Question about AudioCodes MediaPack MP-114 FXS and FXO Analog / Digital Phone Line Converter
Lost Default IP Settings screen after Mult. Interface Table
I no longer have access to the default IP Settings screen, once I click Mulitple Interface Table Screen from the IP Settings screen. The default is now the Interface table. I looked though the user guide, but could not find a reference on how to default back to the standard IP Settings screen.
Now when you highlight IP Settings the Interface table appears.
  • Anonymous Mar 10, 2009
    same problem here but using AudioCodes Mediant 1000
    New Friend:
  • 20 Answers
You have to do a factory reset to the device or it wont go away, make sure you dissconnect ethernet cable when doing the factory reset.
Posted on Nov 25, 2013
Forgot ip address and password
To re-enable the Console access requires the SW2900 series to be reset to its default settings via the WEB INTERFACE
- Web Interface
- Device >Configuration >Initialize To change the Default User "ADMIN" password it is necessary to use the Console connection
-Console Interface
-Once the unit has successfully booted and the prompt presented
-Enter "password" (without "")
-Enter "admin" when the system prompts for User
-Press the "Enter" key when the system prompts for "Old Password" (the ADMIN password was reset by the Web Interface commands)
-Enter "" when the system prompts for the New Password (where "" is the new product ADMIN password)
-Enter "" when the system prompts to confirm the New Password In order to complete the configuration it is necessary to save the configuration via the WEB INTERFACE
-Web Interface
-Device > Configuration > Save
Symptom:
SW2900 Baseline Switch - Default console access disabled following password change
From the web interface, the default user "admin" password is changed and console access is disabled
Cause:
When applying the new password, by default the service-type is set to "telnet". When applied, the default "terminal" setting is removed thus disabling console access.
Apr 20, 2013 | 3Com Baseline Switch 2924-SFP Plus
How to block lan IP
IP filtering is a method used to block computers on an internal network from accessing the Internet. This is often used on critical machines on the network, such as servers. It blocks users from accessing the Internet to protect these machines from malware. You can filter IP addresses on your router using the administrator console provided by the router's manufacturer. Once the block is set up, each user machine listed in the filter settings will no longer be able to access the Internet.
Open your web browser and type in the IP address for your router. For most default settings, the IP for the router is 192.168.1.1. Enter your admin username and password. If you have not set them up, try leaving the username black and the typing "admin" for the password. Click the "Security" tab at the top of the window. This opens a new console screen. Within this screen, click the "Filter" link. A list of text boxes is shown where you enter the IP addresses you want to filter. Enter a range of IP addresses you want to block. You can enter one IP address or several. Click the "Save Settings" button. Hope this helps.
Dec 07, 2012 | D-Link DSL-2540B ADSL2/2 Modem with 4-Port...
What is the default ip address for powerconnect 5212
You must assign an IP address to the switch to gain management access over the network. You may also need to a establish a default gateway between the switch and management stations that exist on another network segment. You can statically configure a specific IP address or direct the switch to obtain an address from a Boot Protocol (BOOTP) or Dynamic Host Configuration Protocol (DHCP) server when it is powered on. Valid IP addresses consist of four decimal numbers, 0 to 255, separated by periods. Anything outside this format is not accepted by the CLI program. notice.gif NOTICE: By default, the IP address is assigned to VLAN 1 through DHCP. If you select the bootp or dhcp option, IP is enabled but does not function until a BOOTP or DHCP reply has been received. Requests are broadcast periodically by the switch in an effort to learn its IP address. (BOOTP and DHCP values can include the IP address, default gateway, and subnet mask).
To display assigned IP settings using the CLI:
  1. From the Privileged Exec or Normal Exec level mode, type show ip interface and press <Enter>.
The assigned IP address and subnet mask displays.
  1. From the Privileged Exec mode, type show ip redirects to display the assigned gateway IP address. Press <Enter>.
The following example displays IP settings assigned by bootp or dhcp using the CLI.
Console#show ip interface
IP address and netmask: 10.1.0.1 255.255.252.0 on VLAN 1,
and address mode: User specified.
