Question about NorStar Meridian M9516 Phone w/ Digital Answering Machine (NT2N42)
On the m9516 what is the fax switch on and off used for?
I dont know what the fax switch function is used for or when to use it
can anyone help because i can not find my owners manual
  • 21 Answers
The Fax Switch
The Fax Switch feature allows you to have two telephone numbers on one incoming line.
There is one telephone number for the line and another telephone number for a Fax Switch peripheral (e.g. fax machine).
To use the Fax Switch, you must subscribe to your telephone company for Distinctive Ringing†. The telephone company will then provide you with an additional telephone number (for your Fax Switch peripheral) which will have a slightly different ring. The 9516 will use the two ring types to determine whether an incoming call is for the telephone or the peripheral. The peripheral should be set to answer after three or more rings.
Note: If Long Distance Ringing† is available in your area, long distance calls will be sent to the Fax Switch peripheral. Also, you cannot use the Fax Switch feature and the Special Greeting feature at the same time. The 9516 must be configured so the Fax Switch peripheral is connected to pins 3 and 4 of jack number 2. See Connecting an optional fax machine or modem on
page 4 for more information.
If you subscribe to your telephone company for Call Waiting services, your Fax Switch peripheral may lose data or get disconnected if someone calls while your fax is receiving data. We recommend that you do not subscribe to the Call Waiting service from your telephone company if you are using the Fax Switch feature.
Posted on Apr 30, 2009
I can send fax cant receive fax the it says the problem ishould swith the drd to 3 i dont know where to find the drd
1.- Turn the machine On - Off
2.- Press the Fax function
3.-Press the automatic receiving switch to " on position "
Godd luck wilsoncopier
Feb 16, 2011 | Office Equipment & Supplies
I have Canon L-220 Plain Paper Fax. It only prints the first page of any fax received, not the rest of the pages. How to reset the fax to defaults.
Please download the product manual and look for the troubleshooting and resetting information. Also, make sure that the telephone line is functioning properly.
Let me know if any further clarification/ assistance is required.
Dont forget to appreciate the solution if I could have been of any help!
Dec 11, 2010 | Canon L220 Plain Paper Laser Fax
I have a fax-100 machine. it wont send or receive at all. the display reads 'memory full'. i dont have an advanced user guide. help please.
I don't know what brand fax 100 is. But if the memory is full you might try the following.
Unplug the power form your unit for 24 hours and then restart it. The memory should clear itself. ( you really have to unplug it not just shut off the switch if it has one).
There are reasons why the memory got full in the first place. Either the phone line was off and transmitted documents never sent or the receive function was disabled due to a paper jam, out of paper, or toner or a spent drum.
Good luck.
Jul 29, 2009 | Office Equipment & Supplies
"TX Function Not Completed"
Open up the document feeder and check to make sure no switches are trapped down.
Jun 28, 2009 | Canon PIXMA MP780 All-In-One InkJet...
Faxes in memory
To retrieve faxes from the memory simply press the Function key, followed by the memory referance key then press OK.
hope this is of help to you folk out there struggling with this machine as i am.
Jan 29, 2009 | Canon L220 Plain Paper Laser Fax
L200 not functioning
Have you got anything else within the line with the fax machine that is maybe holding the line like a credit card machine or a phone? if so remove everything and just plug in the machine to a straight line.
This could be due to a memory problem, you need to do a function memory clear and this might clear your fault
hope this helps.
Oct 21, 2008 | Canon FAX-L200 Plain Paper Laser
Need the driver for it
You can't use it as a printer, it has no connections for the PC.
It's just a Phone/Fax/Copier.
Mar 04, 2008 | Panasonic KX-FP121 Plain Paper Thermal Fax
Panafax UF-S1, Memory full.
i just dont know if ufs1 is the same with ufs10
if so
function #*##
right arrow till you found ram initialize
Feb 21, 2008 | Panasonic KX-FHD331 Plain Paper Thermal...
Drops connection after connect, sends 2-3 pages
The fall-back required for transmission over VOIP is not available on this machine. It is a service mode function and can only be set by a technician. However, VOIP is so iffy for transmission that you may require fall-back to 4800 or even 2400. I have found that forcing fall-back more than 2 steps doesn't work.Also the Line equalisation can't be set as there is only 3 settings, 1.8;3.6; and 7.2 Km. Who knows how far to set VOIP, could be 3000KM. I had more success using a very old fax machine sending at 2400BPS that I could set the dip switches. Takes all sorts of changes to have success and then next time you try, it's changed again.
Feb 15, 2008 | Panasonic Panafax UF-885 Plain Paper Laser...
Samsung Fax machine - not working
Sounds like the machine is trying to talk to the computer make sure the function is set to fax mode this will be in your manual.
Once you have tried this try sending a fax see what happens.
Hope this is some help to you please rate me.
Dec 07, 2007 | Samsung SF-5100 Plain Paper Laser Fax
NorStar Meridian M9516 Phone w/ Digital Answering Machine (NT2N42) Logo
274 people viewed this question
Top NorStar Lands Phones Experts
Oloyede Monsuru
Are you a NorStar Lands Phone Expert? Answer questions, earn points and help others
