L3 and the right ball is R3 so press the ball down and thats the button your looking for.
Jul 10, 2010 | Sony PS2 Dual Shock 2 Controller...
Ps2 dual shock black controllers are not recognized?
1.) i think u r controller pin is bend are broken
2.) or controller wire is cut
its better 2 buy a new controller
peace out >>>>>
Jul 26, 2009 | Sony PS2 Dual Shock 2 Controller...
The vibration on the left side isnt working
Your controller ******** have got fused you are need to replace with new...
Jun 23, 2009 | Sony PS2 Dual Shock 2 Controller...
Directional buttons not working on both PS2 controllers
Hopes this helps!
Jan 30, 2009 | Sony PS2 Dual Shock 2 Controller...
How to check terminals on a dualshock2 ps2 controller
does it stop working?or stopped vibrating?if the vibration stopped then wire connecting to the rotating motor is detached this is the common problem with dual shock because of constant vibration.Solution is to open the controller and connect the loose wire,dust is also a big factor if buttons are already not responding so try also to remove accumulated dust on the button touch board.
Jan 24, 2009 | Sony PS2 Dual Shock 2 Controller...
Ps2 dual shock2 controller buttons not working
Removed accumulated dust sticking on the board were the buttons touches.use cotton balls with alcohol or use clean damp cloth.If nothing's happen check the cord I'm sure it is twisted badly, open your ps2 use this controller and try to twist back the twisted cord if it stopped sometimes when your twisting it then you have to replaced the cord(make sure that your using the original ps2 controller not imitation)pls. rate
Jan 17, 2009 | Sony PS2 Dual Shock 2 Controller...
Can't get ps2 dual shock 2controller to work
you need to do a special code to take control which is press L1,R1, L2, R2, Start, and Select, for about 30 seconds. if it don't work, unplug the controller, blow on the Female and Male ends. (controller and system) and plug back in and you should be good to go. Please rate my solution.
Jun 10, 2008 | Sony PS2 Dual Shock 2 Controller...
Sony PS2 Dual Shock 2 Controller (PrePlayed) (PS2PRSODUSH2) Logo
788 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
marley mcelhinney
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
