Question about Microsoft Xbox 360 Console
Scratching disks Only had x box 360 since xmas. Has scratched/ damaged 2- 3 disks. Brand new games. Have tried cleaning them but you can see the marks on them. I am the only one who has used them and i'm worried to use anymore disks. Why would this happen. No red lights are on.
  • Aegis Kay
    Aegis Kay May 11, 2010
    Is your Xbox 360 vertical or horizontal? If you turn your xbox off with the disk inside and move the console a lot it does tend to scratch the disks but it can also depend on how the console is rested.
    Novelist:
  • 174 Answers
Microsoft have changed the mould for the dvd trays (or the suppliers have changed them at least) so that on the latest editions of the 360 it does not scratch them as much as it used to. the previous person is right. what happens is that when the disc is being read from it will spin very very fast and one slight knock on the older 360's would produce a ring right around the 360. this happens when the game disc wobbles and touches the moulding on the dvd tray.
i would try not to move the console while its on, wait at least 30 seconds before moving the console after you turn it off.
if you have a wired pad this can make things worse as everything you pull the pad it can make the disc wobble and cause this problem.
a friend of min stopped this happening by getting a thin enough peice of soft foam and gluing it onto the tray so that when the discs did wobble they would skim the soft rubber and not the hard mouldings.
im also guessing its a samsung drive you have because the earlier ones were really bad for this.
hope it helps a bit.
www.fixmyconsole.co.uk
Posted on Jan 30, 2009
I turned off my xbox 360 during playing lego marvel super heros and it messed up the disk what do I do.
Turning off your console shouldn't have damaged your disk (unless you knocked it and the disk was scratched), what is more likely is that your saved data was corrupted. Try starting a brand new game, if this works you can be pretty sure it's the data saved on the console and not the disk. If that doesn't work have a good look at your disk, clean off any fingerprints or dirt, if there are any deep scratches you may need to get them polished out ( most good games stores can do this for you pretty cheaply).
Oct 28, 2013 | Microsoft Xbox 360 Console
Bought guitar hero 5 xbox game w/guitar..disk spins and then says unreadable contact support...
Are other games working correctly in your Xbox 360?
Is this a brand new disk? or did you buy used?
if used, check for major scratching on the disk. If scratched heavily you can try to buff out scratches with a lint free cloth, I have also heard that toothpaste could be used for buffing out scratches, but I would only try this as a last resort.
If other games work fine in your Xbox, it's probably the disk. Make sure you have the XBOX version of the game (and didnt accidentally grab the PS3 game instead or something)
If it is the right version of the game and brand new and not working, call Activision and tell them you have a bad disk, if it's brand new I can't see how they wouldn't replace it. Or just return it to the store.
Mar 09, 2011 | Activision Guitar Hero 5 for Xbox 360
My call of duty game doesnt work anymore because of the scratches
If you're lucky, the scratches may not have cause permanent damage. Try taking your disk to a retailer such as EB Games that provides disk cleanings.
Feb 28, 2011 | Microsoft Xbox 360 Console
Have xbox 360, and new fallout 3 game of the year!!! play the game for 2 weeks ,the game loads, but when you start to move your character the game goes to blue screen or says it can't read disc!! and goes...
if it just has scratches then spread toothpaste all around it dry then wash it off with water and dry it completely but if it has a perfect scratched circle then u gotta replace it cause if it has that circle it wont work anymore, thats why gamestop has a new deal for a few more dollars that if that circle happens they replace it for free
Mar 31, 2010 | Microsoft Xbox 360 Console
My XBOX(not a 360) won't read disks
Check to see if there are any scratches or laser burn marks on the discs. Scratches or marks on discs will render the game discs unplayable or will freeze the game and will often show a message stating “Disc Read Error”. Best remedy for starters is to clean the discs and make sure there are no scratches or marks left on the play-side of the discs.
Laser burn, looks like complete or partial circular scratches around your disc, also known as “the ring of death”. This occurs to discs when the games console has been moved whilst playing, from an upright to a horizontal position or vice versa or simply knocked against or the wires may have been just tripped upon. Discs are then impaired by a ring of laser burn, which is a circular scratch into the disc. Some home remedies may help with very light scratches on some discs but professional disc repair services is normally required to restore disc laser burn damage back to "As Good As New Condition".
For further help on Xbox & Xbox 360 disc repairs or to get discs professionally repaired, visit:
www.discREPAIR.ie
Check the More Info Section & FAQ section for more details on disc repairs.
Send your discs off to a Professional Disc Repair Service and the discs shall be sent back as good as new.
If this laser burn scenario is consistently happening to your game discs, the games console itself may require repair. You should contact Microsoft for assessment and guidelines.
Mar 04, 2010 | Microsoft Xbox 360 Console
Damaged Games
Check to see if there are any scratches or laser burn marks on the discs. Scratches or marks on discs will render game discs unplayable or will freeze the game and will often show a message stating “Disc Read Error” or something to that effect. Best remedy for starters, is to clean the discs and make sure there are no scratches or marks left on the play-side of the discs. A common problem that Xbox owners are reporting is if the console is moved during play, a whirring noise is heard and then when the disc is removed, very visible laser burn rings are found on the disc.
For further help on Xbox & Xbox 360 disc repairs, visit:
www.discREPAIR.ie
Check the “More Info” & “FAQ” Sections for further details on disc repairs and related matters.
If this laser burn scenario is consistently happening to your game discs especially if the console has not been moved or bumped against while the discs is in play, the games console itself may require repair.
Hope this Helps!!
Feb 04, 2010 | Microsoft Xbox Console
Playing new fifa2010 on x boxx 360. working ok and then froze stating ''clean with soft cloth'' tried this but unsuccessful
Laser burn, looks like complete or partial circular scratches around your disc, also known as “the ring of death”. This occurs to discs when the games console has been moved whilst playing, from an upright to a horizontal position or vice versa or simply knocked against or the wires may have been just tripped upon. Discs are then impaired by a ring of laser burn, which is a circular scratch into the disc. Some home remedies may help with very light scratches on some discs but professional disc repair services is normally rerquired to restore disc laser burn damage back to "As Good As New Condition".
www.discREPAIR.ie
Send your discs off to this Disc Repair Service and the discs shall be sent back as good as new.
Dec 26, 2009 | Video Game Consoles & Games
My xbox 360 keeps puting scratches on my games
check to see if anything is obscuring the disc tray on opening and closing.
If there isnt check the disc make sure its smooth and flat no bumps and not bent
if there is noises like grinding when playing it may be a part inside causing this
i suggest calling xbox because i dought u want to risk doing this to other games.
please rate. thank you
Dec 17, 2008 | Microsoft Xbox 360 Console
Xbox consol damaged brand new game
If you move the console while the disk inside is running it will scratch the disk(it just happened to me) I used automotive cleaner wax and polished it from inside to out and then outside to in(not in circles) and it started working again, try it:)
Dec 29, 2007 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Martin Murray
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