Console# show ip redirects
ip default gateway 10.1.0.254
Console#
Before you can assign a static IP address to the switch, you must obtain the following information from your network administrator:
  • IP address for the switch
  • Default gateway for the network
  • Network mask for the network
To assign a static IP address to the switch:
  1. From the Privileged Exec level global configuration mode prompt, type interface vlan 1 to access the interface-configuration mode. Press <Enter>.
  2. Type ip address ip-address netmask, where ip-address is the switch IP address and netmask is the network mask for the network.
  3. Type exit to return to the global configuration mode prompt. Press <Enter>.
  4. To set the IP address of the default gateway for the network to which the switch belongs, type ip default-gateway gateway, where gateway is the IP address of the default gateway. Press <Enter>.
  5. To save your configuration changes, type copy running-config startup-config and then press <Enter>.
notice.gif NOTICE: Only one VLAN can be assigned an IP address. If you assign an address to any other VLAN, the new address overrides the original IP address. The following example shows how to set a static IP address using the CLI.
Console(config)# interface vlan 1
Console(config-if)# ip address 192.168.1.5 255.255.255.0
Console(config-if)# exit
Console(config)# ip default-gateway 192.168.1.254
Console(config)#
To configure the switch for DHCP or BOOTP:
  2. At the next prompt, use one of the following commands:
    • To obtain IP settings through DHCP, type ip address dhcp
    • To obtain IP setting through BOOTP, type ip address bootp
  3. Press <Enter>.
  4. To save your configuration changes, type copy running-config startup-config, and then press <Enter>.
Nov 26, 2012 | Computers & Internet
My default IP ADRESS is192.168.1.1, and am trying to change my router password for wireless connection
If you ever lose your settings or if your settings are changed and the router is not functioning properly, you can come to this area to restore your saved settings from the backup file you created. Click Browse to locate the backup settings file you previously created. When you have located it, click Restore and the settings saved within this file will be applied to the router. If you did not create a backup file, you may need to restore the factory default settings.
device3.gif Factory Settings If you ever want to erase all personal settings of your router, come to this area and click Reload to restore the factory default settings. All the current settings will be lost. If you change the router's configuration and it stops functioning properly you can reload the factory settings to fix it.
device3.gif The other method to restore the factory default settings is to press in and hold the RESET button on the Wireless MAXg Router for between five and ten seconds. You will lose all of your personal settings if you restore the factory default settings. You might need to do this if you are unable to access the Web User Interface or have forgotten your password.
Nov 07, 2010 | U.S. Robotics MAXg USR5461 (738168036790)...
Hello can u help me with the default user and password for an ASSUS router? i lost the old user manual and i reset it to default and i forgot the default user and password to set it. thx
Connect youra router to computer with ethernet cable then you can access it with following default link. http://192.168.1.1 or http://192.168.0.1 or http://192.168.15.1 or http://192.168.2.1 If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it. Then it ask for user name and password. Type user as "admin" and password as "admin" or "password" or blank. Then you can see configuration page of router. Then configure wan settings and lan settings enable wireless if you want to use wifi . Let me know if you need further assistance. Thanks for using FixYa.
Oct 04, 2010 | Gateway Computers & Internet
Reset cisco airnet 1130ag
There are 2 ways to reset the access point.
Using the MODE Button
Follow these steps to delete the current configuration and return all access point settings to the factory defaults by using the MODE button:
1. blank.gifOpen the access point cover
2. blank.gifDisconnect power from the access point (the power jack for external power or the Ethernet cable for in-line power).
3. blank.gifPress and hold the MODE button while you reconnect power to the access point.
4. blank.gifContinue pressing the MODE button until the Ethernet LED turns amber. (approximately 2 to 3 seconds). Then release the button.
5. blank.gifAfter the access point reboots, you must reconfigure it using the web browser interface, the Telnet interface, or the access point console port.
Using the Web Browser Interface
Follow these steps to delete the current configuration and return all access point settings to factory defaults using the web browser interface:
1. blank.gifOpen your Internet browser. You must use Microsoft Explorer (version 5.x or later) or Netscape Navigator (version 4.x or later).
