Question about Freezers
Freezer quit working
Recently purchased upright freezer 2nd hand. It was working fine when I bought it. Kept freezer upright in transport. No damage at all from transport, but it did get very cold in transport. After transporting it to my place I waited 24 hours and plugged it in. It did not run but did make a slight buzzing noise for 5-10 seconds before the overload sensor tripped off. Tried again a few minutes later, same result. Warmed up the compressor/motor unit really well with a blow dryer and tried again, same result.
Some thoughts:
motor burned up? why?
relay gone bad? why?
overload sensor bad? why?
could the polarity of my outlet be reversed? (but this shouldn't be a factor with an AC motor anyhow, or could it be?)
Compressor/motor is one hermetically sealed unit with 3 terminals. 2 terminals plug in from the relay which I believe is on the hot side of the circuit, the 3rd plugs into the overload sensor on the nuetral side of the circuit.
    Problem Solver:
  • 19 Answers
I suspect when you lifted or moved the freezer, you tilted the compressor such that the oil washed out into the refrigeration lines. Common when people tilt refrigeration equipment the wrong way.
Posted on Feb 07, 2009
When i moved my kic chest freezer model kc0021-Aa, I heard an light explosive sound and now the freezer does not go on.
The following is the GE moving instructions. If you have started before the 24 hour rest period and the unit had been rotated from vertical have the compressor inspected.
FREEZER MOVING INSTRUCTIONS Please use the following steps when relocating an upright or chest freezer:
  1. Disconnect the power cord from the wall receptacle.
  2. Remove the food, defrost, and clean the freezer.
  3. Use blankets to protect the freezer finish from scratches.
  4. Place the freezer on its side for moving only if you have no other choice.
  5. When transporting a freezer, keep it in an upright position. If transporting it in an upright position is not possible, lay it down on the compressor side of the unit. Be careful to secure the door to prevent it from opening.
  6. If it has been transported on its side, set it right side up in its final location and allow the freezer to sit for the same amount of time that it was on its side (24 hrs max.). Do not plug the unit into the electrical receptacle without allowing this settling time. The unit can be damaged if it is plugged in prematurely.
If the unit was transported in an upright position there is no waiting time required.
Hope this helps?
Apr 07, 2017 | Freezers
Can this freezer be laid on it's side or back to transport? Thank you.
Lay down a shipping blanket or an old blanket and transport the freezer on it's back.
Aug 07, 2015 | Freezers
My amana upright freezer was working fine, but transported it to another location when I plugged it back in, it started to make a buzzing noise. How do I turn this off or fix it?
Hello....First...when you transported the freezer...you must sure the unit stays in the vertical position and not laying on it's side...back..or front....If the freezer is making buzzing noises...adjust the thermostat setting down until the buzzing stops...and increase the setting gradually until the desired temp is reached...it could take 24 hours for it to stablize...I hope this was helpful.....PEACE.......
Jan 19, 2012 | Amana Freezers
Layed down freezer to transport in car for long journey left 4 hrs before start up working fine freezing but side edge behind door seal feels quite hot since
this is normal until all the freon has had a chance to get recirculated throgh the system.
make sure the evaporator fan is also working in order to properly cool the freezer.
Oct 09, 2010 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
I purchased a Sears upright freezer in 2007. We keep it in our kitchen. Recently I noticed brown spots on the door of the freezer. Upon looking closer, I discovered it's rust! What can I do? The...
dear sir /madam
i think you should use anti rust spray WD-40 on your door after make clean it with sand paper . after clean make same colour there coz your freezer is working good so i think no need to buy new.
hope answer the question
thank you
please vote!
Aug 23, 2010 | Kenmore 13.7 cu. ft. Upright Freezer 26442
Yesterday, my dad brought me a working GE upright freezer from his house, transport time about 45 minutes. The freezer was working fine before he left his house, he did tip it little bit to load, unload...
You should try to un-plug the freezer and let it stand up-right over night to re-settle the freon back down inside of the compressor.
The compressor should normally get hot if it is doing it's job right, and there is a starter for the compressor motor (usually it looks like a large capacitor) that could have failed, or the defrost timer (if it has one) could be stuck, and you should be able to see the small dial on the defrost timer slowly turning, and if it does not turn, then replace the defrost timer.
Jun 07, 2010 | GE 13.7 cu. ft. General Electric Upright...
Kenmore 14CF upright freezer will die after a day or so
The defrost timer is faulty or you have a defrost circuit short, unplug remove back panel inside the freezer and check for a short in the heater and defrost thermostat.
Dec 30, 2008 | Kenmore 13.7 cu. ft. / 388 liter Upright...
Not Freezing
Check the door seal all the way around. We purchased one recently that was slightly dented (not noticeably and the seal was not tight.) You need to get in touch with whomever you purchased it from immediately so that it can be repaired or replaced.
Aug 18, 2008 | Frigidaire 14.1 cu. ft. Upright Freezer...
Freezers Logo
442 people viewed this question
Top Freezers Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Freezer Expert? Answer questions, earn points and help others
