Question about Water Heaters
Bradford white 15 yr old power vent runs constant
Pilot light stays on after unplugging...Burnner fires when pluged in...
  • Ron Krysiewski May 11, 2010
    Need a model number!
    Scholar:
    New Friend:
  • 70 Answers
Pilot light will stay on if it is a standing pilot. Turn water heater aqustat down and plug back in. you probably need to clean water heater or replace it. i have drained down a couple of them and took out gas valve and cleaned and put back in worked fine. If you get me a model # i can look it up and tell you some things to try. not sure on yours if it has a different temperature control or if the gas valve is a dual control .
Posted on Feb 09, 2009
How do I light my hot water heater?
It is pretty easy - make sure gas valve is open, change control know to pilot. Press the ignitor a few times and once pilot lights up switch control to warm or hot position.
See instructions by downloading manual for MI-403SF6BN from this site
Bradford White Water Heaters Built to be the best
Sep 15, 2014 | Bradford White Bradford MI403S6FBN-337 40...
Bradford white u45036FRN pilot wont stay lit
1) Copy following link to troubleshoot by type of gas control valve with basic service manual for old and new gas control valve on unit:
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html#intellivent
http://waterheatertimer.org/How-to-replace-thermocouple.html
2) Add a comment and say what you find so far.
Jan 21, 2013 | Bradford White 239-47463-01 ICON Natural...
We have a Bradford White Hydrojet Gas Water Heater. Model# MITW5016CX12. The blower comes on and stays on and the the igniter flame does not light. We are afraid that the blower will get too hot when we...
here's what Bradford White lists....
Burner Will Not Ignite
REASON REMEDY Excess primary air Adjust air shutter to reduce air supply -- if supplied No gas Check with utility Dirt in main burner orifice Clean orifice -- check for source of dirt and eliminate Dirt in gas lines Notify utility -- install dirt trap in gas line Venturi clogged Clean -- check for source of trouble and correct Pilot line clogged Clean -- check for source of trouble and correct Main burner line clogged Clean -- check for source of trouble and correct Defective thermocouple lead Replace with new thermocouple lead Defective thermostat Replace Defective magnetic valve Replace entire control Thermostat set too low Turn temperature knob to desired temperature Heater installed in confined space Provide ventilation by use of louvers in wall or door time for a service tech.
Mar 05, 2018 | Fasco Bradford White Hot Water Heater...
I have a bradford white 40 gal gaswater heater.the pilot will not stay lit.after i light it it fires right up and runs untill it reaches the set temp.then needs to be relit
just the week i repaired a b/w w/ same problem need to replace the temperature control (part where all the lil tubes connect and button where pilot is...shud be on 800 number on w/h or go online www.bradfordwhite.com and enter serial no. might still be under warrnty if not probably cheapr to get new water heater
Nov 18, 2010 | Water Heaters
Bradford White hot water heater - burner lights only 30 seconds
The slightly warm water makes me think of a thermostat problem. The fact that the heater is 10 years old I wonder how hard your water is. Calcium build up kills water heaters. But the yellow flame you mention could be the results of dirty orfices. May want to have a Pro look at that.
May 03, 2010 | Water Heaters
Bradford White LP water Heater Power vent ,flame keeps going out
flue is overheating make sure outlet is not obstructed outside and if not that you feel a good air flow coming from it
Oct 02, 2009 | Water Heaters
Hot water heater does not light
burner and pilot assebly and orifaces need to be cleaned
Sep 16, 2009 | Fasco Bradford White Water Hot Heater...
Bradford White LP water Heater Power vent Will not stay lite. I took off the pipe to the power vent and it will stay lite for a little while. Then it turns off and turns back on. The pipe is not pluged....
does the fan come on, if not there is a problem with the circuit board, if it does then there is a problem with the gas valve or a wire from the gas valve to the fan , if the fan doesn't come on the gas valve is told not to open to light thru the circuit board,
May 03, 2009 | Water Heaters
Water Heaters Logo
234 people viewed this question
Top Water Heaters Experts
Paul Carew
Gil Shultz
Are you a Water Heater Expert? Answer questions, earn points and help others
