Question about Linksys WUSB54GSC Compact Wireless-G USB Network Adapter w/ SpeedBooster [WUSB54GSC] (LS-SB54GSC)
No connection I have 2 linksys wireless adapters with speed boost. Only one of them is working at present. Ive tried everything I know possible to get service to no avail. Whats the problem? Since I cant actually TALK to someone about this problem could you please not have me wait several weeks for a solution.
  • 1 more comment
  • sleepy36323 Jan 30, 2009
    I have 2 computers each with the LINKSYS wirekess adapter. Mine is worming fine but computer # 2 has no internet connection. Message reads "NO association with access point". "Adapter is inactive"' Any suggestions?
    Did someone just ask me if my BILLS were PAYED?
    Thank you yes lets do this
  • 1,183 Answers
Since you have two identical wireless adapters from linksys. Swap them around to check if the adapter is failing or the settings are incorrect . I personally think its the adpater .
Additional you can delete the wirless profile , from the computer 2 and create a fresh connection.
Click on the Start button >>> Control Panel >>> Network Connections-
Here right click on the "Wireless Network Connection" icon and select
Properties- Click on the 'Wireless Network' tab- Click on the 'Remove or delete "'
To make a new connection
Properties- Click on the 'Wireless Network' tab- Click on the 'Add'
button below- Provide the network name in the SSID box exactly as set
on the router/gateway(as it is case sensitive)- Data encryption (WEP/WPA enabled) should be checked- Uncheck the box that says, "The key is
provided for me automatically"- Type the network key in the Network
key box as set on the router/gateway and then confirm it again and
click Ok.Check if that works...
Thanks
Proton
Posted on Jan 30, 2009
    Scholar:
  • 118 Answers
Well if I had two of those I would first make sure that the metal on the ends that go into the computer to work and are not damaged. After that I would make sure it's installed properly and whatever system you're using recognizes is completely. If nothing after that, then I would just take it to a local computer store and see if they can see what's wrong with it.
  • 19,396 Answers
"NO association with access point". and "Adapter is inactive"' means that iether the adapter is not inserted properly, or the drivers are not properly installed.
Try first turning off laptop.
Remove battery and unplug adapter from laptop.
Remove card.
RE-plug and restart laptop with no card.
Check is card is in device manager list, if it is there, remove it and restart again.
Reinstall card software.
Insert card if asked by software, or restart laptop.
If you do not have software disk download from Linksys.
If that does not work, the network adapter may be defective, or Windows has a problem with the driver.
    President:
  • 1,990 Answers
Hi there! Don't know a lot about this But, This Might Help. Let me Know if not Please! You can download the drivers nessessary to reinstall your adapter from the Linksys website. Here's you a link:
http://www.linksys.com/servlet/Satellite?c=L_CASupport_C2&childpagename=US%2FLayout&cid=1166859919492&packedargs=sku%3DWUSB54GC&pagename=Linksys%2FCommon%2FVisitorWrapper&lid=1949219492B01&displaypage=download#versiondetail
  • 679 Answers
Try resetting the card (remove from comp. and reinsert) and if that doesn't help, remove the card via Device Manager and reinstall the drivers.
let me know for further assistance.
Thanks
  • rockfixya
    rockfixya Jan 30, 2009
    check this link>>
    http://www.fixya.com/support/t374548-no_...
    hope its helpful.
    Thanks
    President:
  • 2,559 Answers
First off,for live assistance click here and a live tech will assist you
Secondly,Without details to this statement "Ive tried everything I know possible to get service to no avail." we have no idea what has been done.
What errors, if any, do you receive?
How far are you getting in the setup?
    President:
  • 1,214 Answers
First of all, are you trying to connect to a secured wireless network (router)?
If one is working, have you booted that system down, and swapped the adapters, then booted that system back up, and did it work?
We need to work through this systematically, and I can help you do that.
  • 1,800 Answers
First we need to knw if is detecable on ur OS.
also are ur bilss already payed.
