Question about Rancilio Epoca ST
Rancilio epoca - heating element continue to stick on
On my 2 group commercial machine - when the machine heats up the water in the boiler - it will not stop in the green like it used to - contines way into the red then the release valve goes off to relieve heat-
we thought it was the 3/8 gasket that went out - have had that happen before - but not he case - watched it and continues to get hotter and hotter - like a thermostat - looked at my diagram of machine and not sure which part it is - any help would be great
I have an epoca de 2 group manufacture 11/2004. I replaced the Parker pressure switch ( I Had to do alot of research to find out it didnt have the sarai pressure switch)when it was overheating and it works.
Posted on Jun 04, 2013
    President:
  • 1,214 Answers
It's the thermostat for certain.
Te release valve is put there it be sure the tank pressure doesn't get too high such as to cause a steam explosion/rupture of the tank.
Posted on Jan 30, 2009
My Rancilio Epoca ST1 would not turn on yesterday so I unplugged the machine and plugged it back in and it started right up. Today I turned the machine on and it warmed and pressured up as usual and then...
That's a tough one, the only thing I can think of is checking the reset switch and the element with an ohms meter to see if they are functioning correctly, before moving on. The only reason the machine would turn itself off, would be lack of water in the main boiler and if it does not know there is water in the reservoir, or it cannot take water from the reservoir to fill the boiler, or the element is overheating so *** trips the reset.
Jul 12, 2011 | Rancilio Epoca ST-1 Espresso Machine
Rancilio Epoca DE 2 group espresso machine
Seems to be a problem with either the elctronics sensors, or the "brain" itself. Did you get the machine serviced by an authorised service center, or a local repair guy?
Jun 28, 2008 | Rancilio Silvia Espresso Machine
SilviaWhen running wster thru group head to warm up machine, noticed foamy-smelly water. Ran more - now have almost black water with tiny black specs.?
You have huge corrosion and scale in the boiler. Your heating element will be fried soon. Boiler must be opened up and cleaned, element may be salvageable. USE ONLY BOTTLED WATER NEVER EVER TAP.
www.dolcevitaespresso.com
Jan 23, 2011 | Rancilio Silvia Espresso Machine
Hi! I have a Rancilio epoca DE 2 group machine and the antivacuum valve spurts water as the machine is heating up. ow can I fix this? Please advise
Your boiler is flooding because the water level probe is not behaving properly. The machine thinks it needs water.
Jan 09, 2011 | Rancilio Epoca ST-1 Espresso Machine
My rancilio epoca s1 won't start.
HI
Without being in front of it, there are a couple of things to check.
1. There is a reset button on top of the boiler. It is a black top with a red button in the center between 2 wires.
2. The water tank needs to be emptied and then refilled.That is the first things I would check.
Oct 02, 2010 | Rancilio Epoca ST-1 Espresso Machine
Water safety sensor preventing heat up of boiler?
If the red light is on then the machine is not getting water and or level is low in boiler. Try this remove the bell looking softener and run it under the faucet to see if water flows through, it could be that is blocked and not letting water through, and if so then the reset switch for element might have tripped because machine has low water.
Jul 02, 2010 | Rancilio Epoca ST
Rancilio epoca 2 head machine. Lights are flashing in a line (like arrow) on both sides. pressure is up a little on one side, but not other. water is cold,
Machine is not heating, the lights should flash until it heats up to 1.2 bar on the top gauge. If not check the water level in the machine and check the red reset switch to see if the thermostat tripped.
Jun 28, 2010 | Rancilio Classe 6 E 2 gr Espresso Machine
Rancilio Silvia coffee machine worked once and the
Remove the top panel one of the thermostats on the tank tripped, reset thermostat, and turn machine on.
Dec 25, 2009 | Rancilio Silvia Espresso Machine
Not heating up the water
Hi
3 things could be wrong. First is easy to check. With machine on, turn on the steam switch and after about a minut open the steam knob and push the middle switch. Check the water coming from the wand and see if its warm? If it is you need a brew thermostat. Unplug the machine. Remove the water tank. Remove the 4 screws that hold the top on and lift top off. The boiler has 2 thermostats on the top front of the boiler, and the one with the red dot is the brew thermostat and need replacing.
If that didn't fix your problem there is a reset thermostat on the front face of the boiler and has black wires going to it. There is a red button in the middle of the thermostat and needs to be pushed.
If that one didn't solve your problem you need a new heating element. You can do a continuity check on the terminals.
Apr 20, 2009 | Rancilio Silvia Espresso Machine
Rancilio class 6 E compact authomatic spilling water
  1. check the solenoid valve and electronic comand for boiler filing. solenoid valve could be leaking, electronic part could have weak contact with level detector wire or relay (driver of solenoid valve and motor) has bad contacts, and does not open circuit circuit remains all the time closed.
  2. check the presurestat, be sure that he opens cirquit at 1.5 bar snd does not angage heating element to heat up more.
Aug 13, 2008 | Rancilio S24 Espresso Machine
Rancilio Epoca ST Logo
373 people viewed this question
Top Rancilio Coffee Makers & Espresso Machines Experts
vilhj
Level 1 Expert
Are you a Rancilio Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
