Question about Intel 865G Motherboard
Power Problem I have intel 865 board and 3 Giga P4 processor. My problem is that sometines when i press power button to on the computer it started but with in a moment computer turns off. if i press the power button again now then nothing happen as there is no power (power is still there on board). then i pull out the power cable from back and plug it again then computer start normally. sometines the problem is repeated few times but i repeat the same process untill the computer starts
  • 1,073 Answers
Hmm, it souds like some of the power cables are poorly fitted.
I suggest you to open the pc and unplug the power cables one by one and the plug them in again, you can even unplug and replug all the cables in your pc.
DONT forget to unplug the powercable to the PSU fist! And dont connect that one until you finnish all the your other work.
Good luck to you
Posted on Jan 30, 2009
  • 53 Answers
This is an issue with the power management and sleep setting of your machine. Basically when you press the power button and the machine is in sleep mode the machine will resume and then shutdown. Then if you press the power button again it won't work until you hard reset the machine by pressing and holding the power button for at least 10 seconds.
Follow this link for info on setting an s3 sleep state in xp.
Also check your settings by going over the information on this page.
For Vista the S3 sleep state is on by default and you might want to change this. To do this follow these instructions.
Never boot when start up
That's because you have a Power Supply with a weak voltage power rail
How do I know this?
1) IF all of the LED lights were on at once, they would use less than 1 WATT of power.
2) EACH fan uses 2 to 3 Watts of power.
3) A typical Processor can use 51 to 125 Watts of power. Just depends on what processor it is.
Your motherboard?
With the LGA 1155 processor socket, and the Intel H61 Express chipset, it can support Intel Core i5, and Core i7 processors.
(That use an LGA1155 processor socket)
Information on the Intel H61 Express chipset,
List of Intel Core i5 processors, that use the LGA1155 processor socket,
95 Watts maximum (TDP) Also scroll down.
List of Intel Core i7 processors, that use the LGA1155 processor socket,
95 Watts M-A-X-I-M-U-M. (TDP = Thermal Design Point) Also scroll down.
What is happening?
You press the Power On button. This plastic button in turn, presses against the Power On switch. A Momentary Contact Switch.
The brief closing of the Power On switch, closes the Soft Power On circuit, in the Power Supply.
The Power Supply turns on.
The first chipset to receive power is the BIOS chipset. The BIOS program starts.
BIOS looks to see what devices are connected, does a Ram Memory count, TURNS the Processor on, and hands the computer over to the Operating System.
(Windows XP, and Windows 7, are two examples of an O/S)
When BIOS goes to turn the Processor on, the Power Supply 'falls flat on it's face'.
Has to enough power to light a few little LED lights, and maybe spin a fan, or two, but NOT enough power for the Processor.
The monitor is stating No Signal, because there is no video signal coming from the computer. This is because the computer is not working, because of that bad Power Supply.
[Weak voltage power rail ]
Want to know how to test the Power Supply?
Post back in a Comment.
Jun 20, 2012 | Intel Desktop Board DH61WW Classic Series...
Board runs shows to be on runs but no beep and no display. No beep even when processor or memory removed.
The problem is in the processor or in the board to check first change the processor sutable for the socket and switchon the computer still the computer doesnt work check the secondery power supply thats four pin from the smps to the motherboard check all the FET and the capacitor in the powersupply also the 32khz crystel and the 14.182khz crystel and the clock ic
Mar 29, 2011 | Gigabyte Giga-Byte: GA-8S661FXMP-RZ P4...
Hi.. i need help.. i have trouble with my PC.. after instalation my computer, my hi.. i need help.. i have trouble with my PC.. after instalation my vga can't not detected in my PC. i need Prescott 533...
hi hulan ,
intel 865 mother board need intel 865 driver and 865 m board bus speed is 800
but 533 buss speed mother board is 845 m board it will not match with 865 ,so you should download intel 865 vga driver .Go any mother company >support>choice mother model and download it.I should not give any answer to any email id ,sorry dont mind.
Nov 12, 2010 | MSI : 865PE Neo2-PLS P4 Prescott FSB800...
How to download auidio/video drivers in the intel mother board D865gbf free drivers
Oct 14, 2010 | Intel D865GBF Motherboard
I have a intel desktop board d102ggc2 motherboard,p4 3.00 2mb 800ghz processor,160gb samsung ide hdd,512mb kingston ram and 350w power supply.the problem is that the computer shout downs
Automatic shutdowns are generally caused by three things:
1. A ground fault on the MB, which can be almost impossible to track down.
2. A faulty powersupply, which I would buy a power supply tester just to make sure.
3. A heat related error, check all your fans and heatsinks to make sure everything is clean and in order.
Aug 26, 2010 | Intel D865GBF Motherboard
P4/not booting up upon start
Hi try to open you chase and unistall all the additional slot cards and try to boot up, sometimes one of the slot cards fails and if that happens your machine wont start up until that slot cart is removed, thats how your machine protects it self
May 08, 2009 | Intel D865GBF Motherboard
Monitor goes into 'Power Saver Mode' on boot up!
You need to upgrade your motherboard BIOS to the latest version (V.5a) to support your DUAL CORE 2.5Ghz processor... that's the problem.
Jan 07, 2009 | Corsair Memory Corsair VX 550W Ultra Quiet...
Aug 19, 2008 | Intel Pentium 3 , 450 MHz Pentium III...
250gb sata hard disk to 845 glad mother board
Hello all. I have the same issue. My MB is 845G [P4 2.4 Ghz] and SATA harddisk I need to install is Seagate 250 GB Baracuda with 3.0Gb/s interface, I belive which makes this HD as SATA II. So for this motherboard should I prefer PCI cards which support SATA II over the supports SATA I [these are cheaper].
Thanks so mcuh!!!
May 12, 2008 | Computers & Internet
Intel 865G Motherboard Logo
78 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