  • Jalal Sordo
    Jalal Sordo Jan 30, 2009
    yes sir.
  • Jalal Sordo
    try it in the computer that already works with the other modem.
    Genius:
  • 1,913 Answers
Install driver again. nd check try all usb port on your computer.
tell me the actual eerrors when u connect the inksys adapter to computer.
  • kishor khatri
    kishor khatri Jan 30, 2009
    ok
    u have install driver again after uninstall old driver.
    http://drivers.dltube.net/download13318....
    download driver form here then install.also check that your ip addreses and all settings are correct in your dial up coonectors settings .compare with 1st computer settigns then set same in 2 nd computer .u can do it.
Does it mean my adapter is bad if it just stays lite up green and doesn't flash to try & connect to the internet? I installed everything correctly but it still isn't working. Any ideas? I have a belkin...
The Linksys adapter should have a program you open to find and connect to your router. If not, you can use the Windows Network settings to find your router and connect. Although 54G is a slower speed, they should still connect.
Jan 28, 2018 | Linksys WRT54GX2 Wireless-G Broadband...
Wireless router cannot connect to XBOX Live
I have a linksys 10/ 1000 card and a 2wire wirless router and had the same problem. You need to go to your control panel and double click the wireless network. Once you set it up you need to make sure that if you have a firewall that the xbox has permission to access the net. Also all wireless devices have a security measure some have WEP keys and others have passwords you need to find out what yours is.
Jul 20, 2009 | Microsoft Xbox 360 Console
Question For Experts ONLY
It's true that using router and adapter of the same brand will give you maximum performance. And YES, you can confuse both router and adapter. No matter whats brand, you can boost your adapter performance by changing its link speed or duplex to 100M/Full Duplex. This will gives you maximum performance then Auto Function of the Duplex.
Logically its NOT True but Practically I have done it many time.
Regards;
Hassan
Jul 15, 2009 | 2wire (1000-400108-001) Router
Linksys WGA54G ver.1 cannot find
Try to use the game adapter as your wireless adapter to test if it is still working. Connect the game adapter to your PC and then configure it manually. Assign a static IP address on your PC same range as your game adapter and then configure the wireless settings same as your router. the Default IP address of the game adapter is 192.168.1..250.
Jul 04, 2009 | Linksys Wireless-G WGA54G 802.11g/b...
Good Signal,Good Mbps, Slow Internet Connection?
1. Try to use a different wireless adapter on all available USB ports, if the problem remains then
2. turn off your PC unplug the power cord from the power socket, short the two legs of the power cable then leave it for 5min, then plug it into the power socket again and turn on the PC.
if this didnt work then you have a hardware problem with the USB ports.
let me know how it works out.
Nov 30, 2008 | Linksys WUSB54GSC Compact Wireless-G USB...
Good Signal, Good Speed, Slow Internet?
Try plugging the computer straight to the router.If all is well the adapter may need a firmware or driver update.Or your adapter may be experiencing some type of heat problem or failingRICHARDM69
Nov 29, 2008 | Linksys WUSB54GSC Compact Wireless-G USB...
How can i connect notebook and desktop wireless
192.168.1.1 then enter the password, and your up, let me know...
Bobby
Nov 11, 2008 | Linksys Wireless-G WRT54GS Router...
Hooking up my gaming router
There is a 90 % possibility that the wireless settings on the gaming adapter and the router are not the same. Try to reconfigure this again. Remember that the gaming adapter's wireless settings needs to synchronize with that of the router to make the gaming adpater works. Call netgear and verify the settings on your wireless connection and reverify the settings you have on the adapter. For manual instructions, see user guide at www.linksys.com/download
Oct 15, 2007 | Linksys Wireless-G WGA54G 802.11g/b...
Linksys WUSB54GSC Compact Wireless-G USB Network Adapter w/ SpeedBooster [WUSB54GSC] (LS-SB54GSC) Logo
23 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
