Question about Sony CDP-CX400 400-Disc CD Changer
Lens Knocking Against The CD - All CDs skip or diginoise then fail.
I purchased a CDP-CX400 a month ago. It worked fine for about 3 weeks. Now, every CD skips. I used both a CD Lens Cleaning Disc, as well as taken the machine apart and manually cleaned the lens to no avail. In an attempt to trouble shoot, I watched it load a CD and attempt to play it. The Lens is 'knocking' against the CD surface repeatedly. Sometimes the disc will start to play and then stutter or begin skipping.. occasionally it will play the CD with lots of digital noise. HELP! I got it for cheap on Craig's List and it worked beautifully for 3 weeks before this started happening.
    Problem Solver:
  • 5 Answers
Take the small back cover off and take some electrical grade contact cleaner and spray all around the lens area, that worked for me.
Mike
Posted on Feb 10, 2009
I need the 3 belts for sony cdp cx355 cd player. Do you carry these belts
here are the belts. http://www.ebay.com/itm/SONY-CDP-CX300-CDP-CX335-CDP-CX350-CDP-CX355-CDP-CX400-Drive-Belt-Kit-3-belts-/152184107208?_trksid=p2141725.m3641.l6368
Nov 10, 2016 | Sony Audio Players & Recorders
I have a Sony CDP-CX400 that has a flashing blue light.
sounds like the mech may be out of alignment. I would try running it by hand and making sure everything is moving correctly.
Mar 25, 2014 | Sony CDP-CX400 400-Disc CD Changer
Cdp-ce315 skips in songs
My answer here only concerns if you're trying to play burned audio CDs. Burn your audio CDs at the lowest speed (1). Try the JVC/Taiyo Yuden brand.
Nov 09, 2011 | Sony CDP-CE315 5-Disc CD Changer
The music is skipping a lot on all discs played on the device
are there scratches on the disks if so i recomend replacement but the lens might be dirty if so you can go to a local walmart and purchase a cd/dvd cleaner and i have provided a link
 http://www.walmart.com/ip/Innovera-CD-DVD-Laser-Lens-Cleaner/14915544
Jan 02, 2011 | Sony CDP-CX400 400-Disc CD Changer
I bought a Radio Shack cd cleaner (cd w/little brush on it) to clean the lens of the cd player however the machine won't recognize the disc when inserted so I cannot figure out how to "play" it. Many of...
yes here is a simple easy way to get them to stop skipping, stick them in the freezer portion of your fridge, only if the cds have scratches on them, even the smallest scratch can cause a perfectly working cd player to make the cd skip, stick the cd in the freezer for about 15 or 20 mins and pull it out and play it, i have used this method for a lot of my video games as well and have never had to buy any "cd player cleaner cds" i hope this helps
Jul 16, 2010 | Sony CDP-CE575 5-Disc CD Changer
ALL SEEMS FINE BUT WON'T PLAY DISCS. FLASHING BLUE LIGHT INSIDE.I GET "LOADING ERROR" ON SCREEN, AFTER A COUPLE MINUTES. SONY CDP-CX400
I would suggest taking a can of compressed air to the disk tray to ensure the laser is clear of all possible debris
Mar 30, 2010 | Sony CDP-CX400 400-Disc CD Changer
Cds dont load and tracks will skip during song play
It is clear symptoms of bad optical laser or dirty optical lens.
Please put lens cleaning CD in player, play that CD to clean dust on optical lens surface. If that helps, fine or replace optical laser block in player.
I can provide you optical lens part number, please confirm is it Sony CDP-CX153 cd player or any other model.
Thanks.
Oct 27, 2009 | Sony CDP-CX153 100-Disc CD Changer
Music speeds up,skips pulsating noise
Ok, this is optical lens assembly failure. the lens assembly is a whole device that runs on a rail with rail motor. the spin motor is also attached to this Assembly as well. the entire assembly will need to be replace due to the damage that has occurred.
Replacing the optical lens assembly will fix all the issues you stated.
May 31, 2009 | Sony CDP-CX235 200-Disc CD Changer
Denon DCM 390 not longer reads discs--HELP!
Hi there, this lens may be dirty or it may have a thin layer of heat film that is causing it to not read in a consistent manner. i would try to clean the lens with a good CD lens cleaner. if the cleansing doesn't restore the lens to its original reading state, this will confirm lens assembly failure and you will need to replace this assembly.
May 17, 2009 | Denon DCM-390 5-Disc CD Player
Playback jumps around
Pull the small back cover off and Purchase a can of CRC Electrical Grade Contact Cleaner, un plug the unit all around the len board and the whole genral area that should take care of the problem! it did for me.
Mike
Jan 11, 2008 | Sony CDP-CX400 400-Disc CD Changer
Sony CDP-CX400 400-Disc CD Changer Logo
522 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Gyula Lacz
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
