Question about Samsung RS2630WW Side by Side Refrigerator
Fridge noise hi the fridge i have makes noises but it wasn't level, it wasn't full of food. now it's less noisy.
  • Todd Born
    Todd Born May 11, 2010
    what type of noise are ypou hearing and about where on the unit.
  • 1,800 Answers
  • Hissing and popping is normal on frost free refrigerators, it is the defrost heater.
  • Check that the refrigerator is level.
  • Check the drain pan.
  • Check the condensor fan.
  • Check the evaporator fan.
  • Inspect the compressor mounts.
plz rate this post
Posted on Jan 30, 2009
Fisher and paykel fridge is making a whining noise only when door is closed. Thanks in advance.
If this is a large cabinet or larder fridge the cabinet is not rigid enough to maintain it's shape unless it rigidly stands level and square. It can take a deal of time and effort to adjust the front feet in order to level and square the cabinet on a relatively flat floor and sometimes it is impossible without first preparing the floor.
It is important for them to stand level and square and at the same time stand firmly on all the feet. If they are allowed to operate out of plumb for any length of time the motor/compressor unit can soon become noisy. Often this is only noticed when the door is closed or open. The door is a major part of the rigidity of the modern fridge and if the fridge is not properly levelled the shape of the cabinet will change as the door is opened and closed causing any compressor noise to be transmitted differently.
The gas charge of the modern fridge can also make weird noises as it is being pumped around the circuit. Ours sometimes sounds like the wind blowing across an open chimney and sometimes like the sea breaking on to a pebble beach and sometimes like something sprung a leak. All this is fairly normal after the fridge has lost it's youthfulness.
Jul 23, 2016 | Fisher and Paykel Refrigerators
Noisy Fridge
sounds like the recirculating fan inside the unit is about to seize. Find it and lubricate it.
Apr 23, 2017 | Samsung RS2630SH Side by Side Refrigerator
NOISY FRIDGE
hi glenn ,most fridges make this noise but if your worried ring the place you brought the fridge from and get them to send an engineer to check it. good luck
regards
shaun
Dec 09, 2011 | Washing Machines
Westinghouse virtuoso fridge is noisy after leaving the freezer door open several hours
First analyze from where you are getting the sound.
1)Check the fan at the back side of the freezer.Is it making noise.Remove it and put some oil so it will rotate without sound.Check for the bending and straighten it and see it
doesn't hit on body.
2)compressor motor may vibrating a lot making noise to the condenser coils.It makes the full fridge to vibrate and makes noise.Adhesive stickers will soften them.If still problem persist coil could be damaged.
post a comment for further assistance.
Thank you for using fixya have a nice day:-)
Sep 06, 2010 | Refrigerators
E440t water pooling inside roof of fridge. then it leaks into fridge when its full. fan was noisy, now not making much noise. maybe its stopped.
THE drain in freezer is frozen over and the water is leaking into the fresh food / clean drain with hot water and turkey baster . this wil correct problem . some units need a drain heater installed to prevent it from doing it again .. mm
Aug 11, 2010 | Refrigerators
My freezer is making this high pitch noise, its an industrial Beaufort freezer on wheels
Zaria:
I have the same kind of fridge and it also makes this kind of noises, however, they are on the acceptable level. They sound more like a seal being happy with the new food. It is not all the time but sometimes. I think it is the contraction and expansion of the pipes that cause the noise and is not a sign of any problem. Of course all depends on the level of the noise you have...
Hope it helps. Greg.
Apr 17, 2009 | LG LRTP1231W Top Freezer Refrigerator
Intermittant noise
hi thanks for the question that buzzing noise is probably coming from the ice maker water valve that's about the time it cycles i would not worry about its fine just a little noise thanks the appliance doc but if it s too noisy replace the water valve
Sep 20, 2008 | Jenn-Air JCD2389G Side by Side...
Noisy refrigerator compressor (?)
This is a compressor problem, and chances are there for this to worsen if not attended promptly.
Feb 06, 2008 | Refrigerators
Hotpoint Fridge freezer FFA90 - Noisy fan top fridge
worthwhile checking closer. noisy fan can be due to fan blade hitting ice if there has been a build-up. otherwise needs replacing
May 07, 2007 | Hotpoint FFA90 Bottom Freezer Refrigerator
Samsung RS2630WW Side by Side Refrigerator Logo
338 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
