Question about Hitachi 55HDS69 55 in. Plasma Television
Hitachi 55hds69 powers on no picture blue led blinks 8 times
Replaced power supply already no change, main board leds blink in sequence and shut off during power on.(Which is how they should)
After blue led blinks 8 times it will go to amber.
appears that voltages are not getting generated for the x and y
Customer said problem occurred after power outage, tv worked initially for couple hrs then went off. Thats why we tried power supply first no change, could not find what 8 blinks mean
  • Hitachi Master
  • 19,396 Answers
Re: "main board leds blink in sequence and shut off during power on"
Thta is clearly not power board problem, if you have anough knowledge to DIY, then buy the service manual and follow troubleshooting diagrams, you always need to test the parts before replacing them.
See below for getting service manual:
eBay.com.my: HITACHI 55HDX99 55HDT79 55HDS69 SERVICE REPAIR MANUAL
Hitachi 55HDS69 DW2-U Service Manual
Service Manual 55HDS69, 55HDS69DW2U
50DX10B 50EX8K 50VF820 51GWX20B Service Manual
Posted on Jan 30, 2009
    Genius:
  • 1,913 Answers
Check your power supply waltage and earthing properly working.
LG 47LN5200 no picture led blinks then shuts down
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
http://electro-medical.blogspot.com/
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board
Mar 08, 2016 | LG Televison & Video
When the TV is turned on there is no picture with a verticle line throught the screen. I took the cover off the back and the orange LED light is blinking. The other LEDs are not illuminated.
Hi nikianddonni,
First of all, thank you for posting your question here at Fixya.
I'm assuming here that your TV is Hitachi 55HDS69.
Yes, the digital main board has 5 LED called "knight rider". After "power on" these LED will be turned on in sequence, it may take a few seconds then after the program is loaded without error, all LED will be turned off. All LED should not lit. If some errors occur, it will give an error code through the LED(s).
My first advice is, to unplug the unit from the outlet for at least 1 hour and then check if the symptoms remain the same. If yes, please let me know which LED( D201, D202, D203, D204, D205 ) lit solid/flashing to pinpoint where the fault came from and provide you resolution to fix the problem.
Thank you for your patience...
Jdvillanueva
Dec 26, 2011 | Hitachi 55HDS69 55 in. Plasma Television
I have a hitachi 65SWX20B projection TV. When I power it on, I get no picture, no sound, and on one of the circuit boards, an LED (D967) blinks dimly (1/2 second on, 1/2 second off). A soft click is...
If the board with the blinking LED has larger than average parts on it, it is likely the main power supply and the clicking may be from a relay that is connecting and then, disconnecting the AC. With no video or audio, the main power supply has likely failed. Contact Hitachi service to ask how much the repair or replacement cost of the supply is. Make sure you have all involved model numbers handy; the one from your set with the mfr. date if present and if you can find an assembly number on the power supply itself. it may save you time and errors. These boards are often simply plugged into other assemblies with dissimilar plugs but if you decide to DIY, take some snapshots of the cabling to be on the safe side.
Mar 11, 2011 | Hitachi 65SWX20B 65" Rear Projection...
Power indicator light blinks-7 times. will a new power supply fix it
Physically disconnect the SU board and the SD board. (See precaution # 5)
Plug in the TV and turn it on.
Does the TV shut down and the power LED
blink 7 times?
Yes
No
Replace the Panel and the SU board.
(See precaution #3)
Reconnect the SD board only.
Yes
No
With the SU board and the SD board still disconnected, remove connectors SC2 and SC20 from the SC board (See precaution # 6)
Disconnect the SD board and reconnect the SU board. (See precaution # 5)
Yes
No
Replace the Panel, SD, and SU board.
(See precaution #3)
Replace the Panel and the SD board.
(See precaution #3)
Replace the SC board.
(See precaution #3)
No
Replace the D board.
(See precaution #3)
blink 7 times?
blink 7 times?
blink 7
There is a sequence that you have to check to figure out which board is bad,
Feb 16, 2011 | Panasonic TH-42PZ700U 42 in. Plasma...
The tv cycles on and off
dry soldering on EHT out put side horizontal SEXCTION
Jan 15, 2010 | Hitachi 55HDS69 55 in. Plasma Television
No Picture, The power and the OPC Led's are blinking
Your TV is in fault protection. Due to blows caps on the PSB-power supply board.
Best Regards and Semper Fi
Mar 27, 2009 | LCDDigital LCD7 Television
Hitachi 43UWX10B: Power light blinks continuously on and off, no picture
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://homenol.blogspot.com/
If blinks continue without any pause, the main board is faulty.
Aug 08, 2017 | Hitachi 43UWX10B 43" Rear Projection...
Power Problem
usually blink code on front gives direction but first thing to do would be to determine if surrounding sustain boards are causing draw on power supply by disconnecting them one at a time from power supply. y is on left looking from back and x is on right looking from back. if led goes solid with either board disconnected check supply voltages and if come up and stay up replace that board. if no change then you would need to verify vs on command coming from logic main to power supply. should be labeled on power supply connector and should be 3 volts. if present replace power supply if not present verify if logic main board sitting underneath signal board has one solid and one blinking led on if verifying normal operation and if so replace small signal board
Aug 15, 2008 | Philips 42PFP5332D 42 in. Plasma...
NO PICTURE
7 blink error on that model is 8.6 volt error and generally caused by y main board. disconnect y main from power supply and if tv does not shut down and vs voltage comes up (test point on power supply) replace y main and both y upper and lower buffer boards as replacing one without other two could cause additional failures
Jun 26, 2008 | Philips 42PF9630A 42 in. Plasma Television
Philips 42PF7320A/37 won't power up Led blinks 7 times
This what to do measure from the logic board which is located under the small signal board and have the AV jacks connected to it. If the voltage is 3.1 or close the problem is with the power supply or a boar connected to the power supply. Unplug the set. Disconnect the Y main board first that will be on the left side of the set facing the back. Plug the set back in if the led is solid replace the Y main and the Y upper lower. If still blinking plug the Y main back in and unplug the X main which is on the right side facing the back. If the led is green replace the X main. If the led is still blinking replace the power supply.
But if the volts are 0 the problem is the SSB or the logic board. In that case take the (SSB) small signal board out the set and place 1 jumper on J8003 and another jumper J8004 of the left side of the power supply. Then place 1 jumper on CN2072 of the lower left part of the logic board. Plug the set back in if the set displays a white, blue ect screen replace the SSB. If not and on the logic board you don't have 1 solid blue led and 1 blinking led data is not flowing and change the logic board.
Dec 13, 2007 | Philips 42PF7320 42 in. EDTV-Ready Plasma...
Hitachi 55HDS69 55 in. Plasma Television Logo
1,133 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
