Question about Windsor SR12 Sensor Bagged Upright Vacuum
Dirt Devil vacuum
When I turn my Dirt Devil the motor sounds very loud- any suggestions. Thanks
    President:
  • 1,673 Answers
You might unhook the belt, if it still sounds real loud, then the motor is bad and will have to replaced.
Posted on Jan 06, 2008
SOURCE:
Why does my dirt devil vacuum run so loud?
If a vacuum gets loud all of the sudden it might mean the fan or impeller is broken or cracked which makes it out of balance.
Jul 07, 2018 | Dirt Devil Vacuums
Making loud noise dyson
Give this site a try: repairclinic.com/RepairHelp/How-To-Fix-A-Vacuum-Cleaner/115-204-709304-/Dirt-Devil-Vacuum-cleaner-brush-not-spinning-M085845
Hope this helps if that's the cause of the loud noise.
Johnstown Epoxy Garage Floor
Sep 29, 2013 | Dirt Devil Featherlite Bagless Vacuum...
Very loud "jet like" noise,please
Vacuums are noisy, but shouldn't sound like a jet.....
Trying to find out what is wrong depends on what kind of noise it makes, i.e. high squeal, vibration, whining and where it comes from.
Here is a webpage with troubleshooting advice on noise in vacuum cleaners. Hopefully you should be able to track down the problem. http://www.ehow.com/how_7493926_fix-noise-vacuum-cleaner-motor.html
If you need further help with repairs, please reply back. Thanks,
Handie Andie
May 09, 2011 | Dirt Devil Reaction Twin Cyclone Upright...
Low Hose Suction, Hose is open.
thanks for the clarification.
since the hose in unclogged, the next place to look is in the body of the vacuum.
there is usually a tight turn in the dirt channel in the base. often you can see the clog if you remove the hose.
the next step is to dissasemble the base and look for the clog.
does the motor sound normal?
is the impeller turning at a normal fast rate?.
Jan 07, 2010 | Dirt Devil 12 Amp HEPA Filter Vacuum...
Vacuum making loud noise
It could be 1 of 3 things:
1. The belt2_bing.gif that drives the beater bar. (Inexpensive)
2. An impeller that has a broken wing or 2, throwing it off balance. (Expensive)
3. Or, the bearings in the motor are going out. (Expensive)
Hope this helps,
Jim
Nov 27, 2009 | Dirt Devil Featherlight Bagless Upright...
No clogs, work fine, but makes a very loud wailing sound? what could it be?
My Dirt devil Reaction does the same thing. So I took apart the motor and it was crammed w/ dirt then I decided to clean it out. next time I vacuumed my house it was a lot quieter. The guy from Jones sew and vac said baggless vacuum filters most of the time fail and let dirt get in the motor and start to scream. I read a lot of things saying Dirt devil Reaction is the most common vacuum to get dirt in the motor and start to wail then get worse & worse and get to the point where they start to almost scream. P.S if you let it scream for along time of use it will give the motor permanent damage and you will smell electrical burning, if that happens it will be too late so you will half to buy a new machine. To get to the motor you can take the dust contaner off and take the black filter then use your down stairs vacuum and get a small attachament and stick it in and vacuum it out,if not have two vacuums borrow one. If that doesn't clean it out you will need to take all the plastic appart and realy get to the motor good. If my advice dosn't help it is ok to still use it, it will just be loud until the motor of it is totally fried. This should work it worked on my Dirt devil Reaction. I'm sorry if it doesn't work out. :D
Apr 17, 2009 | Dirt Devil Reaction Twin Cyclone Upright...
Dirt devil bagless vacuum doesn't run,
unplug the vacuum and try tu turn the brush roller by hand a few turns .plug it back in and try it again.if not try another plug in the house.you might have a bad connection at the motor or the motor itself is bad
Dec 19, 2008 | Dirt Devil Featherlight Bagless Upright...
I replaced the belt on my Dirt Devil Featherlite Bagless Vacuum and the brush roller rubs and makes a very loud noise when turned on. I have gone exactly by the manual instructions and made sure the belt...
http://www.geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=561283
Generic problem for all Vacuums
Posted by piggytail on May 01, 2008
I replaced the belt on my Dirt Devil Featherlite Bagless Vacuum and the brush roller rubs and makes a very loud noise when turned on. I have gone exactly by the manual instructions and made sure the belt and end caps were on correctly, but the bristles still rub the back and it makes a very loud noise. Without the brush roller in the vacuum, it sounds and runs normal. What could the problem be?
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure.
The Royal Dirt Devil Featherlite Bagless Vacuum has just bushings in the ends of the brushroll and not bearings and once the bushings are bad I suggest that you replace the brushroll in the vacuum and put a new belt on the vacuum as well. There is no way to repair the bushing s in order to it to work properly. The suggested belt change is every 4 to 6 months and to store the extra belts in a Ziploc bag in the refrigerator to keep them fresh. Suggest looking at a local vac dealer. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.royalvacuums.com
Customer Service
For help with a model that is not working, if you want to check an order, if you need help finding a part or service center or have any other comment, complaint or question that is not a technical question about this web site use the link above. You can also call our Customer Service department between 8AM and 7PM EST Monday through Friday at (800) 321-1134.
www.A-1Vacuum.com 1-800-657-1874 If you cannot find a local dealer near you they can ship you the parts UPS.
Don – The Vac Man
Go Ahead. Use Us.
May 01, 2008 | Vacuums
Windsor SR12 Sensor Bagged Upright Vacuum Logo
674 people viewed this question
Top Windsor Vacuums Experts
Mike
Thatvacguy.com
Are you a Windsor Vacuum Expert? Answer questions, earn points and help others