2. blank.gifEnter the access point IP address in the browser address line, and press Enter. An Enter Network Password screen appears.
3. blank.gifEnter the username Cisco in the User Name field.
4. blank.gifEnter the password Cisco in the Password field and press Enter. The Summary Status page appears.
5. blank.gifClick System Software. The System Software screen appears.
6. blank.gifClick System Configuration. The System Configuration screen appears.
7. blank.gifClick the Reset to Defaults button.
Note blank.gifIf the access point is configured with a static IP address, the IP address does not change.
8. blank.gifAfter the access point reboots, you must reconfigure it.
Aug 13, 2010 | Cisco Aironet 1131AG 802.11a, 802.11g/b...
How to open asus wifi router home page?
In order to access the web interface of the router you should know the IP address of the router. Please try the following steps to check the ip address on the computer which is connected with the router (wired/wireless doesn’t matter).
1. Click on start the go to run and try cmd and click on ok.
2. Type ipconfig and press enter.
3. look for the default gateway numbers.
the default gateway is the address of the router. Open internet explorer and type http://default gateway numbers (for example http://192.168.1.1)
It should take you to the web interface of the router on which authentication is needed. The default user name and password is admin and admin.
Let me know if it help.
Rashish
Aug 09, 2010 | ASUS WIRELESS ROUTER |WL-520G - RT...
Password
Go to the SMC site and download the appropriate manual.
For Windows XP, it says:
"To access the Router’s management
interface, enter the Router IP address
in your web browser http://
192.168.2.1. Then click LOGIN.
(By default, the password is
smcadmin. The default is case
sensitive.)"
Once you are logged in, you may change your password under the System -> Password Settings section.
Please Approve of this answer if I answered your question.
Jul 20, 2010 | SMC Barricade g SMC2804WBRP-G Wireless...
How to reset Paradyne (1740A1400) Router ?
Hi Samsungvt!
You will have to access the Web Interface of the Paradyne Router to reset it to Factory Defaults.
First, connect your PC to the Paradyne Router. Check your IP address is in the range 192.168.1.xx (xx = any number from 1-254). Open your web browser, type 192.168.1.1 then press enter. Enter the default username and password (shown below) to access the router's web interface. On the left pane, click Erase and Reboot; this will reset the router to factory default.
Default IP address is 192.168.1.1
Default Username and Password: root
Let me know if there's anything else...
Anthony
Jun 21, 2010 | Paradyne (1740A1400) Router
I would like to know how to reset the Lexmark E260dn to factory defaults. The printer was set with a static IP address and no longer exists on THAT network. I need to set it up as a DHCP client again to...
Restoring the factory default settings
Do one of the following:
• If your printer is on a network, access the Embedded Web Server:
1 Type the printer IP address into the address field of your Web browser.
Note: If you do not know the IP address of the printer, print a network setup page and locate the IP address in the TCP/IP section.
2 From the Settings screen, click General Settings.
3 Under Factory Defaults, select Restore Now, and then click Submit.
• If your printer is connected to a computer by a USB or parallel cable, use the Local Printer Settings Utility for Windows or Printer Settings for Macintosh.
1 Open the utility.
2 Do one of the following:
– From the Local Printer Settings Utility menu bar, click Actions Restore Factory Defaults.
– From Printer Settings, click Factory Defaults.
Warning—Potential Damage: Restore Factory Defaults returns all printer settings to the factory default settings except Network/Port menu settings. All downloads stored in RAM are deleted. Downloads stored in flash memory or on a printer hard disk are not affected.
Or please download the user guide from this link and follow the instructions
http://static.tigerdirect.ca/pdf/Lexmark-E260D-Series-Mono-Laser-Printer-Manual.pdf
Hope this will help you
thanks
Oct 01, 2009 | Lexmark E260dn Laser Printer
AudioCodes MediaPack MP-114 FXS and FXO Analog / Digital Phone Line Converter  Logo
369 people viewed this question
Top AudioCodes Computers & Internet Experts
Mick Bowen
Mick Bowen
Level 1 Expert
Are you an AudioCodes Computer and Internet Expert? Answer questions, earn points and help others
