Question about GE 30" Self-Cleaning Freestanding Electric Range - White-on-White
Self-cleaning leaves a brown stain on the white part on my oven
When I use my self-cleaning on my oven it leaves a brown stain on the white plastic part outside my oven door. I have tried several things but nothing as worked.
  • 1 more comment
  • Anonymous Mar 08, 2009
    My mom just cleaned her oven today and it did the same thing. Our oven it white and the stains are like brown!
  • Anonymous Mar 14, 2009
    Both my sister and I have white Fridgedaire gas ranges and have the same problem except our stain is yellow on the door.
  • Anonymous Apr 07, 2009
    While cleaning my white oven I was left with ugly brown/yellow stains on the outside.
    Scholar:
  • 39 Answers
Perhaps the door gasket is not sealing well enough. In self clean mode the oven get very hot and vaporizes the fat off the sides. With a leak I think some of the fat is redepositing on on the outside where the leak is. You may need a new door seal.
Posted on Jan 30, 2009
2 Suggested Answers
  • 189 Answers
SOURCE: When I use my self-cleaning on my oven it leaves a
Hello- The self-clean cycle heats the inside up to about 800deg. There is no existing plastic that can take the heat at the vent w/out discoloring. The stain is from the smoke produced when the stuff on the drip pan incinerates. Try some oxy-clean and a damp cloth. Try to predict or minimize spills with foil and drip pans. Techs call 'self-clean' the 'self-destruct' cycle. Using this function will reduce the life expectancy of any electric range. Let me know if this info helps-have more if needed- Thanks- ED
Posted on Mar 03, 2010
The door has turned brown around the top after 2 uses in 5 years of the self cleaning process. How do I clean that off or can it be? Is it possible to replace the door on the stove?
You can easily clean it with easyoff oven cleaner available at most grocery stores.. Yes you can replace the door but the cost would be prohibitive.
Jun 29, 2010 | GE 30" Self-Cleaning Freestanding Electric...
When I use my self-cleaning on my oven it leaves a brown stain on the white plastic part outside my oven door. How do I clean the area that has browned?
Jan 28, 2010 | GE 30" Self-Cleaning Freestanding Electric...
Self cleaning will not operate, lock door, set timer and turn dial to clean, but does not clean oven.
Seems like you found out the hard way what I wrote about in this tip...
Check it out it also contains some thing to try on how to unlock that oven..
Self Cleaning Oven Problem
heatman101
Asker's Testimonial " Wish I had read this first. I never would have usedthe self cleaning option. Thanks for the info!! " - amymrocks
Jun 09, 2009 | GE Hotpoint 30" Self-Cleaning Freestanding...
WHITE FILM INSIDE OVEN
your mom may have used a non-self cleaning cleaner to try and clean this oven in the past. you wont have much luck getting rid of the stain but using cleaners like easy-off or mr muscle may help you reduce the staining.
it could also be that an element has shorted out and "burned" the surface of the oven. if the oven doesnt heat properly then check the elements for a rough or burnt out area. that does happen but its probably just going to be stained as it sounds like you have tried to do the cleaning.
p.s. i like mr muscle better then easy-off.
Jan 09, 2009 | Tappan TGF320 Gas Kitchen Range
Oven vents on front are stained and ugly. How do I clean them?
sorry but you wont be able to remove the "stain" what has happend is the paint used by maytag has become discolored from the oven vent heat and the only way to correct it is to replace the panel. they are available but for about 80 bucks. you could try to paint the panel but it will do it again.
Dec 28, 2008 | KitchenAid KESC307 Electric Kitchen Range
Dirty glass on oven door
Does your stove have an electric self-cleaning cycle?
If so, do it. I was surprised how well it worked on the glass too!
Remember though it may take 3-4 hours at a very high temperature.
Dec 23, 2008 | Jenn-Air JDR8895AAS Dual Fuel (Electric...
Suggestions for cleaning the genn air stove top JDR8895aas
I have no solution but I have a Jenn-air stove, white with dual fuel and the oven door is badly stained on the top, probably from the vapors when self-cleaning. I have tried many things and they won't touch it. can someone help me out
Dec 14, 2008 | Jenn-Air JDR8895AAS Dual Fuel (Electric...
GE Spectra XL44 Gas Oven, flashing "Locked Door". Can't use oven or close door
I had the same problem happen tonight. I have an XL44 self-cleaning gas range. We unplugged it for several minutes and pressed 'cancel' a bunch of times--neither worked. We finally lucked out--opened the oven door and pressed a black button on the upper left side of the front of the oven. It turned out the flashing words and unlocked our door. Weird. There was nothing in the manual about this...
Oct 22, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
Oven wont turn on.
I tried several times to get my oven to work and nothing seemed to help. After downloading the manual from this site, my husband locked and unlocked the oven door several times very hard and it knocked something in place and now my oven works. I hope it works for you.
Nov 22, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
GE 30" Self-Cleaning Freestanding Electric Range - White-on-White Logo
3,191 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Richard Roth
Richard Roth
Are you a Kitchen Range Expert? Answer questions, earn points and help others
