Question about Philips WACS700 Shelf System
System does not physically accept CD into slot.
I posted this prob before & it was kindly suggested that I upgrade software from Philips' site: Unfortunately I have no way to load the sofware into the WACS- I obviously cannot use the (Philip's) suggested method of burning it to CD & then loading it....
Also, I contacted Philips & told the guy on the 'phone that I'd be quite happy to pay to have it repaired. He said they'd send me an estimate & arrange for pick-up if I was agreeable.....That was five weeks ago, still nothing from them I'm afraid.
Incidentally: Curry's- where I purchased the unit, were almost, but not quite, damned rude. If I didn't have their extended warrantee I could go f**k myself seemed to be the attitude as far as they were concerned. Well f**k them, they won't be getting any custom from me in the future!
  • dougmeredith Jan 30, 2009
    Hey Abrsvcs,
    Thanks for the prompt reply to my query.
    I am located in Ramsgate in Kent & would appreciate it if you could give me an idea as to where I might get the unit repaired locally I would be extremely grateful.
    Sorry for the cussing, I coulda throttled the sarcastic toe-rag on the other end of the 'phone at Curry's though.....
    Thanks a lot, Doug.
  • 4,234 Answers
Unfortunately, in order to resolve this problem, a visual inspection of the unit is required. The unit must be partially dis-assembled to determine the problem. Where are you located? This should not be a complicated repair job. I will state that access to the mechanism can be a bit tricky, but overall, any shop with prior experience should be able to resolve this.
Please update this with your location and I'll try to point you to a reputable servicer in your area.
Thanks,
Dan
Posted on Jan 30, 2009
  • penfoldj Jul 28, 2011
    Hello I have exactly the same problem but my local repair shop are useless ...im based in Spalding Lincolnshire. Thanks
I had the same problem and, embarrisingly, I got a friend's bithday present CD stuck in the slot. Cost me (so far) AU$53 to get the CD back and for them to tell me there is a problem with the drive and it needs replacing.
Posted on Feb 21, 2009
How do I upgrade the software if I already have the newest update and the TV cannot find software that is downloaded on the flash drive. The TV is unusable
Contact the authorized service center for Philips. Please do not play more with firmware/s with these sets; especially to Philips brand. To get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Feb 15, 2015 | Philips Televison & Video
I have a Philips Home Theater model HTS3051BV/F7 C and I need to change for DVD region free or for DVD region 4, but I have not get procedure for this model. Can you help me please?
try actualize the firmware..go to http://www.p4c.philips.com/cgi-bin/dcbint/eula.pl?slg=ESP&ctn=HTS3051BV/F7&dct=FUS&link=http://download.p4c.philips.com/files/h/hts3051bv_f7/hts3051bv_f7_fus_aen.zip ....
1. Extract the .bin file from the zip file downloaded from this site.
2. Burn the *.bin file to the root directory of a blank CD. Make sure the CD burner is set to
finalize the CD.
3. To select Disc upgrade, press the menu button on the remote. Select Settings\Advanced
Setup\Others\Software Upgrade\Disc upgrade.
4. Use the cursor up/down button to select "Yes", and then press OK. The Disc tray will open
automatically.
5. Insert the Disc. Close the Disc tray.
6. After the disc has loaded, a confirmation message will appear. Select "Yes" and press OK to
start uploading.
7. After the disc update is finished, the unit will shutoff and eject the disc. Do not unplug or
turn the unit off while the software upgrade is in progress.
SW Version Problem resolved
1.005 - The Dolby Pro Logic feature does not function when
Dolby digital two channel audio is the source using
SPDIF (Digital Audio In) input.
1.006 - Unit shuts off after 30 minutes. Do not use the
Network upgrade to this fix this problem.
source philips.com
Feb 14, 2011 | Philips HTS3051B/F7 Theater System
My dvd rom is not working.incase of inserting any c.d or dvd is not working at all kindly solve my prob.my model no is y410 8bq.offering no is 12x6169.and authentication no is 93312xe95e.kindly resolve my...
There might be an issue with the drive or with the OS of the system.
I suggest you to first insert the OS CD and try to boot the CD. If the CD doesn't boot then its problem with the lens of the drive which should be replaced.
Hopefully the CD boots.
Dec 24, 2010 | Computers & Internet
CD will not load.
I had the same problem, i have now upgreaded the firmware off the philips site it was released in 2007 and mine had already been done but i did it again and it accepts the CD now, I just need to get it to read the whole cd content
Jan 01, 2009 | Philips WACS700 Shelf System
Not reading any cd format
Hi i have just been able to sort this problem, if your system says "NO CD" after it is inserted then the CD is not sitting right inside, solution for this is, join the philips club (free) and update the firmware and update the Gracenote software
1, insert the cd so it is in then turn it off and unplug then take another cd insert it in slowly to push the other one down a bit until it stops (may only move a couple of millimetres, you are only using the cd as it fits the slot so don’t try and insert it!!) plug the centre back in and turn the centre on, it will boot back up and eject the cd that’s still in, wait until it is fully booted and insert the cd again, that should work
OR
2, insert the cd so it is in then turn it off and unplug then you can open the product and physically push the cd down (be careful when you take the lid off as the cd will not be fully slotted down and there are a couple of cables that can pop out but they are easy to put back and obvious) Put the lid back on and plug the centre back in and turn the centre on, it will boot back up and eject the cd that’s still in, wait until it is fully booted and insert the cd again, that should work
any probs just mail back and ill help as much as i can
Oct 21, 2008 | Philips WACS700 Shelf System
WANT TO UPGRADE MY SOLDERED DOWN/INTEGRATED GRAPHIC CARD ON LAPTOP,WITH A PLUG-IN CARD?
hi ,
u can upgrade ur graphic card without any prob
cause u have extra pci express slot
u can opt for any gforce or nvidiva graphic card
acc to ur pocket but franly i will not suggest u to do tht
cause u have a very good config of ur laptop
4gb of memory is more than enough
even if u want to play high end games
its just perfect
May 22, 2008 | Sony VAIO VGN-FJ270/B Notebook
Philips HDD120 MP3 Player Problem
Go to http://www.microsoft.com/windows/windowsmedia/player/11/readme.aspx#1792680
and follow the instructions on how to rollback to Windows Media Player 10
OR:
Dowload the latest version of the software from the Philips website - this will uninstall and reinstall a good verison of the Philips software. and then you should be good.
Difficult and timely - a bit. But the only way to save the player.
-Tha Mp3 Dcotor
Jan 09, 2008 | Philips HDD120 MP3 Player
Downloading songs
Grab the software from the Philips website www.usasupport.philips.com - since revamping the site recently, it looks like the original CD software may no longer be available, so load it by entering a slightly different model number - SA6087/37, for instance. click on Software and Drivers, and then "Device/Firmware Manager". After doing this, there is a firmware upgrade available through entering the correct model number of your device on the Philips website.
-Tha Mp3 Doctor
Oct 22, 2007 | Philips GoGear SA261 MP3 Player
WACS700 not readng cd
Could be dirty lenses onthe laser head. Try to clean them.
Oct 01, 2007 | Philips WACS700 Shelf System
Upgrading RAM
Crucial.com has a great scanner that will scan your system and tell you what kind of memory is installed and make suggestions as to compatible pieces. I actually buy from there, but even if you don't their scan tool works really well.
Jun 09, 2007 | HP Pavilion ze4540IUS (ZE4540US) PC...
Philips WACS700 Shelf System Logo
530 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
