Question about HP Compaq FS7600e CRT Monitor
Monitor blinking While working on the computer the monitor gets grey and black lines then totally blacks out. after a while or with a tap on the back the screen comes on. please help
  • Ruth Brammer Jul 29, 2007
    I know the problem is with the monitor. The only problem is that no one can find why the monitor is doing this
The color in my monitor is not good look like sephia color
can yo help me ??
Posted on Jun 08, 2008
  • HP Master
  • 12,061 Answers
Ok well it appears that ya have a "Dry Joint" in ya monitor.. I would think around the Horizontal output transformer.. If ya can find the problem and , by opening it up and Tapping the PCB find the bad one & resolder the joint.. but wat with monitors costing so little these days 2nd hand, my advise is to get another..
Posted on Jul 30, 2007
    Problem Solver:
  • 15 Answers
Try replacing another CRT to verify whether this prob is related with the Vedio card or not. Then.... the result will coming.
Posted on Jul 29, 2007
  • Anonymous Jul 30, 2007
    OK. it shows the magnetical circuit in your monitor is not very good. Maybe all of the parts are ok, but some connection points on the board, i mean the soldering point is not very strong. So.....=
    Jimmie
SOURCE:
My monitor screen is black and the yellow standby light is blinking. I can not get the light to stop blinking or get the monitor to show anything, but a black screen. What can I do to coerrect the problem?
mcdevito75 here, Press the SHIFT key, a screen should come up telling you too click on your user name, left lower side of screen. If this doesn"t work, press the yellow blinking light on the monitor see if picture comes back, then follow the directions. If this doesn"t work, shut computer down with switch on the computer itself. Hope this helps.
Jul 17, 2010 | Acer Computers & Internet
My screen just blink then go black. The light show
hello,
The backlight drivers on your power supply board are out. If you check our web site at:
www.ccl-la.com/badcaps.htm We have a step by step repair guide that should get you back going again.
I hope this helps, if so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
[email protected]
Nov 14, 2009 | Xerox XG-91D 19" LCD Monitor
Black screen after a year of use
Sine a flashlight on the screen and check for a dim image. If you see a dim image the back light needs to be replaced. After doing that you will want to try using another monitor cable and see if that helps. If it doesn't with the computer on and the monitor on disconnect the cable from the computer. If the monitor shows a no signal error the graphics card needs to be replaced.
Sep 07, 2009 | Acer AL1916W 19" LCD Monitor
Hi I just bought 7 NEC Multisync LCD1550v monitors and they all have the same problem. when plugged in all i get is a blinking power light. 1 of them showed signs of life for just a second but that was it....
You buy a new LCD Monitors, now still not working., if that new LCD Monitor is OK, then check your VGA Card, its inside the CPU maybe its broke or not connect properly inside. This are the cause of not displaying in your LCD Monitors.
If you here some beeps of your CPU then find out how many beeps and tell us here immediately.
Aug 03, 2009 | NEC-Mitsubishi MultiSync LCD2170NX (Black)...
EMachines E19T5W Flat Panel Monitor - keeps blinking red, green, blue white lines
On the monitor below the screen has these fine pink and green lines blinking across the screen all the time on my laptop. Can you tell me how to fix it or solve this problem?
Aug 12, 2008 | E-Machines 19" Widescreen Flat Panel TFT...
Sony Laptop Screen goes Grey
1.What I need you to test is...When laptop monitor go grey try plug external monitor and see that it work fine or not ??
2.Incase it work fine try to give a little tap behinde the laptop monitor and see that any changes...keep try and harder and see
3.Incase if you gave a hard tap also and its still the same but external monitor work fine then....I think you have problem with your LCD monitor coz there are chips that control the LCD crystal and maybe when it goes hot it behave this way....in this case you can't change the chip...you have to change the LCD.
takecare.
Jul 18, 2008 | Sony VAIO VGN-FS640W Notebook
Monitor Went Black
It sounds like the monitor might be going bad. I would try hooking up another computer to it. If it works with another computer, then I would say the Video card might be going bad.
Mar 01, 2008 | Dell E173FP 17" LCD Flat Panel Monitor
Horisontal lines
make sure the cords are connected properly from both the computers end and the monitor
Feb 03, 2008 | BenQ FP931 (Silver, Black) (Black, Silver)...
Dell monitor
Monitor Help CH000315, Black borders on side of screen. CH000316, Dead or black pixels. CH000403, Macintosh and/or PC monitor compatibility.
Black borders on side of screen. Additional information about what causes black borders on computer displays.
Good Luck, Please dont for get to Vote/Thank You.
Dec 19, 2007 | Samsung SyncMaster 712N 17" Flat Panel LCD...
Black screen, White blinking line on bottom of Monitor
During the move was your laptop dropped or bumped ? If so you might of unseated the video adapter from your laptop. Have you tried another monitor? I wouldnt rule the monitor as the problem. Try another monitor. If you have more questions or problems feel free to get back to me and I will do my best to talk you through a solution.
Sep 19, 2007 | Dell E196FP 19" LCD Monitor
HP Compaq FS7600e CRT Monitor Logo
67 people viewed this question
Top HP Computers & Internet Experts
Ekse
Thomas F. Schneider
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
